877A AtoD config problem?
Results 1 to 3 of 3
    Mar 2007
    Default 877A AtoD config problem?
    Using the X1-demo board and a 877A chip. All I want to do is config portA so I can use the pins, An2, An4 An5 to read the voltage from and accelerometer. I started with the A2D8.bas demo code and all works to read pin An2, the problem happens when I try to config the A/D port config control bits from:
    ANDCON1 = %1000 0010 ' An0-An4 configed for Analog Input
    to
    ANDCON1 = %1000 0000 ' An0-An7 configed for Analog Input
    or
    ANDCON1 = %1000 1001 ' An0-An5 configed for Analog Input
    I'm only trying to read An2 but ,my display is not showing anything but sometimes flashes, any ideas?
    oh, ADCON0 is:
    ADCON0 = %11010001 ' Configure and turn on A/D Module
    thanks
    t
    Seems simple, really just use
    Feb 2005
    Kolkata-India
    Question I am surprised that your program is compiling!
    Quote Originally Posted by ttease View Post
    to
    or
    oh, ADCON0 is:
    thanks
    t
    You also need to set your data direction register TRISA as inputs and disable the comparator. Although the POR values should do, it is better to configure manually.
    Sougata
    Mar 2007
    Default Solved..
    Thanks for the reply, I only included the code I figured might be giving me the problem. My Bad!
    After re-reading the correct DS, I figued out that RA4 cannot be configured as an Analog Input.
    I'm using the 877A to prototype some code that will run on a P18F4431. All pins on Port A of the 4431 can be Analogs, so I figured.....
    Note to self:RTCFDS- Read the correct F* data sheet!
    thanks
    t
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
