What is the best way to make forward reverse
Results 1 to 5 of 5
    Default What is the best way to make forward reverse
    I'm currently developing a robot powered by two motors. I connect the motors to a driver to pin c1 and c2 (for forward) and c3 and c4 (for reverse) of PIC 16F877A. I try move left and right. When I move left, I need to make left move reverse and right motor forward. How I can do that using HPWM or PWM? I found that HPWM only support forward because it only has 2 channel.
    <code>
    hpwm 1, 100, 1000
    hpwm 2, 100, 1000
    </code>
    When I try using PWM, only the last line is executed.
    <code>
    pwm portc.1, 100, 100 'forward right
    pwm portc.4, 100, 100 'reverse left
    </code>
    why only last line is executed?
    What is the best way to make forward reverse using hpwm or pwm. TQ
    Default reverse direction
    In most cases, you use the PWM only to supply the speed of the motor, not the direction. If you use something like a L298 dual H-bridge to drive your motors and look after polarity reversal, you're all set.
    ------------Picster------------
    Actually I already used that driver. I told in the first post of this thread that I connect to the motors through a driver to the PIC port c1, c2, c3 and c4. I just need to progam forward reverse using hpwm or pwm.
    Wink think simple ...
    Hi, guanerr ...
    Just have a look to new PICs with the Enhanceded PWM module ...
    they can drive by soft all types of output bridges !!! reverse is also here !!!
    see 16F 684 i.e.
    But I already installed with 16F877A. I don't wanna waste my time and money. I think there must be a solution.
  1. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 17:25
  2. PBP is driving me crazy trying to make an 18F chip blink
    By George in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 06:08
  3. NEWB Help HPWM coding
    By Seafurymike in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 21:52
  4. How come they make electronics hard as poss
    By George in forum Off Topic
    Last Post: - 13th July 2007, 23:54
  5. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
