LCD_AnyPin.pbp
+ Reply to Thread
Results 1 to 40 of 109
Thread: LCD_AnyPin.pbp
    Default LCD_AnyPin.pbp
    This has come up several times, and likewise, I've tried to approach it several times...
    After a 6 month pause from working on it, suddenly all my problems were staring me right in the face, leaving me to wonder ... "What the Hell was I thinking!" Or, maybe Not thinking.
    After fixing the now obvious mistakes ...
    Finally, "A Winner!"
    Here's a viable solution to ...
    "How do I scatter the pins of the LCD data bus across multiple ports with PicBasic Pro?"
    First, let me show you what a sample program might look like...
    ;----[ Change these to match your LCD ]---------------------------------------
    LCD_DB4    VAR PORTA.0
    LCD_DB5    VAR PORTB.3
    LCD_DB6    VAR PORTB.7
    LCD_DB7    VAR PORTC.1
    LCD_RS     VAR PORTD.4
    LCD_E      VAR PORTA.1
    LCD_Lines  CON 2 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 50 ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
    ;----[ Your Main program starts here ]----------------------------------------
    LoopCount VAR WORD
    PAUSE 500 : LCDOUT $FE,1 : PAUSE 250 ; Initialize LCD (You may not need this,
                                         ; but some displays are picky)
        LCDOUT $FE,1 ; clear screen
        LCDOUT $FE,$87,"Hello,",$FE,$C8,"From DT!"
        FOR LoopCount = 0 TO 65535
            LCDOUT $FE,$80, IDEC LoopCount
            LCDOUT $FE,$C0, IHEX4 LoopCount
        NEXT LoopCount
    GOTO Main
    Pretty simple ey?
    Just assign the Pins, Include the file, and away you go, using LCDOUT just like you always have.
    Ok, so now for the other Simple part that can go tragically wrong if you're not careful.
    Yes, ... that's right, ... I'm modifying the Library again.
    Or, more accurately, ... "You" are modifying the Library.
    And before "You" change anything, ...
    "MAKE SURE" you have a backup of the file.
    Don't blame me if it gets messed up and you don't have anything to restore it with.
    And, I will apologize to MeLabs Support ahead of time for the extra support calls this will generate.
    Back it up! and they won't have a problem.
    In your PBP folder (the one with PBPW.EXE in it), open the Library file for the type PIC you are using.
    For 16F's open PBPPIC14.lib with Notepad.
    For 18F's open PBPPIC18.lib
    Search for this string ";* LCDOUT ". That's "semicolon star space LCDOUT space".
    You should see a section that looks like this ...
    ;* LCDOUT     : Send char to LCD                                *
    ;* Input      : W = char                                        *
    ;* Output     : None                                            *
    ;* Notes      :                                                 *
        ifdef LCDOUTJ_USED
      LIST
    LCDOUTJ    movf    FSR, W    ; Jumpman entry
      NOLIST
    LCDOUT_USED = 1
        ifdef LCDOUT_USED
    ; NEW Code goes here...
      LIST
    LCDOUT  movwf   R3 + 1          ; Save char
    That one is from PBPPIC14.lib, for PBPPIC18.lib the only difference is it will show FSR0L, instead of FSR.
    Insert this code into the spot marked ; NEW Code goes here...
    It's very important that you get the EXACT line. Be careful ...
    ;*               Added for HighJack                             *
    HIGHJACK_USED = 1                                              ;*
    LCDOUT_HIGHJACKED = 1                                          ;*
        ifdef HJ_LCDOUT                                            ;*
      LIST                                                         ;*
    LCDOUT                                                         ;*
            L?GOTO  HJ_LCDOUT                                      ;*
      NOLIST                                                       ;*
        else                                                       ;*
    Now, scroll down past the LCDOUT code, and you should see this ...
      NOLIST
    DUNN_USED = 1
    PAUSEUS_USED = 1
    ; Second piece of NEW Code goes here ...
    ;* LOOK2      : Get data from any register                      *
    ;* Input      : R0 address / constant                           *
    ;*            : W data type                                     *
    ;* Output     : R0 result                                       *
    ;* Notes      :                                                 *
    Insert this code into the spot marked ; Second piece of NEW Code goes here ...
    ;*               Modified for HighJack                          *
    If you got it right, you can now use your HD44780 LCD on any pins you wish.
    If you got it wrong, restore the file you backed up (You did back it up, right?). Then try again. It work's. Really! Trust me!
    GoodNote: This modification will NOT interfere with your normal PBP LCDOUT routines.
    In order to invoke the Custom LCD port routines, the main file must have the statement ...
    If that statement is NOT included in your program, the LCDOUT commands will work the same way they always have.
    There are 2 files required to implement this approach ...
    LCD_AnyPin.pbp
    VirtualPort.bas -- (Included from the LCD_AnyPin.pbp file)
    Both files are included in the Zip file below. Extract them to your PBP folder.
    Amazing!
    Congratulations Darrel!
    I am very impressed! Really!
    Thank you very much.
    Thumbs up
    Thanks Ioannis!
    Really!<hr>
    Lesson Learned, when it gets too tough.
    Set it aside for awhile.
    It might look easier when you come back to it later.
    Just make sure you come back to it.
    Yes you are right about that. It happens alot to me too!
    Since I'm more the hardware guy, is a little confussing to really understand what you are doing. But as long as it works, thats fine!
    Anyway you write great piece of code. I really appreciate your offers.
    Perth, Australia
    Needed to do this on one of my projects the other day. This will be very useful. Thanks Darrel.
    Oops!
    Apparently, not ALL my problems were staring me in the face.
    I had PAUSEs in the LCD_Init: routine, and they were changing the system registers.
    So I Changed them to DelayUS, which doesn't use system registers.
    It worked OK before, but now it works right. Or, at least more behaved when Initializing.
    I've updated the LCD_AnyPin.zip file in the first post.
    Version 2.1
    <h1> * * * * Another Home Run Darrel ! * * * *</h1>
    <p>
    <font color=red><h2> THANK YOU !</font color></h2><p>
    JS
    Jan 2006
    Istanbul
    Darrel,
    I appreciate you sharing the code with us; and respect your knowledge. Thank you.
    BTW;
    Even though you clearly stated it, you will get this question anyway.
    Question from an UnKnown user:
    Hi Darrel, I tried to apply your "LCD_AnyPin" code into my project. I followed your instructions exactly as you stated. But, it did not work and now my LCDOUT command does not work at all. Can you collaborate me to solve this problem? because I don't see any problem on my side. I think your code is not ready for everyone, yet. Didn't you test it before releasing it?
    Reply to UnKnown user:
    You were warned.
    You didn't follow directions.
    You Blew It!
    Not my problem!
    And by the way, there's a copy of the file on the CD you got when you bought PBP.
    Quote Originally Posted by sayzer View Post
    ..... I think your code is not ready for everyone, yet. Didn't you test it before releasing it?
    Ohh, come on Sayzer, don't be to pessimistic! 8-)
    Mar 2005
    Novi Sad, Vojvodina
    Thanks Darrel.
    Emil
    kezuke's Avatar
    kezuke Guest
    Talking
    thank you very much!!!
    Default OK now my post
    This is great stuff no doubt, it should be a suggestion to improve the PBP compiler in the future, i am sure we all had this nibble problem before.
    But it is not backwards compatible is it? all of my previous code will be impossible to compile with this change, am i wrong?
    Is it impossible to ask for backwards compatibility? Some magic from the magician please ;D.
    Being completely ignorant about this: IF LCD_E is not defined then use original LCDOUT command else use DTs version. (Most surely not possible )
    An obviuos solution is to have a whole new folder for the PBP modified and one for the original PBP, but in the end it will tend to give trouble, i am almost sure. I know i can handle it but this could be really dangerous code for newbies.
    Just my thought
    Again, thanks a lot DT
    DJC
    Jan 2006
    Istanbul
    Quote Originally Posted by Darrel Taylor who scattered the pins of the LCD data bus across multiple ports with PicBasic Pro succesfully
     NOLIST
    DUNN_USED = 1
    PAUSEUS_USED = 1
    I just realized that in my file, it is
    DONE_USED = 1
    Then they must sell a different version in Turkey.
    Because it's definitely DUNN_USED = 1 here
    Jan 2006
    Istanbul
    Darrel,
    There is nothing like "DUNN" in the file.
    Here is a piece from the code.
            movlw   LCD_DATAUS	; Wait for data operation to complete
            call    PAUSEUS
            bsf     STATUS, C       ; Set no timeout for Serout2mod
      NOLIST
    DONE_USED = 1
    PAUSEUS_USED = 1
    ;*            : W data type                                     *
    ;* Notes      :                                                 *
        ifdef LOOK2_USED
      LIST
    LOOK2   iorlw   0               ; Check for constant
            btfsc   STATUS, Z
            goto    DONE            ; Constant so all set
            movwf   R4              ; Save type
            movf    R0, W           ; Set FSR for translate
            movwf   FSR             ; Put address in FSR
            btfsc   R0 + 1, 0       ; Long address?
            bsf     STATUS, IRP     ; Yes
            clrf    R0              ; Clear the result
            clrf    R0 + 1
            btfsc   R4, 7           ; Check type
            goto    look2bit        ; Bit type
            movf    INDF, W         ; Get low byte of data
            movwf   R0              ; Store it
            btfss   R4, 1           ; Byte or word?
            goto    DONE            ; Byte
            incf    FSR, F          ; Point to high byte
            movf    INDF, W         ; Word - get high byte
            movwf   R0 + 1          ; Store high byte
            goto    DONE
    look2bit call   CONVBIT         ; Change bit to mask
            andwf   INDF,W          ; Isolate bit
            btfss   STATUS, Z       ; Bit / no bit?
            incf    R0, F           ; Bit
            goto    DONE
      NOLIST
    CONVBIT_USED = 1
    DONE_USED = 1
    So instead of DUNN_USED = 1, I have DONE_USED = 1.
    Anyone else has the same?
    I can confirm what Sayzer is saying...
    Just randomly picking PBPPIC14.LIB from my PBP2.46 there is no DUNN_USED but DONE_USED...
    however...
    PBPPIC18.LIB does have DUNN_USED...
    So my British version is mid-way between Darrels American version, and Sayzers Turkish version... yup... about right on the Atlas too... so Alain will have a greater probability of being DONE than DUNN, and Ioannis and Luciano will almost certainly be DONE at sometime...
    Talking The tree hiding the forrest ...
    Hi, Mel
    I've "DONE" in Pbpic14.lib and "DUNN" in Pbpic18.lib ...
    just like you !
    Buuuuuut ... is it really important ??? ( LOL ...); if I understood Darrel ... It's just to show the place where to include a piece of code.
    What ??? I did say something stupid ??? ... I apologize, then ! Acoording to Khomeiny Ayatollah ( and Sayzer ! ) ... What's the cost ?
    Nov 2009
    Default Noob alert!
    I hate to sound like a noob (but I am) so here goes....
    I needed to do exactly this in a project, move the LCD data bus to different pins that is, I did the edit, saved the files (yes w/backup) and placed the example snippet of code into my BAS file.
    When I compile I'm getting this error:
    Error: unable to execute mpasmwin.Error[113]
    "symbol not previously defined (_LCD_DATAUS)"
    "symbol not previously defined (_LCD_COMMANDUS)"
    if I remove the lines:
    LCD_DB4 VAR PORTB.5
    LCD_DB5 VAR PORTB.4
    LCD_DB6 VAR PORTB.3
    LCD_DB7 VAR PORTB.2
    LCD_RS VAR PORTB.7
    LCD_E VAR PORTB.6
    it compiles (assembles?) w/o error. I can't find _LCD_DATAUS or _LCD_COMMANDUS in any readable files in my PBP folder.
    also if I leave those lines in, and just rem the INCLUDE "LCD_AnyPin.pbp" it compiles fine.
    (it's a 16F883 I'm working with on PBP 2.6)
    LCD_DATAUS and LCD_COMMANDUS are constants that you must declare in your program. Shown in the first post of this thread.
    They are not optional.
    Nov 2009
    I'm sorry, I should have posted a code snippet for you to see, I already did define them, is a "declaration" different that this?:
    ; Define LCD registers and bits
    DEFINE LCD_DREG PORTB ;
    DEFINE LCD_DBIT 4 ;
    DEFINE LCD_RSREG PORTB ;
    DEFINE LCD_RSBIT 0 ;
    DEFINE LCD_EREG PORTB ;
    DEFINE LCD_EBIT 1 ;
    DEFINE LCD_COMMANDUS 2000   ; Set command delay time in uS
    DEFINE LCD_DATAUS 50        ; Set data delay time in uS
    DEFINE LCD_BITS 4           ; Set LCD buss size (4-bit or 8-bit)
    DEFINE LCD_LINES 2          ; Set number of lines on LCD
    LCD_DB4   VAR PORTB.5
    LCD_DB5   VAR PORTB.4
    LCD_DB6   VAR PORTB.3
    LCD_DB7   VAR PORTB.2
    LCD_RS    VAR PORTB.7
    LCD_E     VAR PORTB.6
    ;INCLUDE "LCD_AnyPin.pbp"    ; this include MUST be AFTER LCD Pin assignments
    I tried this in PBP 2.46 and it does compile, but my MPLAB chokes because of some file missing or unsupported (COD file I think)
    Go back up to the first post and take another look at the highlighted code example.
    There are no DEFINEs, only VAR and CON.
    It must be exactly as shown (except for the actual pins used).
    Don't improvise or over think it. Just copy/paste and modify for your pins.
    Nov 2009
    I must have some other issue at hand then if it's really that simple.
    Just for the sake of it I created a new project with the following minimal code, it still fails:
    (again MPLAB v8.40, PBP v2.60, PIC16F883)
    CLEAR                        ; standard opening move
    ;DEFINE OSC 4                ; set oscillator speed
    LCD_DB4   VAR PORTB.5
    LCD_DB5   VAR PORTB.4
    LCD_DB6   VAR PORTB.3
    LCD_DB7   VAR PORTB.2
    LCD_RS    VAR PORTB.7
    LCD_E     VAR PORTB.6
    PAUSE 500
    TRISA = %11111111
    TRISB = %00000000
    ADCON1=%00000111
    DO
    loop:
          LCDOUT $FE, 1
          PAUSE 250
          LCDOUT "Hello"
          LCDOUT $FE, $C0
          LCDOUT "World"
          PAUSE 250
    ...and this is my output spew:
    Executing: "D:\PBP\PBPMPLAB.BAT" -ampasmwin -k# -p16F883 "Untitled.bas"
    Executing: "D:\PBP\PBPW.EXE" -ampasmwin -k# -p16F883 "Untitled.bas"
    PICBASIC PRO(TM) Compiler 2.60, (c) 1998, 2009 microEngineering Labs, Inc.
    All Rights Reserved.
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    mpasmwin /o- "D:\PIC Projects\Untitled.ASM"
    ERROR: Unable to execute mpasmwin.Error[113] D:\PIC PROJECTS\UNTITLED.ASM 244 : Symbol not previously defined (_LCD_DATAUS)
    Error[113] D:\PIC PROJECTS\UNTITLED.ASM 244 : Symbol not previously defined (_LCD_COMMANDUS)
    Halting build on first failure as requested.
    BUILD FAILED: Sat Nov 14 14:08:14 2009
    Sorry to bother you about this, and than you for taking the time to replay to my posts. Pardon me as I'm a noob to PIC programming and have not developed any intuition with this environment yet.
    If this code indeed works for you, as shown, it should work for me but isn't.
    (yet)
    Woohoo!
    Nice work Guido!
    I copied your post to the LCD's with Shift Registers, and LCDOUT thread too.
    Oct 2010
    Default thanks
    Thanks Darrel for the "nice work", but i would like to thanks for the outstanding base you did.
    Best regards.
    Guido
    Woohoo!
    Nice work Guido!
    Hi, Darrel
    as " LCD on anypin " was ... not intended for 8 pins Pic 12 series
    But now, as only two pins are needded ...
    is "LCD on anypin" compatible with PBPPIC12.lib .... ???
    I had a look at the Library and NOPE ...
    No way to do it on a chip with only 2 stack levels (12-bit core).
    There are several other 8-pin pics with 14-bit cores. 12F629, 675, 683 ...
    It'll work fine on those.
    Hi, Darrel
    thanks for the point.
    So, ... in this case THIS would be a solution to test, avoiding the " Backpacks"
    http://www.romanblack.com/shift1.htm
    That's pretty neat.
    But with the new PIC's costing $1 or less, and could do a full 8-bit interface on a back-pack with an internal OSC.
    That one seems pretty expensive with all the extra parts.
