Simple question about Serin..
Results 1 to 7 of 7
    Nov 2007
    Default Simple question about Serin..
    Hello,
    I'm writing some code for a couple of 16F628's on a RS485 network..
    I'm using the serin command ;
    databyte      VAR    BYTE    ' Recieved command/request
    ADRESS        VAR    BYTE    ' Adres selected by dip switches
    serin PortB.1,t9600,[WAIT (ADRESS),databyte]
    The adress is selected by an 8 bit dipswitch on the slave pcb.
    The only way a slave can be adressed is by its unique adress.
    I now want to implement a broadcast adress to..
    I was wondering if there is a way so that the slave only completes the serin command if the "adress" statement OR the "broadcast adress" is forfilled ?
    I've tried ;
    BROADCAST     CON    %11111111 ' Broadcast adress
    serin PortB.1,t9600,[WAIT (ADRESS OR BROADCAST),databyte]
    But i knew this would be to easy..
    Any help would be greatly appreciated.
    Regards Donat
    Looks like your syntax is the problem.
    serin PortB.1,t9600,[ADRESS],databyte
    It waits for whatever is in the []
    You are coded more for SERIN2
    What 485 converter are you using?
    Nov 2007
    Default My mistake
    Sorry, thats my mistake
    It was originally a serin2 command..
    But it's about waiting for one qualifier OR the other i'm trying to implement.
    It should store the recieved byte once the slave's individual adress (qualifier 1) or the broadcast adress (qualifier 2) is forfilled.
    Maybe i should just divide it up in two different commands..
    Thank you
    Nov 2007
    Default RS485 Tranciever
    The RS485 Tranciever i am using is the TI SN65HVD06D 1/8 Load, 10Mbps
    http://focus.ti.com/lit/ds/symlink/sn65hvd06.pdf
    'Instead of waiting, grab the first byte and see if it's for your ID or Broadcast then
    'if so collect the rest of the bytes
    HSerIn Timeout,ExitRx,[BufRX(0)]
    If ((BufRx[0] = MyID) or (BufRx[0] = BroadCast)) then
    For Cnt = 1 to 7
    HSerIn Timeout,ExitRx,[BufRX(Cnt)]
    Next Cnt
    EndIf
    WAIT actually has to look at each byte as well in order to know weather to start storing or not.
    Bombay, India
    You can use Skinner's technique which is easy enough or consider this.
    If your command sequence is terminated with a known value like CR or CRLF which is the norm in most cases, your job becomes easier. What you have to do is just collect the data and buffer it till you hit the CR. Then, check the packet for ID and process accordingly. This is how I do it in my products
    ID xxxx CR
    If the packet is not yours and not a broadcast, discard it.
    Yes, but if he is doing something like modbus for instance, he only has the node#, correct number of bytes to collect, and then the timeout or Silent time.
    Then he would have to verify the data with a crc check before proceding, this of course is if he is using MB RTU and Not ASCII, or his own home grown protocol.
    Only reason I menioned modbus is because he mentioned a 485 network, Node ID, and Broadcast so it kind of sounds like it.
    Richard
  1. serin question?
    By sachymo in forum General
    Last Post: - 27th July 2008, 11:04
  2. SIMPLE question
    Last Post: - 5th February 2008, 19:27
  3. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  4. Simple question, I hope? (Serial control, 16F84A)
    Last Post: - 31st December 2005, 20:47
  5. Replies: 4
    Last Post: - 7th September 2005, 15:11
