Dear Gurus,
Below is the code I am using to build a wireless data transfer, I started by building a wired connection and it worked very fine but once I go wireless nothing works.
Any idea, hint, help is greatly appreciated.
Mankan
'* Name : Receiver.BAS *
'* Notice : Copyright (c) 2006 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 5/10/2006 *
'* Version : 1.0 *
'* Notes : *
INCLUDE "modedefs.bas"
'@DEVICE PIC16F628, WDT_ON
'@DEVICE PIC16F628, BOD_ON
'@DEVICE PIC16F628, PROTECT_OFF
'@DEVICE PIC16F628, MCLR_ON
DEFINE NO_CLRWDT
'* Variable declarations
Header var BYTE
Counter VAR BYTE
Packet VAR BYTE
End_Of_Data VAR BYTE
counterA VAR BYTE
ErrorFlag var bit
MyData var byte
ManchesterWord Var WORD
Temp_Byte var byte[5]
Temp_Word var WORD[5]
x VAR BYTE
send_word VAR WORD
SYNCH VAR byte
SYNCH=$C6
CMCON = 7
VRCON = 0
TRISB.1 = 1
INPUT PORTB.1
PORTB.1 = 1
pause 10
Loop:
Header = 0
HIGH PORTB.6
'SERIN PORTB.1,N300,[SYNCH],Header,Counter,Packet,End_Of_Data
'SERIN PORTB.1,N300,[SYNCH],ManchesterWord.lowbyte,ManchesterWord.highbyte
SERIN PORTB.1,N300,[SYNCH],send_word.lowbyte,send_word.highbyte
Temp_Word[0] = send_word
For x=1 to 4
SERIN PORTB.1,N300,300,Loop,send_word.lowbyte,send_word. highbyte
Temp_Word[x] = send_word
next x
for x=0 to 4
ManchesterWord = Temp_Word[x]
GOSUB DecodeManchester
Temp_Byte[x] = MyData
next x
Low PORTB.6
Header = Temp_Byte[0]
PAUSE 100
if Header = 96 THEN
gosub GLOW_PIN7
if Counter = 2 Then
gosub glow_pass
goto loop
TimeOut:
call GLOW_TIMEOUT
goto loop
GLOW_PASS:
HIGH PORTB.5
PAUSE 50
LOW PORTB.5
PAUSE 50
GLOW_PIN7:
HIGH PORTB.7
PAUSE 50
LOW PORTB.7
PAUSE 50
GLOW_TIMEOUT:
HIGH PORTB.6
PAUSE 500
LOW PORTB.6
PAUSE 500
DecodeManchester:
ErrorFlag=0
For counterA=0 to 7
if ManchesterWord.1=0 then
MyData.7=0
If ManchesterWord.0=0 then ErrorFlag=1
MyData.7=1
If ManchesterWord.0=1 then ErrorFlag=1
ManchesterWord=ManchesterWord>>2
if counterA<7 then MyData=MyData>>1
next counterA
/**********END OF Receiver*********************/
/**********Start of Transmitter*********************/
'* Name : Transmitter.BAS *
'* Date : 5/2/2006 *
'* Version : 1.0 *
'* Notes : *
DEFINE NO_CLRWDT
CMCON = 7
VRCON = 0
TRISB.2 = 0
Header VAR BYTE
End_Of_Data con 24
SYNCH VAR byte
SYNCH=$C6
Counter VAR BYTE
Packet VAR BYTE
counterA VAR BYTE
MyData var byte
x VAR BYTE
send_word VAR WORD
Header = 96
pause 10
OUTPUT PORTB.2
PORTB.2 = 0
OUTPUT PORTB.4
PORTB.4 = 0
OUTPUT PORTB.5
PORTB.5 = 0
Counter = 2
Packet = 78
Temp_Byte[0] = 96
Temp_Byte[1] = 16
Temp_Byte[2] = 26
Temp_Byte[3] = 36
Temp_Byte[4] = 46
start:
MyData = Header
for x=0 to 4
MyData = Temp_Byte[x]
gosub EncodeManchester
Temp_Word[x] = ManchesterWord
nEXT X
'SEROUT PORTB.2,N300,[126, SYNCH,Header, Counter, Packet, End_Of_Data]
'SEROUT PORTB.2,N300,[126, SYNCH,ManchesterWord.lowbyte, ManchesterWord.highbyte]
SEROUT PORTB.2,N300,[1263, SYNCH]
for x=0 to 4
send_word = Temp_Word[x]
PAUSE 1
SEROUT PORTB.2,N300,[send_word.lowbyte, send_word.highbyte]
next x
CALL GLOW_LED
goto Start
GLOW_LED:
HIGH PORTB.5
PAUSE 50
LOW PORTB.5
PAUSE 50
EncodeManchester:
ManchesterWord = 0
for counterA=0 to 7
if MyData.0 = 0 then
ManchesterWord.14=1
ManchesterWord.15=1
if CounterA<7 then ManchesterWord = ManchesterWord>>2
MyData=MyData>>1
Next CounterA
/************END OF TX****************/
