Trouble with Lcdout
Results 1 to 4 of 4
    Tomexx's Avatar
    Tomexx Guest
    Default Trouble with Lcdout
    I have a keypad and an LCD.
    My keypad's scanning rutine returns a key (0 to 9).
    I'd like to display each digit (as I press the key on the keypad) next to the previous one.
    For example:
    After pressing digit 3 the LCD will read: 3
    Then I press digit 6, the LCD now reads 36
    then I press digit 4, the LCD now reads 364 and so on
    For some reason I can't do that. I've only been able to display one digit at a time by clearing the display first:
    Lcdout $FE, 1, #key
    but I really want to show them together as they're being pressed.
    Please help
    You've done pretty much OK... just rearrange things a little...
    Start:
    	LCDOut $FE,1
    KeyLoop:
    	Gosub GetKey
    	LCDOut #key
    	Goto KeyLoop
    Tomexx's Avatar
    Tomexx Guest
    Thanks Melanie.
    I didn't know that you could skip the "$FE" command when sending data using Lcdout.
    BTW, do you have a complete list of LCD commands for use with Lcdout? (I only have the ones from PBP manual and Google couldn't help me).
    Tom
    all the special command to use with LCDOUT are in the PBP manual.
    $fe,1 clear display
    $fe,$c0 jump to 2nd line
    etc
    so LCDOUT $FE,1," hello "
    will clear the display an write hello
    LCDOUT $FE,1,"line 1",$FE,$C0,"line 2"
    will clear the display and write line 1 on the first line, line 2 on the second line of your LCD.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 07:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 02:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
