Code Protection
Results 1 to 12 of 12
Thread: Code Protection
    Jan 2007
    Exclamation 12C508A code protect problem
    Hi All,
    I programmed a 12C508a chip and wrote code in configuration to protect the code. I programmed it with EPIC Programmer Ver2.44 and also set the code protection to all in options menu.
    The chip is programmed but not protected. When I Read data in EPIC Programmer, it reads the chip and by menu View code it show the contents of the program in Hex format.
    Why it does not protect the chip? Any help in the problem???
    Shahzad
    Quote Originally Posted by thetrueman View Post
    Are you sure you didn't set them to ALL OFF?
    Jan 2007
    Default 12C508A Code Protection
    Yes while programming at the top of code I confing Code Protect ON and while downloading to chip, in the EPIC programmer software options menu I set Code protection to ALL.
    I just read this chip with ALL-100 Universal Programmer and it reads the chip 12C508A. So how to protect the code to be invisible to others???
    Sep 2007
    USA, CA
    Some programmers have a setting to read the config in the hex file or not... maybe your programmer is using default settings.
    Hi, Thetrueman
    1) could you show us your config settings ( from the program AND read from the chip ).
    2) now ... keep cool, but the C series chips are really easy to " crack" ...
    Hi Alain. I doubt that he still has the code. Its been ... 2 years now!
    Were you having any of the fine French wines?
    Please do sent me a bottle!
    Hi, Ioannis,
    You're perfectly righ ...
    I begin to open the 1989 - 90 vintages ... really nice !!!
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  2. Loop with two motor and 2 sensors
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  5. Can't remove code protection of 16F88!!!
    Last Post: - 22nd December 2006, 13:18
