DEFINE OSC 20
INCLUDE "MODEDEFS.BAS"
#config
__CONFIG _CONFIG1H, _OSC_HS_1H
__CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOREN_OFF_2L & _BORV_2_2L
__CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_16384_2H
__CONFIG _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
__CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
__CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L
__CONFIG _CONFIG5H, _CPB_ON_5H
#endconfig
T2 var byte
LedG VAR PORTA.1 ' Green LED
LedR VAR PORTA.2 ' Red LED
BUZ VAR PORTA.3 ' Buzzer OP
KeyLine VAR PORTA.5 ' keyline
BPear1 var PORTB.4 ' Push 1 IP
BPear2 var PORTB.5 ' Push 2 IP
Bcall var PORTB.6 ' Call Button
Bcancel var PORTB.7 ' Cancel Button
LedR = 0 ' led off
LedG = 0 ' led off
Start:
BUZ = 1 ' Buzzer off
KeyLine = 1 ' transmitter off
Slp: ' Now prepare for sleep
INTCON=0 ' Disable all interrupt including tmr0
INTCON2.7 = 0 ' Enable weak pull-ups
PORTA=%00001000 '
PORTB=%11110000 '
PORTC=%00001000 '
TRISA = %00000000 '
TRISB = %11110000 '
TRISC = %00000000
T2=PORTB ' Read port to ensure no setting of flag
INTCON=%10001000 ' Enable the global interrupt and enable the change on port b
@sleep
PAUSE 100 ' Sound buzzer and Led as indicator of sleep exit
ledr=1
BUZ=0
ledr=0
BUZ=1
goto slp
