Using Nokia LCD - Page 7
Page 7 of 8 FirstFirst ... 345678 LastLast
Results 241 to 280 of 301
Thread: Using Nokia LCD
  1. #241
    Default Re: Using Nokia LCD
    Out of curiosity, which PIC didn't worked for you?
  2. #242
    Hi Steve
    I was using the 16F88
    Oct 2010
    i was trying to use pic16f628a.
    I have seen over the internet some others they succeed with pic12f629
  4. #244
    it could even work with a 10F, but probably not with PBP as it consume too much RAM, but that's another story
  5. #245
    varunksr's Avatar
    varunksr Guest
    hi
    can anyone please send info regarding interfacing the nokia 6610 display with 8051..
  6. #246
    You're probably out of luck on a Microchip PIC oriented forum like here, but
    http://www.google.ca/search?q=nokia+...w=1366&bih=596
    then
    http://www.lcdinterfacing.info/Nokia...-Interface.php
  7. #247
    Oct 2010
    Hi Steve,
    i'm looking forward to see the new driver.
    I have 5 of the Nokia 5110 and i would like to play with them.
    I'm sure you did a good work.
  8. #248
    You can work with them right now, everything here work as long as you're aware of some Macro limitations. Which PIC do you plan to use ???
    BTW, I'll take no credits, all the job have been done here and well done. I just put some of my spices in, some user configurables settings and some ease of use. It will be like my Keypad routine.
    Still working on the final touch, code optimisation, documentation, some code example, basic schematics... fun job.
  9. #249
    Quote Originally Posted by astanapane View Post
    Note to self, always read previous posts sorry 'bout that...
  10. #250
    Hi Steve,
    you are right about being able to using it except of some Macro limitations.
    It works like a charm with the 16F88 microcontroller IF i dont use the "@ PrintStr x,y, "string goes here"" . But...IF i use that i get the truncated errors.
    That's because the macro use DATA, you want to jump on the DA or DT asm instruction
  12. #252
    Oct 2010
    Hi Steve,
    are you going to share the new Nokia 3310 and 5110 driver with us the following days?
    thanks
  13. #253
    Do you want to be a beta tester or a happy user?
    Trust Steve that he will post a good piece of working code when he decides it is ready. Besides being on different time zone.
  14. #254
    Oct 2010
    Ioannis,
    i can wait as long as it needs to be ready.
    thanks
  15. #255
    I have it working, no problem, I just always find some features to add in, and/or way to use it. Yes it will works on almost everything. 12f629 is enough with PBP... but damn, dont'expect being able to show a lot of string and embedded pictures with a so RAM/EEPROM underpowered device Still doable to add some eeprom to it, but WHY?!? Too much new 8 pin device with much more horse power under the hood for the same price.
    The magic is at compilation time... hidden but there. The "driver" know which method to use to store/retrieve the strings out of the code space... OR EEPROM if you want.
    Some PIC allow to read/write to their code space (PIC16F88, 877 and so forth), some don't (16F628, 12F629...)... and then you have the PIC18. 3 different method, one driver deciding for you. Sick! I learned a lot out of it... again.
    Sure there will be odd PIC somewhere though... there's ALWAYS one ... or twelve.
    Stay tunned... free stuff need patience
  16. #256
    Oct 2010
    i would like to thank you once more Steve.
  17. #257
    Really welcome my friend. BTW it will be handy for me too
  18. #258
    Jan 2011
    Skopje,Macedonia
    @Fretello,can you post the code for this project (see image : )
    please I need it to make a project with Nokia 3310 LCD display.And can you put the program that you make those graphic pictures?
  19. #259
    Dec 2008
    Ploiesti, ROMANIA
    All you need...
    Simple follow up: I haven't gave up, just really busy.
  21. #261
    Oct 2010
    no problem Steve,
    take your time.
  22. #262
    Jan 2011
    Skopje,Macedonia
    I compile the code and I got an error message:When I delete this line:@ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON, LVP_OFF, CPD_OFF, PROTECT_OFF
    there is no Error.When the line isn't deleted there is an error,that is saying Illegal opcode(pic16F628A) This error is when I use pic16F648A
  23. #263
    which code?
    @ DEVICE line is for PM assembler, if you're using MPASM to compile, you need to change it accordingly.
    So again, Post #1 & #5
  24. #264
    Jan 2011
    Skopje,Macedonia
    I am using MPASM to compile.I try with two of them @DEVICE and _config_... etc. but it doesn't working on my PC.
  25. #265
    If you have read post #1 and #5 of the above link and it still don't work.... Post what you tried then...
    For MPASM you will use @ __CONFIG thing. notice there's 2 underscore character before CONFIG
  26. #266
    Teaser time... have a good reading BEFORE the launch... or lunch... whatever floats your boat.
    Readme.txt
  27. #267
    Oct 2010
    Hi steve,
    i have downloaded the txt, reading time.
    thanks.
  28. #268
    Default BETA Version
    OK, since I'm changing my ISP and I'll be unavailable for a few days, I've decided to post the BETA version of it today. It's not finished yet, but quite workable.
    Extract the archive to your root directory, it should create a NokiaGLCD folder. from there surf in the few code example and you should be able to understand most part of it.
    Like I said, it's not 100% finished yet, the documentation is not finished (maybe not 100% accurate either) AND I'm still adding/modify features and try to shrink the whole codesize. No need for ANY complaints and I know some part have to be coded better than they already are
    Before next friday (july 5th) I might not be able to access the internet as much as I would like to.
    Beta Enjoy.. or beta wait
    Last edited by ScaleRobotics; - 30th July 2011 at 05:08. Reason: removed outdated file
  29. #269
    Default Re: BETA Version
    OUPS, discard the previous.. from wrong computer
    here you go, sorry
  30. #270
    Dec 2008
    Ploiesti, ROMANIA
    Wow !!! GREAT JOB !!! Thanks Mr. E !
    ...In some applications I put the "RES" pin of display to V+ (max 3v3), and I have no problem...Maybe it's usefull for having one "extra-pin" free, for 12F675, for example.
  31. #271
    Thanks Fratello,
    Yup, I'm aware of that, But I would prefer the CE option, since it's better to initialise the LCD right after a hardware reset. Basically you can set the CE pin to ground without problem. Now if you really run out of I/O, you could use a R/C network on the RES pin, and do the initialisation. Another thing, if you run your unit and want to go in Sleep mode... you can still re-initialise the display after the Sleep. Not sure if you can do it properly with the RES pin always high.. However, I haven't messed too much with this too much.
    If you want to save an I/O, set the RES pin to Ground and use the following define
    DEFINE GLCD_OVERRIDE_CE
    This will remove the CE High/Low at compile time.
  32. #272
    Thank you Steve for your work on this,
    Will do some experiments this week.
    Best regards
    Rui
  33. #273
    Thanks Rujic. This should work
    The next and final version Include the Variable/constant to HEx/Bin/Dec conversion routine, improvement for custom, character/custom screen and... that's all. After that, it will be to the end user to make his own homework
  34. #274
    as of today, 37 downloads, no bug report, no questions, not much comment... must be ok
  35. #275
    Jan 2004
    Thessaloniki , GREECE
    Mister_e: I had very long time since last read this thread!
    I see that ther has been great project with NOKIA LCD stuf!!!
    Excellent work you've done my friend!
    If ever I need to use nokia lcd ,in the future, your routine will certainly be my first option!!!
  36. #276
    Haha thanks Bitmaniac!
    I don't know how much future there is in those Nokia LCD right now, seems the deal is no longer the deal some had couple of years ago, however it's been a good and funny project. Learnt a lot from it. Still polishing the latest version for PBP 2.60, and I guess I could have it easier to use for PBP3 but not sure yet.
    Side note, for the Proteus/Isis user, one of my friend found a Model for that. I haven't used it myself because... I don't use Proteus.
    OK, it seems it doesnt simulate all Nokia features like Contrast, Inverse Video and couple of other, but It looks workable. Here's the link for those interested.
    http://www.8051projects.net/download...eus-model.html
    What I've been told about the installation: You unpack the .zip file and copy the files located in Models and Library folder of this zip archive to Proteus/Isis Models and Library folder. Period... and it should work. My friend use Version 7.8 on Win 7 , not sure if this is the latest version or not... however...
  37. #277
    May 2006
    Del Rio, TX, USA
    Waiting for a display to arrive in the mail...
  38. #278
    Mar 2006
    Hyderabad (India)
    @ Steve,
    Perhaps one can convert it to work on a modern TFT type NOKIA lcd display, as 3310 displays may not be available in future.
    Sarma
  39. #279
    Sure enough, it's a huge core for ANY Glcd. Sure they will be available for some times... but not those <= 2$
  40. #280
    farhang's Avatar
    farhang Guest
    Hi,could you please send me hex code an schematic for me, my email [email protected] many thanks.
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 01:43
  3. Play with LCD on PICDEM
  5. LCD will not start
