Debounce routine comments?
Results 1 to 4 of 4
    Default Debounce routine comments?
    I needed to have some short of debouncing of an input in order to accept it in my program.
    In my program I am looking if the input has a High(+5V) or Low(0V).
    The input is driven by the contacts of a relay which cannot oscillate.(If this happened I believe this could cause the program to hang)
    INPUTPORTBIT VAR PORTx.x
    COUNTERA VAR BYTE
    INPUTPORTBITFLAG VAR BIT
    '''''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''''''''''''' subroutine CHECKINPUTPORTBIT
    CHECKINPUTPORTBIT:
    COUNTERA=10
    CKCK:
    Pause 100
    IF INPUTPORTBIT=0 Then
    COUNTERA=COUNTERA+1
    IF COUNTERA=20 Then WAYOUT1
    Else
    COUNTERA=COUNTERA-1
    IF COUNTERA=0 Then WAYOUT2
    EndIF
    GoTo CKCK
    WAYOUT1:
    INPUTPORTBITFLAG=1 ''OK OUR INPUT WAS STABLE FOR AT LEAST 1 SEC
    GoTo WAYOUT3
    WAYOUT2:
    INPUTPORTBITFLAG=0 ''NOT OK
    WAYOUT3:
    I used this routine(it is working for me Ok since yesterday) which ,I think, has some nice features like making the debouncing ''light'' or ''heavy'' by altering the PAUSE and/or the COUNTERA start and limit value.
    Perhaps someone can improve it or make it with less code?
    Please comment
    Bill
    Question Reinventing the wheel ...
    Why not simply use the BUTTON Command ??? ... even in a loop for long debouncing times ...
    Hi Bill,
    I agree with ACETRONICS about the button command, I have a thought about making it easier to follow your code, instead of all caps you might try InputPortBitFlag or Input_Port_Bit_Flag.
    Ultimately only you have to look at it, I just thought it might be easier.
    JS
    Joe S your suggestion will be given a trial because it started annoying me also having only capitals but sometimes habits are difficult to change.
    The reason for reinventing the wheel ,as you put it, is that from the very early days of PicBasicPro ther were some bugs and problems with this Button command and I was avoiding it to the point I realize now that I forgotten all about it.
    Having a look though in the manual I think it is not providing the same things as the "wheel".
    It is also peculiar that the manual ''prompts'' you not to use it but use an IF THEN instead.
    Now that I "apologized" I am waiting for the verdict.
    Bill
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 20:30
  2. Replies: 4
    Last Post: - 17th December 2009, 00:29
  3. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  4. PIC16F84A Tachometer LED routine
    By ThaSanta in forum mel PIC BASIC Pro
    Last Post: - 24th July 2009, 02:58
  5. Software Driven Reset Routine
    Last Post: - 11th April 2005, 00:53
