Automatic Toilet Flusher - Page 3
Page 3 of 3 FirstFirst 123
Results 81 to 99 of 99
  1. #81
    Jul 2007
    I got it to work!!!!!!!!!
    Although I got to adjust the ms because it only moves like 3mm but it should be done soon!
    Ps I found out what was wrong
    The servo was not connected right to the pic
    I had the postive going to the pic pin and the signal was going to positive
    I got the new servo in and now all I have todo is make some adjustments in the software
    So you will here from me soon
  2. #82
    Jul 2007
    Can't figure out the delay for the servo
    Here's my program
    IRLED1 var PORTB.0
    Servo var PORTB.1
    TRISB=%00000001
    Loop:
    If IRLED1 =1 then
    Pulsout Servo,110
    pause 10
    Pulsout Servo,150
    Pulsout Servo,110
    Goto Loop
    I Want it to move the servo to the right to it's most and delay for two seconds and
    then come back to center.
    If anyone can help me out
    it would be much appreciated
  3. #83
    Does this work?
    x var byte
    IRLED1 var PORTB.0
    Servo var PORTB.1
    PORTB = 0 ' setup for high-going pulsout
    TRISB=%00000001
    Loop:
     If IRLED1 = 1 then
       goto Flush ' flush
     else           ' else center
      for x = 1 to 20
        pulsout Servo,150
        pause 20
      next x
      goto Loop
    Flush:
      for x = 1 to 20
       Pulsout Servo,200
       pause 20
      next x
      pause 2000
      Goto Loop
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  4. #84
    Jul 2007
    Thanks for the code bruce
    I appreciate it
    Although it didn't work
    instead of not moving enough like my code
    this code twitches every two seconds unless it makes contact which it just go's to center
    and the twitches are just a little more then mine was at last time
  5. #85
    Italy
    (A long-lasting project).
    Your room mates will very soon say:
    OK, we will flush the toilet but you turn off the light at night so we can sleep!
    Seriously, what they think about your efforts?
    Best regards,
    Luciano
  6. #86
    Jan 2006
    Istanbul
    Quote Originally Posted by Luciano View Post
    Best regards,
    Luciano
    Luciano,
    I think they will soon say, "let us help you with your Automatic Toilet Flusher Project".
  7. #87
    Jul 2007
    lol well I have a sleeping disorder so they are used to me up
    I just want this thing to work.
    I will get it though
  8. #88
    Funny that should work. Here's a few things to check.
    Make sure you're using a separate power supply for your servo, and you have a common ground between them. Running a servo from your controller power supply can cause problems if you aren't using a hefty bench type power supply with a lot of filtering to remove motor noise.
    Make sure you're using the correct voltage for your servo. These normally run on 4.8 to 6V. If you're trying to operate your servo from 9V that may be a problem. Most hobby type servos can't handle 9V, and a 5V control pulse from the PIC is going to look pretty weak to a servo operating at 9V.
    I tested the above code example, and it works as expected with a Hitec HS311 servo operating at 5V with a 16F627. Note some servos will move 90 degrees right or left, so you can tweak the value in the Flush routine between 200 to 250 to extend the rotation range.
    My HS311 moves full right with 250, and centers with 150.
    -Bruce
    tech at rentron.com
  9. #89
    Jul 2007
    Yep I am using a separate power supply for both and each is filtered
    Yep I used 5volts and I even tried it with 6
    I am using a hi-tec HS-322HD
    And I used another servo which was a futaba S3003
    but it was modified for continues rotation but it was rotating in 90% degree section
    but that was when it was not in contact but when it was in contact it didn't move just like the hs-322HD
  10. #90
    Quote Originally Posted by Techbuilder View Post
    You mean in contact with the handle? If so, maybe the servo is not strong enough?
  11. #91
    Jul 2007
    No contact with the IR led
    Although I figured out that I have to modify the servo to do 180 degrees
    because mine only does 60 degrees, still doesn't explain why it is only going off when it is not in contact with the IR led.
  12. #92
    Jul 2007
    Actually if I spin it by hand it spins enough
    so I don't believe that's the problem.
  13. #93
    Jul 2007
    It is not connected
    the only thing that it is connected is to the IR receiver which it needs to be
  14. #94
    May 2008
    Hey everyone, I've been working on a very similar project (also my first PIC only project), before I even discovered this thread. I'm having a problem getting my servo to move 90 degrees. I'm using a parallax standard servo (left over from my Basic Stamp days), which is based on a futabu (http://www.parallax.com/dl/docs/prod...s/stdservo.pdf).
    I tried using the code that Bruce posted, but the servo only moves about 10 degrees each time the move loop is called. I also tried using a modified version of the BS2 code in the pdf I linked, but I get the same result. How can I get my servo to move the full 90 degrees?
    Here is the code I'm using:
    @ __config _INTOSC_OSC_NOCLKOUT &_WDT_ON &_PWRTE_ON &_MCLRE_OFF &_BODEN_ON &_CP_OFF &_DATA_CP_OFF &_MCLRE_OFF
    servo1 var Porta.0
    x var byte
    		low servo1
    		HIGH PORTB.3
    loop:	pause 500
    		low portb.3
    		high portb.3
    		GOTO move
    		pause 2000
    		low portb.3
    		GOTO loop
    move:	for x = 200 to 1200
       		pulsout servo1,x
       		pause 18
    		next x
      		pause 2000
    I have the LED blink so I can be sure that I know the program is working properly and I can tell when the servo should be moving.
    Thanks for the help in advance!
    BTW, I'm making the project because I have a cat that is toilet trained, not because room mates don't flush
  15. #95
    And the PIC you are using is ______________________(fill in the blank).
    Kinda handy to have that sort of info, dontcha think?
    Servo pulse width is GENERALLY centered around 1.5ms...which means that there's probably something wrong here:
  16. #96
    May 2008
    I'm using a 16F627A
    and yes, I've tried changing those numbers and I've tried using the numbers that Bruce posted, but I still get the same result regardless. I've also tried using a different servo (another parallax one)
  17. #97
    Quote Originally Posted by JohnnyV View Post
    I'm using a 16F627A
    So, you're running at 4Mhz (INTOSC). The PBP manual tells us that at 4Mhz, pulsout has a granularity of 10us. Your loop runs from 200 to 1200, meaning 2000us (2ms) to 1200 (12ms). A bit out of the range of a normal servo ya think? Unless you've got one of the oddball ones...
    Also, try turning off the WDT and Brown-Out reset for grins... You might be killing the battery voltage when the servo tries to move and causing a reset.
  18. #98
    Use GOSUB VS GOTO if the routine you're going to uses RETURN to get back.
    Disable onboard comparators with CMCON=7 before trying to use a pin that
    has the comparator feature.
    Give this a shot;
    servo1 var Porta.0
    x var byte
    CMCON=7 ' <-- disable analog comparators
        low servo1
        HIGH PORTB.3
    loop:
        low portb.3
        high portb.3
        GOSUB move   ' <-- use GOSUB VS GOTO
        pause 2000
        low portb.3
        GOTO loop
    move:
        for x = 200 to 100 STEP -1 ' 2mS to 1mS pulse
          pulsout servo1,x
          pause 18
        next x
        pause 2000
        for x = 100 to 200 ' 1mS to 2mS pulse
          pulsout servo1,x
          pause 18
        next x
        pause 2000
    This should cycle your servo from one side to the other. Tested with a
    Parallax servo.
    -Bruce
    tech at rentron.com
  19. #99
    May 2008
    Bruce, works beautifully, thank you!
  1. Automatic 240V / 110V selector
    Last Post: - 13th October 2008, 00:33
  2. LCD automatic management?
    Last Post: - 26th September 2008, 11:24
  3. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  4. Automatic turn off
    By AMay in forum Schematics
    Last Post: - 6th February 2006, 12:31
