Time & Simulation
Results 1 to 2 of 2
    Jul 2007
    Grass Valley CA
    Question Time & Simulation
    Two questions from a nooby ...
    1. How can I either estimate (and a rectorandom estimate is fine) or measure how long it takes my program to execute a loop? That is, if I'm looking at a dozen ports to see if a switch is thrown and then do some other stuff, how do I figure out how often each port will be sampled to see if the switch has been activated?
    2. Is there a program or routine where I can load my program and "build" a circuit (complete with processor, switches, lights, resistors, capacitors, perhaps peripheral memory...) and watch what happens when I press this or that switch?
    Jim
    Several possibilities.
    • Use MPLAB's MPSIM simulator, and use the built in "Stopwatch" to measure the time.<br><br>
    • Toggle an output pin on each loop and use an oscilloscope to measure the time.<br><br>
    • or, try this program...<br>
      Instruction Execution Time
      http://www.picbasic.co.uk/forum/showthread.php?t=365
  1. I don't understand this code!
    Last Post: - 13th February 2008, 02:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 23:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 13:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 14:24
