Plldiv...
Results 1 to 2 of 2
Thread: Plldiv...
    Post Plldiv...
    Hello everybody... I am trying to make some USB communication and thereŽs something IŽd like to know.... I use these lines on my 18F4550.INC file: (this post is more about the configuration in this file than usb communication)
    CONFIG FOSC = HS ;I am using a 12 MHz xtal, do I need the HSPLL_HS
    ;option for the usb communication?
    CONFIG USBDIV = 2 ; USB clock source comes from the 96MHz PLL
    CONFIG PLLDIV = 3 ; If usbdiv = 2 and my xtal is 12 MHz then is this line requiered? if not, what does this line do exactly?
    if usbdiv = 2 then the usb clock source will be the pll always no matter what the fosc configuration is??
    Thanks to all!
    Best Regards.
    Armando Herjim.
    P.D. Is the word "requiered" well written?
    mmmpffmmppffm i'll try to explain this one.
    The PLLDIV factor is the one you need to reduce the external OSC to 4MHZ. Yes the internal OSC will always work @4MHZ and raise it to 96MHZ... later
    In your cas 12MHZ external /4MHZ internal = PLLDIV should be 3.. you have it good
    USBDIV/2 will be the PIC OSC SPEED. in this case 48MHZ.
    i could be wrong... but i think it's 'required' or 'needed'
    Francais un jour, francais toujours
  1. PICBasic newbie problem
    By ELCouz in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 01:55
