Converting ASCII HEX digits to decimal...
Results 1 to 4 of 4
    Default Converting ASCII HEX digits to decimal...
    My project recieves an ASCII text string such as "3FE35853" and stores them in an array. I need to convert each ASCII byte in the array to its decimal equivalent.
    example:
    "3" = 3
    "F" = 15
    "E" = 14
    Is there an easy way to do this without using a lookup table?
    John
    Default Re: Converting ASCII HEX digits to decimal...
    Are you sure it is not pairs like '3F', 'E3','58','53'?
    If it is the you can use HEX modifier.
    e.g. HSERIN [hex2 byte1, hex2 byte2, hex2 byte3, hex2 byte4]
    Dec 2007
    Finland
    Or this might be one option and you can make it easily scalable beyond 8 bit input string...
    Hex_input       var byte
    ASCII_Array     VAR BYTE [8]
    i               var byte
    for i = 0 to 7
        DEBUGIN [HEX1 Hex_input]
        ASCII_Dec_Array[i] = Hex_input
    next i
    Thank you. That will work.
    John
