How to calculate ADC resolution (pic12f683)
Results 1 to 7 of 7
    Feb 2005
    Question How to calculate ADC resolution (pic12f683)
    I have a doubt: how can I calculate the maximum detail I can get from an ADC reading.
    In my case I have these parameters:
    Vcc: 4v
    Lower value to be read: 1.90v
    Higher value to be read: 2.10v
    How many different values can I read between these levels using the pic12f683 ?
    Thanks in advance!
    Quote Originally Posted by peu View Post
    Vcc: 4v
    Thanks in advance!
    All of them...
    Feb 2005
    WOW, that was fast, you were looking over my shoulders?
    maybe I didn't used the right words to formulate my question, what would be the resolution?
    1.9001, 1.901 or 1.91? or how many steps.
    I don't know how to calculate this. Thanks!
    Vcc: 4v
    Thanks in advance!
    Well, let's see....
    Vcc = 4v
    Vdd = 0v
    Difference between Vcc and Vdd = 4v
    PIC12F683 has a 10 bit A/D converter, 1024 possible values to read between 0 and 4v.
    1.9v - 2.1v = .2v
    4v maximum value / 1024 = 3.90625mv/bit
    Therefore,
    .2v = 200mv
    200mv / 3.90625 = 51.2
    So, you can read 51.2 values between 1.9 and 2.1 volts.
    How 'bout that math...
    OR....
    You could set VRef to 2.2v...
    2.2v maximum value / 1024 = 2.1484375mv/bit
    Therefore,
    .2v = 200mv
    200mv / 2.1484375 = 93.09
    If you had a VRef of 2.2v, you could read 93.09 values between your limits...
    Feb 2005
    AHA! that was the info I was after, thanks again skimask.
    So, after reading the datasheet I see that I can set the internal Vref for this purpose, but I dont understand something, from the datasheet:
    VRR = 1 (Low Range): CVREF = (VR3:VR0/24) x VDD
    VRR = 0 (High Range): CVREF = (VDD/4) + (VR3:VR0 X VDD/32)
    So in my example, if I set VR3:0 say at 1101 I get these values:
    VRR=1 2.167v
    VRR=0 2.625v
    or if I use VR3:0 at 1001 I get these
    VRR=1 1.5v
    VRR=0 2.125v
    So what should I use, VRR=1 or 0 ?
    VR=9, VRR=0
    Closest to 2.1v without going under...
    Feb 2005
    Smile
    Thanks skimask for your fast and accurate replies!
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 02:18
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 15:33
  3. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 15:54
  4. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 01:55
  5. High resolution ADC
    By vsingh in forum mel PIC BASIC Pro
    Last Post: - 29th April 2004, 18:53
