Code: Why is this code greater than 2000 words?
Results 1 to 10 of 10
    May 2007
    Default Code: Why is this code greater than 2000 words?
    Hi Guys,
    I am new to PICs and picbasic pro, and an using a PIC 16F628a. I have a program up and running, but I seem to have run out of space on my PIC. The 628 has a 2000 word limit, and it seems that my compiled code exceeds that. I don't quite understand what in the code amounts to one word of data. Is it possible to take a peek at my code and see what is taking up so much space, am I doing something wrong, or is this normal for the commands I am using?
    Right know I have commented out several blocks of code that use the pulsout command to generate a pwm signal to move a servo. I have commented them so that the code remains below 2000 words. With those blocks it grows to roughly 2300 words.
    I appreciate the help,
    Andreas
    Actually, it compile 1808 word here. if you need to use PULSOUT often , just create a subroutine(or macro) and pass the parameters in. But frankly... Pulsout is nothing more than
    High
    PAUSEUS xxxx
    Low
    you could still upgrade to a 16F88 or 16F648A
    Also, apply the same rule to every code you use 2,3,4,5 times such as this section
    RawCompass = (A_Curve - LowLimit) * Scale
    Compass = ((RawCompass/10) * 4) /10
    Heading = Compass + 1800
    if Heading  > ActuateOn and Heading  < ActuateOff then
    high PortB.4
    In Section A, B ,C, D. Sure there's some variant between them, but sure you can reduce the whole thing.
    May 2007
    yes, it compiles at 1800 now because I commented out the sections that deal with servo control. So the best method of reducing the size is to create subroutines for repeated code blocks?
    Wink Think simple ...
    Hi, Andreas
    A little thing ... you use a 4Mhz crystal ...
    no use, then, to keep WORDS for pulse length : result always will be between 50 and 250 ... so BYTES will fit.
    Will save much room ( and time ) in the calculation part !!!
    But if you want to use 20 Mhz crystal ... you have to keep the WORDS.
    T.Jackson's Avatar
    T.Jackson Guest
    Post "Reuse-ability"
    The term "reuse-ability" springs to mind. For example, you could create a routine for PULSOUT and pass allocated variables to it, resulting in just one instance of the PULSOUT (this will certainly save space)
    GOSUB Do_Pulse
    Do_Pulse:
       PULSOUT IO_Pin, Duration
    <lu>
    <li> Just declare IO_Pin and duration as variables that are specific to the purpose.</li>
    </lu>
    Wink Nice flight stabilizer...
    just missing ref. to a twin axis gyroscope sensor ... IDG 300 ???
    << if Ratio < 100 And Ratio > 0 then ... >>
    other room to save : Ratio is ALWAYS > 0 ( Coz. PbP only works with POSITIVE INTEGERS !!! ) ...
    << Alpha = Ratio*11 + 732*10 >>
    Why not directly write " Alpha = Ratio*11 + 7320 "
    saves one 16x16 multiplication !!!
    Was just some examples ...
    Here the multiple used math is more revealant than Pulsout Itself. Yeah i still refer to the same method to measure the code size... let's see
    <font color="#000080">@ __CONFIG  _INTRC_OSC_NOCLKOUT &amp; _MCLRE_ON  &amp;  _LVP_OFF &amp; _WDT_OFF &amp; _PWRTE_ON  &amp; _BODEN_ON
        </font>PORTB=0
        TRISB=0
        Led1    <font color="#000080">VAR </font>PORTB.0
        Led2    <font color="#000080">VAR </font>PORTB.1
        Led3    <font color="#000080">VAR </font>PORTB.2
        Led4    <font color="#000080">VAR </font>PORTB.3
        Led5    <font color="#000080">VAR </font>PORTB.4
        Led6    <font color="#000080">VAR </font>PORTB.5
        Led7    <font color="#000080">VAR </font>PORTB.6
        Led8    <font color="#000080">VAR </font>PORTB.7
        ByteA   <font color="#000080">VAR BYTE
        </font>ByteB   <font color="#000080">VAR BYTE
        </font>Worda   <font color="#000080">VAR WORD
        </font>PORT    <font color="#000080">VAR BYTE
        </font>DURATION <font color="#000080">VAR WORD
        GOTO </font>Start
        <font color="#000080">ASM
    HOGSTART MACRO
    BLOCKSTART=$
        ENDM
    HOGEND  MACRO BLOCKNAME
    BLOCKNAME = $-BLOCKSTART
        ENDM
    CUSTOM_PULSOUT MACRO PORT, PIN, DURATION, BYTEA
        PULSOUT?TC PORT,PIN,DURATION
        MOVE?CB BYTEA,_ByteA
        L?CALL _DO_CALC
        ENDM
    </font>DO_CALC:
        ByteB=50+ByteA
        Worda=(ByteA+ByteB)*100
        <font color="#000080">RETURN
    </font>Start:
        @   HOGSTART
        <font color="#000080">PULSOUT  </font>Led1,10000
        ByteA=10
        ByteB=50 + ByteA
        <font color="#000080">PULSOUT  </font>Led2,10000
        ByteA=20
        ByteB=50 + ByteA
        <font color="#000080">PULSOUT  </font>Led3,10000
        ByteA=30
        ByteB=50 + ByteA
        <font color="#000080">PULSOUT  </font>Led4,10000
        ByteA=40
        ByteB=50 + ByteA
        @   HOGEND ____MULTIPLEPULSOUT
            HOGSTART
            CUSTOM_PULSOUT _Led1,10000,10
            CUSTOM_PULSOUT _Led2,10000,20
            CUSTOM_PULSOUT _Led3,10000,30
            CUSTOM_PULSOUT _Led4,10000,40
            HOGEND ____MACRO_CUSTOM_PULSOUT
    </font>SPIN: <font color="#000080">GOTO </font>SPIN
    Compile this with MPASM, and open the according .LST file... and discover that...
    Quote Originally Posted by ...LST file
    SYMBOL TABLE
    LABEL VALUE
    ____MACRO_CUSTOM_PULSOUT 0000002C
    ____MULTIPLEPULSOUT 00000074
    2c=44 decimal
    74=116 Decimal
    here the simple macro and sub call will use 116/44=~2.6 time less code and make the code MUCH MORE readable... at least to me.. case not.. hum, hum, just fart in Darrel's direction
    How handy they are
    Quote Originally Posted by DrDreas View Post
    Just had a look, how about some of this:
    Combine math in this chunk of code if possible:
    Alpha=Ratio*51 + 532*10
    Alpha=Alpha/10
    Instead of /2, use >> 1 (shift right by one bit = divide by 2), example:
    if Alpha < (ServoArc/2) then.......becomes:
    if Alpha < ( ServoArc >> 1 ) then
    Same thing with any multiply or divide by a power of two, use a shift << for multiply, shift >> for divide
    Like Ace said, combine your subroutines a bit:
    SectionA:
    RawCompass=(UpLimit - A_Curve) * Scale: gosub FIXCOMPASS
    Compass=((RawCompass/10) << 2) /10
    Heading=Compass
    GOSUB SUBSECTION1
    GOSUB SUBSECTION2
    GoTO Mainloop ' Do it indefinitely
    SectionB:
    RawCompass=(B_Curve - LowLimit) * Scale : gosub FIXCOMPASS
    CrossZero=Compass + 2700
    if CrossZero >= 3600 then SectionBA
    Heading=CrossZero
    GOSUB SUBSECTION1
    GOSUB SUBSECTION2 (and so on, but the rest aren't boldfaced for emphasis)
    SectionBA: ZeroCross=CrossZero -3600 :Heading=ZeroCross
    GOSUB SUBSECTION1
    GOSUB SUBSECTION2
    SectionC:
    RawCompass=0:RawCompass=(UpLimit - B_Curve) * Scale
    gosub FIXCOMPASS : Heading=Compass + 900
    GOSUB SUBSECTION1
    GOSUB SUBSECTION2
    SectionD:
    RawCompass=(A_Curve - LowLimit) * Scale : gosub FIXCOMPASS
    Heading=Compass + 1800
    GOSUB SUBSECTION1
    GOSUB SUBSECTION2
    Calibrate: IF A_Curve > 2048 THEN UpLimit=A_Curve ' Establish the actual upper limit
    If A_Curve < 2048 THEN LowLimit=A_Curve ' Establish the actual lower limit
    Spread=9000 / (UpLimit - LowLimit):Scale=(Spread * 10) >> 2:Return
    SUBSECTION1:
    high PortB.4: pulseWidth=2000:lowTime=20000 - pulsewidth:Low Servo
    Pulsout Servo, pulseWidth/10:Pauseus lowTime
    SUBSECTION2:
    LOW PortB.4: pulseWidth=1500:lowTime=20000 - pulsewidth:Low Servo
    FIXCOMPASS:
    That might get your program on the chip. There's a couple of other optimizations relating to Bank'ing your variables, but that's a bit of an advanced subject. If the program still doesn't fit, re-post what you've got...maybe more optimizations will get 'er in there.
  1. Manchester coding/decoding Code help
    By financecatalyst in forum Code Examples
    Last Post: - 25th August 2009, 19:05
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
