pwm with voltage monitoring
Results 1 to 4 of 4
    Puerto Rico
    Exclamation pwm with voltage monitoring
    Hello i need a Idea how run a DC Motor but monitoring the voltage with a A/D pin.
    my problem is my Volt Divider is not Stable so mi reading are no correct.
    10k and 10.5k in my Divider
    My Hobbies is PicBasic PRO
    Hi, ...
    Just read the voltage ... during OFF periods of the PWM drive ...
    Puerto Rico
    Lightbulb
    that you mean i have to turn off the motor to read the volts
    or
    please send a example
    thanks
    Lightbulb
    Motor is turned off automatically during PWM off ( or LOW ) periods ...
    just sample and hold during this moment.
    that's how all ESCs current limiting devices work ... they just sample the power mosfets voltage loss ( = Intensity * Rds ON ... ), and compare with a reference.
    Here, the "free running" ( PWM LOW state ... ) voltage of your motor is proportionnal to the rotor speed ...
    That's all !!!
  1. Newbie: Need help with Voltage Monitoring
    Last Post: - 16th November 2009, 01:31
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. Voltage monitor and PWM control
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 11th May 2009, 16:11
  4. Monitoring voltage and current ?
    By iugmoh in forum General
    Last Post: - 1st April 2009, 11:39
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
