40Mhz
Results 1 to 2 of 2
Thread: 40Mhz
    Smile 40Mhz
    Hello everybody!!
    Does anybody know if the Pic 18F4550 works with a 40 Mhz crystal in HS mode?? If not, does anybody has a hint??
    Thanks to all of you.
    Apr 2006
    New Hampshire USA
    Smile The PIC18F4550
    Hi Armando,
    I haven't used the PIC18F4550, yet.
    Take a look at this thread:
    http://www.picbasic.co.uk/forum/showthread.php?t=4086
    Quote Originally Posted by Bruce
    Is this a 40MHz crystal (I.E. one requiring parallel caps) or is it a 40MHz TTL
    clock oscillator?
    Above 25MHz, you'll need a TTL type clock oscillator. HS and HSPLL support
    up to 25MHz primary osc.
    Make sure you have the latest verion of the 4550 data sheet rev DS39632C
    and look in the electrical characteristics section at table 28-8, parameter 1A.
    With a 40MHz TTL type clock oscillator, and EC or ECIO oscillator modes, it
    should work fine.
    CONFIG PLLDIV=10,CPUDIV=OSC1_PLL2,USBDIV=2,FOSC=ECIO_EC
    -Adam-
  1. Replies: 23
    Last Post: - 23rd September 2008, 18:20
  2. Cannot compile for 40MHz 4 x pll
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 21st October 2007, 17:50
  3. Replies: 0
    Last Post: - 5th September 2007, 12:25
  4. SERIN2 @ 38400 @ 40mhz
    Last Post: - 29th January 2007, 05:49
  5. 16F876 : settings for 40Mhz
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 11th April 2005, 16:36
