Interfacing with the ISD4003
Results 1 to 7 of 7
    Sep 2006
    Default Interfacing with the ISD4003
    Anyone with experience in the voice chip ISD4003. I saw a few post here about it.
    I wanted to know how the memory is divided. Example.
    From the datasheet, the playback mode is initiated at 00, and ended at EOM. But if I have mulitple recordings, my second recording with not be starting with 00. How does it read the memory place once it has finish recording,
    Mainly, beside the first 00, how do we read the address at every start and stop of each voice recording?
    K
    You may need to use RAC and INT pin, then use SETPLAY and/or MC command. Datasheet is not really extensive about the explanation of it.
    Sep 2006
    RAC pin ?? Row address clock
    these datasheet do a poor job of explanation.
    I saw RINT for read interrupt, is this what you meant for INT ?
    No i meant INT & RAC pin
    http://www.winbond-usa.com/products/...4003Rev1.0.pdf
    And yeah their datasheet do bad job... but i saw worst.
    Maybe these one may clear up few things
    http://www.winbond-usa.com/products/...iefs/an_5a.pdf
    http://www.winbond-usa.com/products/...riefs/an_7.pdf
    Sep 2006
    I think I am almost there.
    I am checking the program and the ISD4003 datasheet. there is one last thing I am confused about. It is the following lines in the spi_send section in this thread:
    http://www.picbasic.co.uk/forum/show...hlight=isd4003
    isd_data_out = address REV 16
    isd_data_in = isd_data_in REV 16 ' Reverse the bits of incoming data (received LSB first)
    I do not understand why we need to reverse ..
    ken
    Because this example used the MSSP instead of SHIFTIN/SHIFTOUT + their modifier.
    AND this is unfortunately how those ISD works.
  1. ISD4003 to TDA7052A
    By Northstar in forum mel PIC BASIC Pro
    Last Post: - 14th January 2010, 17:27
  2. Interfacing DS1603 to PIC 16F877
    By hackableFM in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 21:37
  3. Interfacing two PIC micros
    By sajid in forum General
    Last Post: - 26th May 2007, 06:58
  4. Replies: 1
    Last Post: - 21st March 2007, 00:20
  5. ISD4003 & 16F877 Interface
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 17:50
