Aliasing a port with arbitrary I/O pins?
Results 1 to 3 of 3
    Apr 2008
    Default Aliasing a port with arbitrary I/O pins?
    I am using a 16F676 which has only two 6bit ports.
    I would like to have an 8bit port, but I am unable to Alias one.
    I am trying to do something like:
    OUTPORT.0 = PORTA.0
    OUTPORT.1 = PORTC.0
    but I will get compilation errors. I am using Microcode Studio.
    Is there anyway to get an 8bit alias that represents 8 I/O pins so that I can do something like:
    OUTPORT = %11101101
    Any ideas? Or will I just have to make a byte variable and create a routine to assign its values to output pins (and then run it every time I change the variable)?
    Jan 2006
    Istanbul
    Apr 2008
    So the short version, for anyone who finds this thread on a search, is that I do indeed have to just create a routine to assign the outputs.
    However, if you follow the link provided by Sayzer, you can find some simple and efficient routines to accomplish it.
    Thanks Sayzer!
  1. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 18:25
  2. Microcontroller with 2 way paging application problem
  3. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
  4. PIC PORT 'special' pins
    By barkerben in forum General
    Last Post: - 18th January 2005, 22:40
  5. PIC12F629, useing all I/O pins
    By Jcee324 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 12:05
