16F876A ADC write and read?
Results 1 to 9 of 9
    Apr 2007
    Unhappy 16F876A ADC write and read?
    I've never used an ADC function on a PIC, and am fairly inexperienced with PIC's compared to you guys,
    My question is, does anyone have a sample of code that defines and configures an ADC input, does a read, writes that variable to a place in memory, and is read some time later?
    Thank you in advance
    Jim-
    Quote Originally Posted by clem View Post
    Jim-
    ADC Input configuring and reading - fine example in the little green book
    EEPROM writing - little green book
    EEPROM reading - little green book
    So, what I am eluding to here, is that there is a lot of good information in the little green book.
    So, read the book, write some code and try to make it work the way you want it to.
    If and when that code doesn't work, we here in the forums will be more than happy to help you figure out why it doesn't work.
    Apr 2007
    Default the little green book
    I read the little green book and it is'nt very intuitive.
    here is the code... I keep getting a output must be a variable error message
    at ADCIN PORTA.0, 0
    PULSE VAR PORTC.2
    RL1 VAR PORTC.1
    RL2 VAR PORTC.0
    HEATIN VAR PORTA.1
    SENSIN VAR PORTA.0
    ADCON1 = 0011 'Declare A ports 0 & 1 as Analog to dig converters
    ADCON1.7 = 1 'Analog to Digital variables declared right justified
    TRISA = 255
    DEFINE ADC_BITS 10
    DEFINE ADC_SAMPLEUS 5
    loop_delay CON 500 ' adjust to tweak timing
    ms_count VAR WORD
    loop:
    FOR ms_count = 0 TO 999 ' 0 to 999mS
    IF ms_count < 14 THEN ' PULSE low 0 to 13 mS
    low PULSE
    ELSE ' PULSE and RL1 high at 14
    high PULSE
    high RL1
    high RL2
    IF MS_count > 8 THEN ' RL1 low at 9 mS
    high RL2
    IF ms_count > 995 THEN ' RL2 low at 995 mS, high at 0
    low RL1
    IF ms_count = 997 THEN ' Read PORTA.0 ADC VALUE put in mem loc 0
    ADCIN PORTA.0, 0
    PAUSEUS loop_delay ' fill in time for 1mS loop
    NEXT ms_count
    goto loop
    What do you think?
    Read the ADCIN section again, 5.2.
    ADCIN PORTA.0, 0
    Where's the variable?
    Apr 2007
    Default I'm still lost
    Do I have to set aside specific memory locations?
    Do I have to declare specific variables?
    The book states:
    ADCIN channel, Var
    I'm still lost
    The book states:
    ADCIN channel, Var
    I'm still lost
    Did you read section 5.2?
    You are using the command ADCIN, which reads the specific ADC channel, which is connected to a certain pin. This value which is read is put into a specifica variable. You aren't using a variable in your code, you haven't specified a place to put it. You are using variables in other spots...so why not here?
    How much PIC programming have you done so far? LED blinky? Anything like that?
    Apr 2007
    Default None
    Sorry this is my first time.
    But I did figure it out,
    thank you for the help
    Jim-
    Jim-
    If you're starting off with ADCIN type commands, you might want to back up a bit and play around some with some LEDs and some buttons first. Get the basics down. Dig in too deep and too hard right off the get go, and you're setting yourself up for headaches in the future.
    Just my thoughts on the process...
    Apr 2007
    Default Thanks
    Thanks for the advice...much appreciated
    Jim-
  1. READ WRITE not working consistantly on 12f675
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 19th September 2009, 16:15
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 13:06
  3. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. Write Read And Words
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 30th March 2004, 23:27
