Help with sending text file from pic
Results 1 to 7 of 7
    brighton
    Question Help with sending text file from pic
    Hello
    i just need to draw on your expert advice on this problem that i have got.
    i am trying to use my pic18f452 to communicate with a device that accepts text files to activate a test.
    when i send say C1 with CR ,LF from hyperterminal there is no responce but
    if i save C1 with CR,LF as a file and use send text file from hyperterminal
    this works ok.
    Is there a way i can do this with the pic ?
    At present i send it with Hserout["C1",10,13]
    What am i doing wrong here
    Isaac
    Jun 2005
    Wisconsin
    Try Hserout[$C1,10,13]
    This Sends Decimal 193,10,13
    Hserout["C1",10,13]
    This Sends Decimal 67,49,10,13
    Hi Isaac,
    In Hyperterminal, goto
    File | Properties | Settings Tab |ASCII Setup
    and check the "Send line ends with line feeds" checkbox.
    brighton
    Thumbs up
    Thanks Darrel
    Your advice did the trick
    Isaac
    Docw's Avatar
    Docw Guest
    Default Sending text within quotes e.g. "xxxx" within a string
    Is it possible to send a string that has text within quotation marks in a string using the SEROUT command ? I seem to get an error and I need to use this feature to send commands to an external color LCD panel. (BTW, I'm new at PicBasic).
    Sure can,
    The ascii code for double quotes is 34. So you can do this...
    SEROUT Pin, Mode, [34,"some text here",34]
    Docw's Avatar
    Docw Guest
    Thank you !!! That approach had never occurred to me.
  1. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  2. Best way to store text in a pic
    By atwoz in forum General
    Last Post: - 6th December 2007, 14:50
  3. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 18:31
  4. Need help on pic to pic flow control (simple problem I think)
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 00:34
  5. Help, problems first time with 18F452 PIC
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 20:49
