Numbers
Results 1 to 12 of 12
Thread: Numbers
    Exclamation Numbers
    Anyone Know A Way To Include Dec Numbers
    Such As 1.2 4.3 Or Any With Decimal Points
    Pbp Seems To Dislike Fraction Numbers
    How To Incorporate This Type Of Number?
    May 2006
    Del Rio, TX, USA
    Something to ponder. For the most part, the decimal point is arbitrary. If you are going to work with numbers limited to the range of 0.0 thru 6553.5, just use a WORD type variable, forget about the decimal point, and when a human will read it, plop a "." between the 1st and 2nd digits (counting from the right). It's a simplistic explaination, but hopefully you get the point and can extrapolate from there. More "accuracy", you are limited to 0.00 thru 655.35.
    Beyound that, there are FP routines that you can get from MeLabs website. Knock yourself out!
    SteveB
    Jan 2006
    Istanbul
    jcleaver,
    As SteveB says, you can go around it as below.
    Say you have to divide 6 by 5.
    6/5= 1.2
    In PBP, you will get the result as (1).
    Result = 1
    But there is something called "remainder". You can check this in manual.
    Then you can hold the remainder (2) in another variable.
    Floating = 2
    Then you can put them together or collect them in a single variable.
    If it is only for display purposes then the job is easier.
    Default ?
    thanks for the responce however i was not clear enough
    i am trying to divide a number by a fraction number
    1000/7.5 as a example pbp gives error on the 7.5 or any number with a decimal point
    thanks
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by jcleaver View Post
    thanks
    Then take your numbers, multiply them by 10 beforehand to get rid of the decimal point, do the division, then divide them by 10 afterwards.
    PBP does NOT deal with any sort of fractions at all. PBP only deals with straight INTEGERs, whole numbers, no floating points, no decimal points, no halves, no quarters, no tenths, no nothing.
    PBP runs on a PIC. A PIC is a microcontroller. A microcontroller runs by 'interpreting' (for lack of a better word) binary code. Binary numbers, base 2 numbering, no matter which language you are dealing with, only have states; 1 and 0, on and off, up or down, left or right, yes or no, true or false, voltage or no voltage, positive or negative, day or night, open or shut, and so on...
    There is no 1/2 on, 1/2 up, 3/4 left, partially true, a little voltage, somewhat positive, almost day, 1/2 way open...etc. To do any of these would introduce something that the binary numbering system doesn't not have; a decimal point.
    Can you create a decimal point? Sure, in a way. If you couldn't, your PC couldn't handle math, you couldn't calculate pi, do any trig, etc.
    I could go on and on...but now I'm bored and somebody can probably pick up the conversation from here...
    Talking wow
    thanks ski\
    great reply probably more info than i can absorb
    but you hit the nail on the head
    skimask's Avatar
    skimask Guest
    thanks ski
    I actually tried to drill in the info nice and gentle this time (for a change ).
    Feb 2005
    Kolkata-India
    Default Anybody seen the ocean ?
    I am mentioning Floating Point.
    Sougata
    Cool ok
    where is info on using this in pbp manual or others
    thanks
    Info on using Microchips FP routines with PBP is available here:
    http://www.melabs.com/resources/fp.htm
    /Henrik Olsson.
    Smile thanks all
    thank everybody for there help
    great answers
    skimask's Avatar
    skimask Guest
    thanks
    And yet again...no floating point in PBP. All math that PBP can handle is mentioned in the manual. No decimal points, no fractions, no halves, no thirds, no tenths, no hundreths, no nothing. Just whole numbers.
  1. Working with 3 byte numbers
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 22:59
  2. Splitting numbers and recombining them(EEPROM Error)
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2007, 06:40
  3. Returning whole numbers for DS1820?
    Last Post: - 12th February 2007, 12:15
  4. Multiplying large numbers
    By jhonea1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2006, 17:41
  5. Storing numbers for caller ID?
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 28th March 2005, 10:27
