Digital Pot
Results 1 to 4 of 4
Thread: Digital Pot
    Jan 2008
    Default Digital Pot
    Hey
    I need this code:
    How to change 5 V on some . Sample when portb.0=1 (program).... program is like pot, it relaxation 5 volt, on 4.9 then 4.8..4.7...0. How can i do that? My english is bad i forget some things, sorry
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Tastature View Post
    Hey
    I need this code:
    You'd get a lot more help by writing some code and asking other people to help you figure out why it doesn't work VS. asking others to write code for you.
    A dozen different ways to do this...
    One way, yes, connect an external digital pot (I've used the Xicor types), and control it.
    Another way, use the PWM module (or software PWM) across an R/C network, vary the duty cycle of the PWM output to change the average voltage across the cap. Probably want to follow the R/C with an Op-Amp so any loads won't change the voltage across the cap much.
    Jan 2008
    Can you post samo exaple, i dont understand good?
    skimask's Avatar
    skimask Guest
    Cool
    PWM - pulse width modulation (wikipedia)
    http://en.wikipedia.org/wiki/Pulse-width_modulation
    1st hit in Google...
    PWM in a PIC...(search phrase 'pwm microchip.com')
    ww1.microchip.com/downloads/en/AppNotes/00538c.pdf
    1st hit both times...
  1. Digital Pot
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2012, 07:54
  2. Controlling a MCP4162 Digital Pot
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 6th February 2011, 18:51
  3. Digital Pot Advice
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2007, 20:38
  4. Replies: 4
    Last Post: - 24th January 2007, 22:20
  5. Serial control of a digital pot?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2006, 23:49
