Hello all
I'm working on a way to monitor a quadrature encoder feeding back to a VFD to independantly verify that the drive and motor have decelerated when commanded to do so. My program, below, compiles but then I get the follow-wing error message "error decel~1.asm 96: [226] numeric constant or symbol name expected" as an assembler error. How do I find where my error is? I can't find anything in the manual or on the list.
any help is appreciated.
Take care
Alec
'* Name : decel_check.pbp *
'* Author : Alec Noble *
'* Notice : Copyright (c) 2006 Alec Noble *
'* : All Rights Reserved *
'* Date : 7/11/2006 *
'* Version : 1.0 *
'* Notes : pic 16F628a *
DEFINE OSC 4 ' Set the Xtal frequency to 4mHz
@ device pic16f628a, INTRC_OSC_NOCLKOUT,
' ** Declare LCDOUT Defines **
DEFINE LCD_DREG PortB ' Set Data to PortB
DEFINE LCD_DBIT 4 ' Set starting Data to Bit4
DEFINE LCD_RSREG PortB ' Set Register Select to PortB
DEFINE LCD_RSBIT 2 ' Set RS line to PORTB.2
DEFINE LCD_EREG PortB ' Set Enable to PortB
DEFINE LCD_EBIT 3 ' Set Enable line to PortB.3
DEFINE LCD_BITS 4 ' Set for 4 bit Bus
DEFINE LCD_LINES 4 ' Set number of lines to 2
Define LCD_DATAUS 50 ' Data Delay (uS)
' ** Define LCD Control Constants **
I Con 254 ' Control Byte
Clr Con 1 ' Clear the display
Line1 Con 128 ' Point to beginning of line 1
Line2 Con 192 ' Point to beginning of line 2
Line3 Con 148 ' Point to beginning of line 3
Line4 Con 212 ' Point to beginning of line 4
Cgram Con 64 ' Point to Cgram within LCD
Shift_L Con 24 ' Shift display left
Shift_R Con 28 ' Shift display right
' ** Declare I/O **
up_btn var portb.0
dn_btn var portb.1
entr_btn var porta.4
A var porta.0
A_ var porta.1
B var porta.2
B_ var porta.3
relay1 var porta.6
relay2 var porta.7
' ** Declare the Variables **
RPM var word 'Motor rpm
setpoint1 var word
setpoint2 var word
freq var word
ppr var word 'encoder pulse/rev
ppr_index var byte 'index to make setting ppr easier
' ** initialize variables from RAM **
read 0, ppr_index
read 2, setpoint1.byte0
read 3, setpoint1.byte1
read 4, setpoint2.byte0
read 5, setpoint2.byte1
' ** initialize variables **
RPM = 0
freq = 0
PPR = 0
' ** initialize ouputs **
relay1 = 0
relay2 = 0
' ** Set Registers **
cmcon = 7
trisb = %00000011 'port b pins 0 and 1 input, 2 - 7 output
trisa = %00111111 'port a pins 0 - 5 input, 6 and 7 output
' ** enable LCD display **
pause 500 'allow lcd to wake up
lcdout I, CLR 'clear lcd
pause 50
gosub banner 'toot my own horn - what the hell...
' ** Program starts here **
if entr_btn = 0 then gosub configure
lookup ppr_index,[4,8,16,32,64,128], ppr
ppr = ppr * 16 'convert ppr_index lookup value to encoder ppr
count A, 1000, freq 'read pulses from encoder for 1000 ms
RPM = 60 * (freq / ppr) 'convert pulses/sec into RPM
if rpm < setpoint1 then 'compare rpm to setpoint 1
relay1 = 1 'if rpm less than setpoint energize relay 1
relay1 = 0 'if rpm greater than setpoint 1 turn relay 1 off
if RPM < setpoint2 then 'compare rpm to setpoint 2
relay2 = 1 'if rpm less than sepoint2 energize relay 2
relay2 = 0 'if rpm greater than setpoint2 turn relay 2 off
lcdout I, line1, "DECEL CHECK"
lcdout I, Line2, "RPM = ", dec4 rpm 'display current rpm
if rpm<setpoint1 then
lcdout I, line3, dec4 setpoint1, " relay1 on" 'display setpoint1, indicate relay 1 on
lcdout I, line3, dec4 setpoint1, " relay1 off" 'display setpoint1, indicate relay 1 off
if rpm<setpoint2 then
lcdout i,line4, dec4 setpoint2, " relay2 on" 'display setpoint2, indicate relay 2 on
lcdout I, line4, dec4 setpoint2, " relay2 off" 'display setpoint2, indicate relay 2 off
goto main 'do it again, and again, and again...
' ** subroutines **
Configure: 'routine to set ppr and rpm setpoints
pause 10 'debounce
if entr_btn = 1 then main
pause 2000 'make sure enter button pushed for more than 2 seconds
while entr_btn = 0 :wend 'wait until enter button released
gosub set_ppr
gosub set_setpoint1
gosub set_setpoint2
set_ppr:
for ppr_index = 0 to 5 'allow ppr_index to have values of 0 - 5
lookup ppr_index, [4, 8, 16, 32, 64, 128], ppr'lookup ppr
ppr = ppr * 16
lcdout i, clr,I, line1, "PPR = ", dec4 ppr 'display ppr
loop1:
if entr_btn = 0 then pause 20'debounce enter button
if entr_btn = 0 then getout1 'if enter button pressed get out of loop
if up_btn = 1 then loop1 'stay in waiting loop until a button is pressed
while up_btn = 0 :wend 'wait for up_btn to be released
next ppr_index 'go to next ppr valu
getout1:
while entr_btn = 0 :wend 'wait for enter button to be released
write 0, ppr_index 'write set value of ppr to rom
set_setpoint1:
lcdout i, clr,I, line1, "setpoint1 = ", dec4 setpoint1 'display setpoint1
if entr_btn = 0 then pause 20 'debounce enter button
write 2, setpoint1.byte0
write 3, setpoint1.byte1
if up_btn = 0 then setpoint1 = setpoint1 + 10 'increment if up button pressed
if dn_btn = 0 then setpoint1 = setpoint1 - 10 'decrement if down button pressed
goto set_setpoint1
set_setpoint2:
lcdout i, clr,I, line1, "setpoint2 = ", dec4 setpoint2 'display setpoint2
while entr_btn = 0 :wend 'wait for enter button to be relaesed
write 4, setpoint2.byte0
write 5, setpoint2.byte1
if up_btn = 0 then setpoint2 = setpoint2 + 10 'increment if up button pressed
if dn_btn = 0 then setpoint2 = setpoint2 - 10 'decrement if down button pressed
goto set_setpoint2
Banner:
lcdout i, clr, i, line1, "decelcheck mod"
lcdout i, line2, "by alec noble"
lcdout I, line3, "firmware rev0"
lcdout i, line4, "hardware rev0"
pause 10000
