MCS+ with PBP 2.50
Results 1 to 5 of 5
    Default MCS+ with PBP 2.50
    I just loaded my CD-ROM of PBP 2.50 and had a quick burrow in the manual.
    Big VAR LONG immediately fails. MCS+ does not recognise LONG as a keyword.
    I checked the MeLabs site (now showing PBP 2.50 available) and the Mecanique site but could not find any clues .
    How do I tell MCS+ 3.0.0.0 to use PBPL instead of PBPW?
    Cheers
    Brian
    Notice:
    This workaround is now obsolete. Please see post #4
    <hr>
    I've heard there will be an update to MCS that will make things easier.
    But I have not heard when that might be.
    So, in the mean time this is what I'm doing ...
    I have 2 folders PBPW and PBPL.
    PBPW is the original installation of 2.50
    PBPL was a copy of that folder.
    Then in the PBPL folder, the PBPL.EXE gets renamed to PBPW.EXE (delete or rename the existing PBPW.EXE first)
    Now, in MCS+ goto ...
    View | Compile and Program otions | Compiler tab | Find Manually Button
    And select the PBPL folder for Longs, or the PBPW folder for normal.
    hth,
    Default Works a treat
    Thanks Darrel,
    That little workaround works a treat.
    It still needs a patch from Mecanique to make the reserved word capitalisation work however.
    Cheers
    Brian
    Once again I get to be the bearer of Good News.
    There's a new update to MicroCode Studio +. Version 3.0.0.5
    Now there's a Checkbox on the Compiler Options Tab that selects PBPL as the compiler. Or, un-check it for PBPW.
    Sure makes things easier.
    If the Checkbox is checked, the editor will also highlight the LONG variables.
    And a big one, the ICD works with signed 32-bit variables. &nbsp;
    Thanks to David Barker! http://www.mecanique.co.uk/
    It's an easy update. In MCS+, goto View | Online Updates
    <HR>Notice:
    If you've used the previous workaround from Post #2, then you should be able to just point to the original PBP 2.50 installation folder using the Find Manually button. The second folder is no longer needed.
    Default easy
    This is how upgrades should be.
  1. PBP 2.50 and Longs
    By mikendee in forum GPS
    Last Post: - 21st May 2008, 21:16
  2. PBP 2.50 UPGRADE problems!!!!
    Last Post: - 7th March 2008, 15:42
  3. PBP 2.50 manual
    By Fredrick in forum General
    Last Post: - 6th February 2008, 03:40
  4. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 20:45
  5. New PBP 2.50?
    By Dave in forum mel PIC BASIC Pro
    Last Post: - 9th September 2007, 19:14
