High End Pre with PIC 16F876A
Results 1 to 11 of 11
    Apr 2008
    Default High End Pre with PIC 16F876A
    Hi Guys:
    I am quite new to PIC Programming and I thought it would be an excellent place to learn about it at this forum.
    I have been working on this idea of developing a high end pre around PIC 16F876A, though as far as I could go the porject works fine as long as I use up, down and mute buttons.
    But I cannot figure out a way how to configure that input selection stage so that one button changes the input (a total of four inputs) and when it reaches input 4, any new press on button input shifts the input to "input 1". I use ULN2803 for driving relays.
    Appreciate if guys here could help me out.
    Abidr
    Not sure what you are after
    but this may give you an idea. http://www.picbasic.co.uk/forum/showthread.php?t=8602
    Or maybe use "count" routine. every time the button is pressed the counter increases. If the count VAR is 1 do something. If count VAR is 2 do something else. If count VAR > 4 then count VAR = 0.
    Is that what you need?
    Apr 2008
    thanks "mackrackit"
    link is not helpful.
    Other part is that is VAR=0 then input is "IPOD" if input =2 etc.
    My issue is how to define variable "an exmaple will be of great help" and how to shift the command to ULN2803 again an example will help.
    Attached is picture of populated PCB of the project
    abidr
    The count code would be something like this
    Bcnt VAR BYTE ' variable for counting
    Button VAR PORT?.? 'PIN FOR BUTTON
    MAIN:
    IF Button = 1 then Bcnt = Bcnt + 1
    IF Bcnt > 4 then Bcnt =0
    IF Bcnt = 1 then GOSUB someplace1 ' after done at the gosub "return"
    IF Bcnt = 2 then GOSUB someplace2
    so on and so on
    That is the basics, you may need a debounce routine and pauses. Maybe some endifs and elses too.
    The sub routines would have something like
    HIGH PORT?.?
    This pin will be connected to the pin on the 2803 that you want to trigger.
    Apr 2008
    Thanks dave heres is the code:
    ACTIVATE_RELAY:
    LOW MUTE ' Activate MUTE
    select case RELAY
    case 1 : PORTD = %10000000
    PAUSE 500
    case 2 : PORTD = %01000000
    PAUSE 500
    case 3 : PORTD = %00100000
    PAUSE 500
    case 4 : PORTD = %00010000
    PAUSE 500
    end select
    GOSUB SHOW_INPUT
    HIGH MUTE
    IF RELAY_FLAG = 0 THEN GOTO MAIN
    SHOW_INPUT:
    select case RELAY
    case 1 : LCDOUT $FE, $C0,"DVD 5.1 "
    case 2 : LCDOUT $FE, $C0,"USB DAC1"
    case 3 : LCDOUT $FE, $C0,"USB DAC2"
    case 4 : LCDOUT $FE, $C0,"CD "
    end select
    Let me give it a try I guess it should work now.
    If you need to count how many time a button have been pressed, you may use RA4/T0CKI. really easy to setup and work really fine. The only thing you need to read/reset is TMR0 register.
    Apr 2008
    Attached is the PIC of populated Project PCB.
    I have decided to put the button at RB6 and debounce it, so that it could change between inputs.
    I have already posted the whole code along schematics.
    Appreciate if someone could suggest improvements in the code or better mark area where code should be changed.
    Dec 2003
    Storrs, Ct.
    Default Snippett of my own.
    I also use a 2803 for relay control but use a PGA2320 for volume control. This is very much a work in progress but here is a snippett of code I use to change inputs and outputs. My switches however are a webpage done with a Siteplayer.
    switches:
          INTCON.7 = 0
          SerOut2 PORTC.6,SPbaud, [$00, $C7, $1E]
          SerIn2 PORTC.7,SPbaud, 100, mainloop, [power,ipod,computer,mute,bookshelf,subwoofer,volup,voldown]'
          INTCON.7 = 1
          checkswitches = 0
          if power = 1 then
               high relay6
               high relay5
               INTCON.7 = 0
               write 1, power
               INTCON.7 = 1
               gosub dostuff
               low relay6
               low relay5
               INTCON.7 = 0
               write 1, power
               INTCON.7 = 1
             'subroutine
    dostuff:
          mydata.0 = 0
          mydata.1 = ipod
          mydata.2 = computer
          mydata.3 = mute
          mydata.4 = bookshelf
          mydata.5 = subwoofer
          mydata.6 = volup
          mydata.7 = voldown
          select case mydata
                case 18
                     low relay1    'relays for speaker output
                     low relay2    'relays for speaker output
                     low relay7    'relays for Audio In
                     low relay8    'relays for Audio In
                case 20
                     high relay7    'relays for Audio In
                     high relay8    'relays for Audio In
                case 34
                     high relay1    'relays for speaker output
                     high relay2    'relays for speaker output
                case 36
                case 82,84,98,100
                     volup = 0
                     INTCON.7 = 0
                     SerOut2 PORTC.6, 84, [$00,$81,$24,volup]
                     INTCON.7 = 1
                     gosub Increasegain
                     gosub Post_Gain
                case 146,148,162,164
                     voldown = 0
                     INTCON.7 = 0
                     SerOut2 PORTC.6, 84, [$00,$81,$25,voldown]
                     INTCON.7 = 1
                     gosub Decreasegain
                     gosub Post_Gain
                end select
                INTCON.7 = 0
                write 2, ipod
                write 3, computer
                write 4, mute
                write 5, bookshelf
                write 6, subwoofer
                INTCON.7 = 1
    Done somewhat like yours. Hope this helps..
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    Apr 2008
    Rojodu:
    Thanks man for the help I think this code sample will be all that i need.
    Here is my updated version of preamp I call it V1.3.
    I guess this code will be enough.
    Check_sel
    If sel=0 then debounce_sel
    debounce_sel:
    pauseus 200
    If sel=0 then check_sel
    relay=realy+1
    if relay=4 the relay=0
    Abidr
    Dec 2003
    Storrs, Ct.
    Default Your welcome.
    Glad you found it helpfull. Check out this thread for more reading and some pictures of my PGA and amp setup.
    http://www.picbasic.co.uk/forum/showthread.php?t=7717
    Apr 2008
    Ok guys:
    Code completed sucessfuly, just needed a few tweaks here and there, it has compiled sucessfully and burnt to 16F876A well, now its testing (which I ll do over the weekend).
    Once completed I ll post my results here.
    Abidr
  1. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 01:09
  2. PIC keeps resetting when executing subroutine
    By jbirnsch in forum mel PIC BASIC Pro
    Last Post: - 27th August 2009, 07:03
  3. Using Sleep
    Last Post: - 17th August 2008, 04:05
  4. need help simulating PS/2 mouse
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 9th December 2007, 21:49
  5. Pic suggestion for high precision voltage measure
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 10th April 2004, 06:22
