LCD Showes Some Wrong Letters
Results 1 to 3 of 3
    Feb 2008
    Default LCD Showes Some Wrong Letters
    hello,
    Never posted here before. But I do read a lot.
    Any way maybe this will help some one starting out with LCD's
    I use Pic Basic Pro Version 2.50a
    Micro Code Studio Version 3.0.0.5
    I have A Microchip PIC 12F628A
    and a Hantronix HDM20216L-1 20x2 LCD
    I started off with the "Hello World" LCD Toturial.
    plugged in a chip, set the right chip in PBP, programed it up, soldered a few test leads to my lcd. and this is what i got
    Code: -------------------------------------------------------------------
    Pause 500 ' Wait for LCD to startup
    loop: Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    Screen 1: Hello
    Screen2: HelloWo ld
    (well this is wrong! Hello was suppose to disappear and last i checked "Wo ld" had an r in the middle)
    ok lets modify the code and try something new
    new code: -------------------------------------------------------------------
    Pause 1000 ' Wait for LCD to startup
    lcdout $fe, $80
    Lcdout "abcdefghijklmnopqrst" ' Display Hello
    lcdout $fe, $c0
    Lcdout "uvwxyz0123456789ABCD"
    lcdout $fe, $80
    Lcdout "EFGHIJKLMNOPQRSTUVWX" ' Display Hello
    lcdout $fe, $c0
    Lcdout "VZ~!@#$%^&*()_+-=,.?"
    Screen 1:
    abcdefghijklmno7qrst
    Screen 2:
    EFGHIJKLMNO QRSTUVWX
    YZ>!@#$%^&*()_2-= .?
    ok still not even close since when is "p" = "7" and "~" = a right arrow, "+" = "2", and a comma = nothing.
    new thought maybe i have a bad wire, maybe i have a non compatible LCD, maybe I'm a rock
    well the answer is number three, after reading lots and finding nothing, i found a post about an LCD with a gridded out screen. several posts in the thread someone suggested that he had spelled CMCON = 7 wrong
    then i thought i don't have a turn off analog statement in my code.
    guess what,
    that's it works like a champ
    my only question is what if i need a analog input? say i want a battery meter on my project.
    now what i have no analog ports, can anyone suggest something for me
    Last edited by sbobowski; - 7th September 2008 at 15:36. Reason: wrong PBP Version
    Hi and welcome to the forum.
    You do not have to use the pins in the schematic in the manual for your LCD. You can assign other PIC pins for LCD usage by using the various DEFINE LCD statements. So, in that case, you can reassign the LCD to use other Ports/Pins leaving your Analog pins free.
    Here is an example where all the Data and Register connections for an LCD have been assigned to PortC... (PIC16F876)...
    	Define LCD_DREG PORTC				' Port for LCD Data
    	Define LCD_DBIT 4				' Use upper 4 bits of Port
    	Define LCD_RSREG PORTC				' Port for RegisterSelect (RS) bit
    	Define LCD_RSBIT 3				' Port Pin for RS bit
    	Define LCD_EREG PORTC				' Port for Enable (E) bit
    	Define LCD_EBIT 0				' Port Pin for E bit
    	Define LCB_BITS 4				' Using 4-bit bus
    	Define LCD_LINES 2				' Using 2 line Display
    	Define LCD_COMMANDUS 2000			' Command Delay (uS)
    	Define LCD_DATAUS 50				' Data Delay (uS)
    Feb 2008
    Talking
    Works GREAT thank you!!
    i did it on a pic16f628A and moved them to Port.B
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
