2 PWM output
Results 1 to 4 of 4
Thread: 2 PWM output
    Md.Shah's Avatar
    Md.Shah Guest
    Default 2 PWM output
    What is the code to generate 2 PWM output for PIC16F877A. the second output is inverted with the first output.
    Jun 2005
    Wisconsin
    I'm using the 16F876A, which is similar and I just used the following two commands. I'm not sure what you mean by inverted.
    HPwm 1,value,2000
    HPwm 2,value,2000
    Jun 2005
    Wisconsin
    So this is a double post. One or the other should be removed. (I don't like double posts)
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  2. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
