ok eee, seems to be working now, am I awake....
thank you thank you
i will try the wireless
what is this line for (was for , or intended to)
'templo = converts[templo] : temphi = converts[temphi]
thank you thank you
Well, what program are you running right now? I changed some stuff and was about to post it...but if you say it's working correctly at both ends, then I'll go with that.... So, repost the program you're running now (if it works), so I can remember what the line above did.
using post 118
it works wireless,
does it have to do with the encoding technique ?
but most often its showing good temp.
could I add a 10v voltage regulator for the RF transmitter to boost up the signal ? I am using the rentron 433mhz chips tws
Glitches - Probably has to do with the encoding technique because the data isn't encoded (I commented that part out in post #118), but the 'training' bytes are encoded.
Maybe try to add a few more $55 to the serout line in the transmit section. And make sure the char_pacing isn't in the define sections anymore.
If you're running the module at 5v now, you're good for about 500ft (that's what I've gotten at 9600 a few times, a few errors, but it still worked). and if you read the datasheet, you'll see that you have to run your data input line to the TX module at the same voltage range as your power input.
I've ran that TX module at 2.5v before and gotten 100ft without troubles.
I di dwhat you told me removing the char_spac adding more $55, its worst now,
its constantly showing 360, 445, and sometime the temperature
more often 445
Well, I would think that taking out the char_pacing and adding $55 would help it, but apparently not since none of the data is being encoded, the receiver is picking the $55 up as actual data or something.
Try it the other way around, but do one thing at a time.
1) No char_pacing - a single $55, no $55 (which should not work!)
2) no char_pacing - two $55's
3) no char_pacing - 4 $55's
4) small char_pacing - single $55 (I would think that any char_pacing value above 4000 would mess things up bad enough not to work at all)
etc.
See which one works out the best...
OR....
you could add you manchester encoding routine back into the program (from way back when, ya know, page 1!!!) and see what happens.
I added DEFINE CHAR_PACING 2000
also 1000 works good with four $55
But it seems to be long to change the temperature, sometime the receiver seems to hang there with its value.
HI, ok
I learned a lot in these four pages of posts,
What i did now I took the original program and modified it (serin, definnes, $55 , $aa ...
it works great now
I got a couple of glitches when I took the reciever down in the basement ( one floor below in a zig zag)
if you would like to see the code i could post it,
Those temp sensors aren't designed to respond to temp changes RIGHT NOW. If they did, they'd be all over the place. Remember, you have a certain amount of mass that you have to heat or cool and it takes X amount of time to do that, especially buried down in the middle of the blob of goo where the sensing element actually is. Fill a glass with ice cubes, fill the rest of the glass with water, let it sit for a bit, then dip the sensor in the water. It should read just a hair over, if not right on 0C/32F. You can add a bit of calibration by doing that. I don't think I'd try the boiling water for the other end though!
well here goes,
I still need to do work, because I dont think it measures negatives temperature. Not sure yet how i am going to do it, but I will be
Transmitter:
'TRANSMIT PIC
INCLUDE "modedefs.bas"
DEFINE OSC 20 'use external 20mhz crystal
CMCON = 7 : ANSEL = 0 : ADCON1 = 7
DEFINE LCD_DREG PORTA ' Set LCD Data port
DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 0 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DQ var PortB.4
temp var word
temperature var word
count_remain var byte
count_per_c var byte
counter var byte
tempc var word
dataout var word
dataout2 var word
datain var word
array var word
encoded1 var word
encoded2 var word
encoded22 var word
encoded11 var word
loop:
owout DQ,1,[$cc]
owout DQ,0,[$44]
Pause 500
owout DQ,1,[$cc]
owout DQ,0,[$be]
owin DQ, 0, [temperature.LOwBYTE, temperature.Highbyte, Skip 4, count_remain, count_per_c]
'50
temperature = ((( temperature >> 1) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
tempc = (((temperature *9) / 5)+3200)
dataout = temperature / 100
dataout2 = temperature
encoded1 =temperature.LowBYTE
encoded2 =temperature.HighBYTE
For counter=0 TO 7
IF encoded1.0[counter]=0 Then
encoded11.0[counter*2]=0
encoded11.0[counter*2+1]=1
Else
encoded11.0[counter*2]=1
encoded11.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
IF encoded2.0[counter]=0 Then
encoded22.0[counter*2]=0
encoded22.0[counter*2+1]=1
Else
encoded22.0[counter*2]=1
encoded22.0[counter*2+1]=0
EndIF
Next counter
lcdout $FE,1
LCDOUT "TempC: ", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
lcdout $FE,$C0, bin encoded11.HighBYTE , ".", bin encoded2," ",$DF,"F"
serout portb.2, n2400, [$55, $55, $55, $55, $aa]
serout portb.2, n2400, [encoded22.HighBYTE, encoded22.LowBYTE, encoded11.HighBYTE, encoded11.LowBYTE ]
goto loop
Receiver:
'RECEIVE PIC
'16
datain2 var word :temp var word
datain var word
dataout var word
counter var byte
encoded1 var word
encoded2 var word
encoded11 var word
encoded22 var word
pause 2000
'28
loop:
waitfor55:
serin portb.2 , n2400 , temp : if temp <> $55 then goto waitfor55
waitforaa:
serin portb.2 , n2400 , temp : if temp <> $aa then goto waitforaa
'36
serin portb.2, n2400, encoded22.HighBYTE
serin portb.2, n2400, encoded22.LowBYTE
serin portb.2, n2400, encoded11.HighBYTE
serin portb.2, n2400, encoded11.LowBYTE
For counter=0 TO 7 'decoding
encoded1.0[counter]=encoded11.0[counter*2]
encoded2.0[counter]=encoded22.0[counter*2]
Next counter
temperature= encoded1 ' putting back together as the original temperature
For counter=0 TO 7
temperature.0[counter+8]=encoded2.0[counter+8]
Next counter
temperature.LowBYTE = encoded1
temperature.HighBYTE = encoded2
lcdout $FE,1
goto loop
Looks good enough. As far as handling the negative numbers, I'd do all the math at the receiving end, that way you can preserve the sign bit and work with it there rather than try to worry about how to transmit the sign bit along with the real temperature and screwing it up in the process.
The negative temperature is nothing more than using 2's complement math. Google it, re-read the -1820 datasheet. It's not that hard to handle those cases. It just takes a bit of creative math to work it out. And PBP can handle it if you work it right (hint: re-read the PBP manual, the SEROUT can handle 'signed' integers, make that work for you in the receiver code).
hi, I have this simple if then statement, it givs me four mistakes.. It tells me I need and endif and also its abad expression , this is straight out of the pbp manual. what is wrong with it
IF temperature.bit11 = 1 Then zerotemp
zerotemp
program here
naa, i was initializing zerotemp dee.
I am going to put the calculation on the receiver side only, this is getting real confusing.
The reason i did not want to do that is I am sending 4 byte of coded information. I want to have a high accuracy, so i would like to send the count_per_c and count_remain and in the data sheet. that will add more bytes, If I take the raw information and send it, it will be 4 bytes or 8 encoded byte to send. Is this do able ?
I mean is it too much to send wireles ?
k
anywau here si the code fo the sending part:
i am just worried about the two serout line, should I put it into one line, or is it just the same like this,
I am leaving now, coming back ina few hours
'TRANSMIT PIC
DQ var PortB.5
temp var word
counter var byte
encoded1 var word
encoded2 var word
encoded22 var word
encoded11 var word
encoded33 var word
encoded44 var word
loop:
owout DQ,1,[$cc]
owout DQ,0,[$44]
Pause 500
owout DQ,1,[$cc]
owout DQ,0,[$be]
'50
For counter=0 TO 7
Else
EndIF
Next counter
For counter=0 TO 7
Else
EndIF
Next counter
For counter=0 TO 7
IF count_remain.0[counter]=0 Then
encoded33.0[counter*2]=0
encoded33.0[counter*2+1]=1
Else
encoded33.0[counter*2]=1
encoded33.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
IF count_per_c.0[counter]=0 Then
encoded44.0[counter*2]=0
encoded44.0[counter*2+1]=1
Else
encoded44.0[counter*2]=1
encoded44.0[counter*2+1]=0
EndIF
Next counter
lcdout $FE,1
lcdout $FE,$C0, bin count_remain , ".", bin count_per_c," ",$DF,"F"
serout portb.2, n2400, [encoded11.HighBYTE, encoded11.LowBYTE, encoded22.HighBYTE, encoded22.LowBYTE ]
serout portb.2, n2400, [encoded33.HighBYTE, encoded33.LowBYTE, encoded44.HighBYTE, encoded44.LowBYTE ]
goto loop
I send strings and strings of data using the TWS/RWS modules without much problem at all. Of course I get messed up data once in awhile, that's what error detection is for (checksums, etc.). 4/8 bytes is fine...1000 bytes is fine. It's all in how you want to send it, break it down, detect errors, etc. Just create and use LEDAWDTP (lerameur's error detection and wireless data transfer protocol).
I agree...send only the raw information, then do the math at the receiver end, again, with some error correction. For instance, you get one reading, save it placeA and display it...you get the next reading, save it in placeB. If the placeB reading is higher than placeA, then increment placeA by one, same thing is it's lower, decrement it by one. That way, a one-time reading that's 'out in the weeds' because of bad data won't neccessarily show up on the output as a fluctuating result.
Now that the whole thing is working, you can probably condense those serout lines down into one line...try it and find out...
That and it makes the program shorter on the screen so you don't have to scroll thru so much stuff...
'TRANSMIT PIC
DQ var PortB.5 : temp var word : temperature var word : count_remain var byte : count_per_c var byte : counter var byte
encoded1 var word:encoded2 var word:encoded22 var word:encoded11 var word:encoded33 var word:encoded44 var word
loop:
owout DQ,1,[$cc] : owout DQ,0,[$44] : Pause 500 : owout DQ,1,[$cc] : owout DQ,0,[$be]
'50
encoded1 =temperature.LowBYTE : encoded2 =temperature.HighBYTE
'I'd put these encoding/decoding sections into their own subroutine to GOSUB to...
For counter=0 TO 7
encoded11.0[counter*2]=0 : encoded11.0[counter*2+1]=1
Else
encoded11.0[counter*2]=1 : encoded11.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
encoded22.0[counter*2]=0 : encoded22.0[counter*2+1]=1
Else
encoded22.0[counter*2]=1 : encoded22.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
encoded33.0[counter*2]=0 : encoded33.0[counter*2+1]=1
Else
encoded33.0[counter*2]=1 : encoded33.0[counter*2+1]=0
EndIF
Next counter
For counter=0 TO 7
encoded44.0[counter*2]=0 : encoded44.0[counter*2+1]=1
Else
encoded44.0[counter*2]=1 : encoded44.0[counter*2+1]=0
EndIF
Next counter
lcdout $FE,1 : LCDOUT "TempC: ", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
serout portb.2, n2400,[$55,$55,$55,$55,$aa,encoded11.HighBYTE,encoded11.L owBYTE,encoded22.HighBYTE]
serout portb.2, n2400,[encoded22.LowBYTE,encoded33.HighBYTE,encoded33.Low BYTE,encoded44.HighBYTE]
serout portb.2, n2400,[encoded44.LowBYTE]
goto loop
OK, I must be getting lucky, I'm not getting many mistakes as before. The system works now, the sending code is good. The receiving is good for positive celcius, For some undetermined reason it is not giving the right Ferenheit degrees, and I am using the same math equation as before to translate from C to F.
I am now working on the negative celcius and also in that scenatio there is two cases, positive and negative F ...
I will the subroutine for later, I never touched it before so I will do it at the end once everything is working
'RECEIVE PIC
counter var byte : temperature var word : encoded1 var word : encoded2 var word : encoded3 var byte
encoded11 var word : encoded22 var word : encoded33 var word : encoded44 var word : encoded4 var byte
count_remain var byte : count_per_c var byte : temp var byte : tempc var byte
pause 2000
loop:
'23
waitfor55:
waitforaa:
serin portb.2, n2400, encoded11.HighBYTE : serin portb.2, n2400, encoded11.LowBYTE
serin portb.2, n2400, encoded22.HighBYTE : serin portb.2, n2400, encoded22.LowBYTE
serin portb.2, n2400, encoded33.HighBYTE : serin portb.2, n2400, encoded33.LowBYTE
serin portb.2, n2400, encoded44.HighBYTE : serin portb.2, n2400, encoded44.LowBYTE
encoded1.0[counter]=encoded11.0[counter*2] : encoded2.0[counter]=encoded22.0[counter*2]
encoded3.0[counter]=encoded33.0[counter*2] : encoded4.0[counter]=encoded44.0[counter*2]
Next counter
'41
For counter=0 TO 7
Next counter
count_remain = encoded3
count_per_c = encoded4
IF temperature.11 = 1 Then goto Zerotemp
lcdout $FE,1, "TempC: ", "+", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
lcdout $FE,$C0, "TempF: ", dec (tempc / 100) , ".", dec2 tempc >> 1," ",$DF,"F"
goto loop
Zerotemp:
temperature = temperature >> 1 'removing lowest bit
for counter=0 to 14 ' 2's compliment, starting to invert all the digits
if temperature.0[counter] = 1 then temperature.0[counter] =1
if temperature.0[counter] = 0 then temperature.0[counter] =0
next counter
temperature = temperature + 1 ' 2,s compliment ends by adding a one
lcdout $FE,1, "TempC: ", "-", dec (temperature / 100) , ".", dec2 temperature," ",$DF,"C"
goto loop
for one thing, tempc should be tempf shouldn't it?
Another thing, if your temp value (which I assume is multiplied by 100 by that conversion/correction thing you've got going on) is above 7281, you'll overflow your 16 bit tempc value (65536 / 9 = 7281.xxx). So try dividing by 5 first, then multiply by 9.
tempc = ( ( ( temperature / 5 ) * 9 ) + 3200 )
another thing...what are you trying to do with the lcdout line?
lcdout $FE,$C0,"TempF:",dec (tempc/100),".",dec2 tempc >>1," ",$DF,"F"
I think what you really mean is:
lcdout $fe,$c0,"TempF:",DEC3 (tempc/100),".",DEC2 (tempc//100)," ",$DF,"F"
use the remainder (modulus) ( // ) function, not the shift ( >> ) function.
its working good, now, I think I have a problem with the 2,s compliment, working on it
I am just doing 2,s compliment, I get all 1,s at the output
Zerotemp:
temperature1 = temperature
for counter=0 to 6 ' 2's compliment, starting to invert all the digits
if temperature.0[counter] = 1 then temperature.0[counter] =0
if temperature.0[counter] = 0 then temperature.0[counter] =1
next counter
'temperature = temperature + 1 ' 2,s compliment ends by adding a one
'temperature = ((( temperature >> 1) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
'tempc = (((temperature *9) / 5) + 3200)
lcdout $FE,1, "TempC: ", bin temperature1, ".", dec2 temperature," ",$DF,"C"
lcdout $FE,$C0, "TempF: ", bin temperature , ".", dec2 (tempF // 100)," ",$DF,"F"
goto loop
I just flip these around and it works
Zerotemp:
------------------------------------------why are you removing the lowest bit?
next counter
------------------------------------this will never work....follow it thru
1. if temp.counter = 1 then set it to 0
2. if it's zero set it to 1.....it just got set to zero by the above line!!!!!
what you want is:
for counter = 0 to 6
or just use this:
temperature = ~ temperature (bitwise inversion)
goto loop
And you didn't change the temperature to doing the /5 first, and then the *9. If you leave it the way you've got it, you'll get an overflow when it gets really warm outside!
when it get to ZERO, it shows 655,
then when it reach about -3 then it shows the right temp, weird..
any idea?
See my post above referring to your post #114...your logic above is flawed also
(temperature.0[counter] - just call it temp for right now)
if temp is zero, set it to one. then go to the next line down
if temp is one, set it to zero. again, it just got set to 1 on the line above!
its all good now, exept foe that part between 0 to -5 degrees celcius,
There is no grey area, if the bit 11 os 1, then goto zerotemp, the math is the same for -1 C or -10C....
'RECEIVE PIC
count_remain var byte : count_per_c var byte : temp var word : tempc var byte : tempF var word
temperature1 var word
pause 2000
loop:
'23
waitfor55:
waitforaa:
Next counter
'41
For counter=0 TO 7
Next counter
tempF = (((temperature /5) *9 ) + 3200)
lcdout $FE,$C0, "TempF: ", "+", dec2 (tempF / 100) , ".", dec2 (tempF // 100)," ",$DF,"F"
goto loop
Zerotemp: ' cases when zero celcius and positive Fahrenheit
next counter
temp = temp + 1 ' 2,s compliment ends by adding a one
temp = temp >> 5
temperature = ((( temp ) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
tempF = 3200 -((temperature /5) * 9)
if tempF = 0 then goto ZeroF
lcdout $FE,$C0, "TempF: ", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
goto loop
ZeroF: ' cases when zero celcius and 0 Fahrenheit
lcdout $FE,$C0, "TempF: ", "-", dec (tempF / 100) , ".", dec2 tempF ," ",$DF,"F"
goto loop
You do realize that 0C is not 0F right?
0C = 32F
0F = -17.78C
Maybe it would be easier (if you really need to display both C and F) if you'd convert your initial celsius reading from the serin statements over to the Kelvin scale (0C = 273K, 0K = -273C), add in the correction factors, and then convert them back, taking into account the + and - as needed right before displaying the final numbers
And all based from the celsius value....
1) if tempC > 0 then both C and F are positive
2) if tempC => -17 and tempC <=0 then C is negative, F is positive
3) if tempC < -17 then both C and F are negative
or in Kelvin terms...
1) if tempK > 273 then C/F +
2) if tempK => 256 and tempK <=273 then C- and F+
3) if tempK < 256 then C/F -
yes exactly, that,s what i meant, I omitted the numerical degrees.
I believe this is what I have in my program.
One glitch is that when is hits ZERO, it immediatly shows -5C, the conversion from C to F is good (making conversion from -5 to 23F) BUt it is not getting the right values between 0 to -5 C
Well, this might be a bug...or not...the tempC to tempF conversion is done differently in the 2 spots...and so are the lines above that...2 different methods... Shouldn't everything be the same except for the display?
I'm not sure, you're doing it a bit different than I would do it... maybe it's one of those 'features' like Windows always has in it that Microsoft fixes every Tuesday
I made these formulas and tested them on a calculator. it works. I dont know hy it do not work on the pogram I wrote.
So
--- SO if I need to do the conversion : -17C to 1.4F
so I take 1700 (17 *100) put it in the formula (temperature) I get 140, just divide by 100 to get the answer..
k
next counter
------------------------------------temp value right here not set up
temp = temp >> 5
goto loop
goto loop
Where is the first temp getting set at? I don't think it is. I think it's always $ab (left over $aa from the serin with 1 added).
I just got up, looked at the program , wow , a mess I did yesterday....
I have to go be back working on it this afternoon.
ok I changed it a bit, but it is still getting confused about the zero mark.
stll showing +655.XX celcius
another thing, the decimal values are going the opposite way in the negative ,
meaning, -1.96 to -1.90 instead of -1.90 to -1.96
I have dec2 temperature for the decimal I tried
1- dec2 temperature but it do not work ...
loop:
'23
waitfor55:
waitforaa:
Next counter
'41
For counter=0 TO 7
Next counter
goto loop
Zerotemp: '------------- cases when zero celcius and positive Fahrenheit
temperature = ~temperature +1
'63
temperature = ((( temperature >>1 ) *100)- 25) + (((count_per_c - count_remain) * 100) / count_per_c)
if tempF <= 0 then goto ZeroF
goto loop
ZeroF: '---------------- cases when zero celcius and 0 Fahrenheit
goto loop
So, I can assume that the positive temperature readings are all correct?
Why are the 2nd and 3rd temp conversion formula's different from the 1st?
t = 3200 - *5 / 9 instead of t = T*5/9 + 3200 (shortened, you know what they are)
temperature = ( ~temperature ) + 1 try that also
loop:
'23
waitfor55:
waitforaa:
Next counter
'41
For counter=0 TO 7
Next counter
goto loop
'temperature = ( ~ temperature ) + 1 ----- do this later, right before displaying it
'63
tempF = ((temperature /5) * 9) + 3200
temperature = ( ~ temperature ) + 1 : tempf = ( ~ tempF ) + 1 ' added this
goto loop
goto loop
Try that....
I just did an edit... You might have to do the correction/conversion/calculation before you do the 2's complement conversion. I've modified the program for that.
Last edited by skimask; - 29th December 2006 at 22:01. Reason: Changed program again!
Found this at Rentron's site:
'* Name : Temp.BAS *
'* Author : Bruce Reynolds *
'* Notice : Copyright (c) 2003 Reynolds Electronics *
'* : All Rights Reserved *
'* Date : 7/28/2003 *
'* Version : 1.0 *
'* Notes : *
DEFINE osc 20 ' We're using a 20MHz oscillator
Comm_Pin VAR PortC.0 ' One-wire Data-Pin "DQ" on PortC.0
Busy VAR BIT ' Busy Status-Bit
R_Temp VAR WORD ' RAW Temperature readings
TempC VAR WORD ' Temp in deg C
TempF VAR WORD ' Temp in deg F
Float VAR WORD ' Holds remainder for + temp C display
Cold_Bit VAR R_Temp.Bit11' Sign-Bit for +/- Temp. 1 = Below 0 deg C
Real_Cold CON 1 ' Define Real_Cold = 1
BAUD CON 16468 ' N9600 for serial LCD
DISP VAR PortB.0 ' Pin to drive serial LCD
Deg CON 223 ' Data to display Deg ° symbol
CLR CON 1 ' CLR LCD command
LINE1 CON 128 ' LCD line #1
LINE2 CON 192 ' LCD line #2
LINE3 CON 148 ' LCD line #3
LINE4 CON 212 ' LCD line #4
INS CON 254 ' LCD command mode parameter
Sign VAR BYTE ' +/- sign for temp display
Dummy VAR BYTE ' Dummy for Div32
SEROUT2 DISP,BAUD, [INS,CLR]
Start_Convert:
OWOUT Comm_Pin, 1, [$CC, $44]' Skip ROM search & do temp conversion
Wait_Up:
OWIN Comm_Pin, 4, [Busy] ' Read busy-bit
IF Busy = 0 THEN Wait_Up ' Still busy..?, Wait_Up..!
OWOUT Comm_Pin, 1, [$CC, $BE]' Skip ROM search & read scratchpad memory
OWIN Comm_Pin, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]' Read two bytes / end comms
GOSUB Convert_Temp
GOTO Start_Convert
Convert_Temp: ' +32.0 to +257 F
IF Cold_Bit = Real_Cold THEN Yikes ' If Cold_Bit = 1, it's below "0" deg C
Sign = "+"
Dummy = 625 * R_Temp ' Multiply to load internal registers with 32-bit value
TempC = DIV32 10 ' Use Div32 value to calculate precise deg C
Dummy = 1125 * R_Temp
TempF = DIV32 100
IF TempF >6795 THEN ' Over 99.5 deg F..?
TempF = TempF + 3200
SEROUT2 DISP,BAUD, [INS,LINE1, " TempF = ",Sign,DEC TempF DIG 4,_
DEC TempF DIG 3,DEC TempF DIG 2,".",DEC2 TempF,Deg,"F "]
SEROUT2 DISP,BAUD, [INS,LINE1, " TempF = ",Sign,DEC TempF DIG 3,_
TempC = (R_Temp & $0FF0) >> 4 ' Mask middle 8-bits, shift into lower byte
Float = ((R_Temp.Lowbyte & $0F) * 625) ' Lower 4-bits of result * 625
SEROUT2 DISP,BAUD, [INS,LINE2, " TempC = ",Sign,DEC TempC,".",DEC Float,Deg,"C "]
SEROUT2 DISP,BAUD, [INS,LINE4, "Raw", IBIN16 R_Temp]
Yikes: ' Display full range -C to -F conversion
Sign = "-" ' Display - symbol for negative temp
Dummy = 625 * ~R_Temp+1' Multiply to load internal registers with 32-bit value
TempF = ~R_Temp / 16 ' Begin conversion from -C to deg +/-F
IF TempF >=18 THEN ' Check for -degrees F "-18 C = -0.4 F"
TempF = ((((TempF + 50) * 9) /5) -122) ' -C to -F below -17 deg C
SEROUT2 DISP,BAUD, [INS,LINE1, " TempF = ",Sign, DEC TempF,Deg,"F "]
SEROUT2 DISP,BAUD, [INS,LINE2, " TempC = ",Sign,DEC TempC DIG 4,_
DEC TempC DIG 3,".",DEC3 TempC,Deg,"C "]
ELSE ' Else result = +deg F
TempF = ((((-TempF + 50) * 9) /5) -58)' -C to +F below 32.0 deg F to -17 deg C
SEROUT2 DISP,BAUD, [INS,LINE1, " TempF = ","+",DEC TempF,Deg,"F "]
Might get some good ideas from here on how to do the job efficiently.
