Instant Interrupts - Revisited - Page 17
Page 17 of 20 FirstFirst ... 71314151617181920 LastLast
Results 641 to 680 of 773
  1. #641
    Hey Darrel, I have a question about N-Bit math as it relates to DT_INTS ASM type interrupt.
    Would the ASM part of the N-Bit Math qualify as an assembly interrupt? for instance, can I do math like this in the middle of an asm type interrupt handler, without having to worry? I am not really talking about this code (your degree conversion example) but doing math like this inside an assembly interrupt handler. Or since it is using an include file, I have to worry?
         MOVE?WP  _degree_Total, _Temp1           ; copy degrees to a PVAR
         MOVE?CP  65535, _Temp2                   ; put multiplier in a PVAR
         MATH_MUL _Temp1, _Temp2, _Temp1          ; Temp1 = DEG * 65535
         MOVE?CP  35999, _Temp2
         MATH_DIV _Temp1, _Temp2, _Temp1          ; Temp1 = Temp1 / 35999 (16-bit result)
         MOVE?PP  _Temp1, _Temp2                  ; copy result to Temp2
         MATH_ROR _Temp2                          ; rotate right 4 times
         MATH_ROR _Temp2
         MATH_ROR _Temp2
         MATH_ROR _Temp2                          ; Temp2 is now 12-bits
         MOVE?PW  _Temp1, _Decimal_value_16bit    ; copy PVAR's to WORDs
         MOVE?PW  _Temp2, _Decimal_value_12bit
    Walter
    http://www.scalerobotics.com
  2. #642
    Absolutely!
    The math routines don't use any of PBP system variables.
    But they do use an FSR, so that must be saved/restored at the beginning/end of the ISR.
    There are two macro's included in N-Bit_Math that do the FSR save/restore ...
    @ FSRSAVE
    ; -- math code here --
    @ FSRREST
    ADD: DT_INTS already saves/restores the FSR's, so if you're using DT_INTS, there's nothing to worry about.
    hth,
    That is awesome, just opened a ton of possibilities with the speed of ASM, and the ease of DT_INTS and N-Bit Math. Thanks Darrel!
  4. #644
    Mar 2009
    Just a quickie, re IOC interrupts....how do I know which one to use? (previously I was using IOC with a 16f690 & used RABC_INT then, but the PIC I'm using now doesn't have a PORT B)
    From DT's site...
    Several new interrupt sources have been added in version 1.00. GPC_INT, IOC_INT, RAC_INT, RABC_INT and the original RBC_INT are all forms of Port Change Interrupts. The chip being programmed determines which one you need to use.
    Where do I look to establish this info?
    I'm using one of the newer 14 pin 16F1823 PICs.
  5. #645
    The key is to look in the INTCON register.
    For the 16F690, INTCON.0 is RABIF. So you would use RABC_INT.
    With the 16F1823, INTCON.0 is IOCIF, so it's IOC_INT.
    I could probably make it so IOC_INT works for all of them.
    They are all "Interrupt On Change".
    Mar 2009
    Many thanks Darrel.
    I have a problemetette - my program runs fine, but then when I press a switch (to generate an IOC), an interrupt *is* triggered, but it then seems to loop in my interrupt handler (it's actually becuase the INTCON.0 bit seems to be staying at 1, which keeps it jumping to the interrupt handler constantly)
    Any ideas, why the IOC_FLAG = 0 entry towards the end of the interrupt handler doesn't appear to be taking affect?
    IOC_FLAG VAR INTCON.0 ' Alias RABIF interrupt flag bit
    debug_out var byte
    SW1    VAR PORTA.5
    on_status var byte
    Green_LED VAR PortC.1
    INT_LIST  macro ; IntSource,    Label,         Type, ResetFlag?
        INT_Handler  IOC_INT,  _Switch_Interrupt,  PBP,  YES
        INT_CREATE       ; Creates the interrupt processor
    Check:
      'Check switches before enabling/re-enabling IOC
      WHILE SW1 = 0 : WEND  ' Wait until all switch inputs = 1
     IOC_FLAG = 0          ' Clear the int-on-change flag bit
    @ INT_ENABLE IOC_INT   ; Enable 'Int On Change' interrupts
    on_status = 0
    Low GREEN_LED
    Switch_Interrupt:
    hserout ["trap ", dec IOC_FLAG, 13, 10]
    @ INT_DISABLE IOC_INT  ; Disable further IOC interrupts
            pause 10
            IF sw1 = 0 THEN
            if on_status = 1 then
            on_status =0
            Low GREEN_LED
            High GREEN_LED
            on_status =1
            pause 20
            pause 25
            IOC_FLAG = 0
    @ INT_RETURN
    This is almost certainly something I'm doing wrong, but then again, it's pretty much a direct what was working fine my functioning 16F690 IOC routine?
  7. #647
    On these Enhanced chips, the Interrupt On Change works much better than on the older chips.
    You can specify wether you want Rising edges, Falling edges or both by enabling them in the IOCAP and IOCAN.
    Then each Pin has it's own interrupt flag in IOCAF. And you need to clear those bits.
    It's described better in section 13.0 in the datasheet.
    http://ww1.microchip.com/downloads/e...Doc/41413A.pdf
    Mar 2009
    Yet again, you've come up trumps - worse still I knew about the positive edge/falling edge for triggering an interrupt ...since I'm using weak internal pullups, I selected negative, but I never made the connection that I'd have to clear the flag you mentioned....I've now modified my code to clear IOCAF ..... & it works a treat.
    You've made a happy man very old.
  9. #649
    Mar 2011
    Default Re: Instant Interrupts - Revisited
    I have a fair amount of experience with MPLab and PBP. I'm trying to hook up instant interrupts, and have run into an odd situation. I've pored through the ASM file, source file, compiler and assembler manuals, and the MPLab info, and searched on line, including here. I'm sure it's simple and I'll slap my own forehead when someone points it out, but ... well, if you can supply a pointer, I'd be grateful.
    I'm trying to compile the instant interrupts "BlinkyLight" program, which is as follows:
    ' this Blinky Light program will continue Blinking at the same rate, no
    ' matter what else you add to the Main: program loop.
    LED1   VAR  PORTB.1
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    T1CON = $31                ; Prescaler = 8, TMR1ON
      PAUSE 1
    GOTO Main
    ' ---[TMR1 - interrupt handler]--------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    I'm running MPLab v8.60 with PBP 2.60a. I have used this setup to successfully compile to HEX other programs in PBP. MPASM is the assembler, and I'm using the 110 level of instant interrupts.
    I get this odd error from the assembler that it cannot continue, as follows:
    Executing: "C:\PBP\PBPMPLAB.BAT" -p16F628A -ampasmwin -k# "BlinkyLight1.bas"
    Executing: "C:\PBP\PBPW.EXE" -p16F628A -ampasmwin -k# "BlinkyLight1.bas"
    PICBASIC PRO(TM) Compiler 2.60A, (c) 1998, 2010 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Error[101]   E:\AVS\V2 DEVT\DUAL DELAY\BLINKYLIGHT1.ASM 231 : ERROR: (wsave variable not found,)
    Error[101]   E:\BLINKYLIGHT1.ASM 195 : ERROR: ("                     Add:"       wsave VAR BYTE $70 SYSTEM)
    Error[101]   E:\BLINKYLIGHT1.ASM 252 : ERROR: (Chip has RAM in BANK1, but wsave1 was not found.)
    Error[101]   E:\BLINKYLIGHT1.ASM 202 : ERROR: ("   Add:"       wsave1 VAR BYTE $A0 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    Error[101]   E:\BLINKYLIGHT1.ASM 268 : ERROR: (Chip has RAM in BANK2, but wsave2 was not found.)
    Error[101]   E:\BLINKYLIGHT1.ASM 209 : ERROR: ("   Add:"       wsave2 VAR BYTE $120 SYSTEM, Or change to   wsave BYTE $70 SYSTEM)
    BUILD FAILED: Thu Mar 10 13:21:14 2011
    It looks like the problem is in assembling the instant interrupts code - I think. I clearly have something set up wrong, but what?? Just point me in the direction and I'll go find it.
  10. #650
    Read the error message. It tells you what to do.
  11. #651
    You have error messages that tell you exactly what to do:
    Add wsave etc...
    Look into your DT-INT-14.bas file at the first section that says:
    ;-- Place a copy of these variables in your Main program -------------------
    ;-- The compiler will tell you which lines to un-comment --
    ;-- Do Not un-comment these lines --
    and follow the instructions of the errors you get.
    Mar 2011
    Got it. Thanks very much. Somehow I missed that the error message was the cure.
    I understand the issue now. It seems to work Now got to go burn chips...
  13. #653
    Darrel has changed the way DT-INTs work now.
    It may surprise but is far better now.
    Happy burning
    Mar 2011
    Just so I don't miss anything, can you direct me to more information on how they have changed? Is that on line?
  15. #655
    For the practical side, users just get a descriptive message as of what to do in the main program. This errors,that are instructions really, may scare a little. But they just tell you what to do.
    Regarding the setup there is no change for the users.
    Mar 2011
    Thanks for taking the time to point this out for me.
    Like many things, it seems obvious now that you say it, and I get to slap myself on the forehead again.
    It's working fine.
  17. #657
    Nov 2008
    Hi Darrel,
    i found a problem which is not clear to me:
    I hava a 18(L)F25K22 and want to use SSP1_INT for my I2C handler, but after compiling the source, i get this error:
    ....test.asm 1052 : Symbol not priveiously defined (SSP1IF)
    When defining SSP2_INT there is no error.
    Ralf
  18. #658
    Ralf,
    What version of MPLAB are you using?
    I don't get the error when compiling for SSP1_INT here.
    When dealing with new chips like the 25K22, you should always keep up to date.
    Current MPLAB version is 8.66.
    http://www.microchip.com/stellent/id...&part=SW007002
    Nov 2008
    Hi Darrel,
    yes you are right, i had 8.56, now 8.66 and it works.
    BTW: For all I2C Slave progger:
    To get the I2C Slave running on a 25K22, use SSP1_INT or SSP2_Int, and, very important, you must set ANSC4 & ANSC3 = 0 for SSP1 and ANSB1 & ANSB0 = 0.
    Ralf
  20. #660
    Feb 2008
    Default Weird PortB change interrupt
    Hey there,
    I'm trying to code a portb change interrupt routine with DT's Inst Ints, but it does very weird stuff, and I can't find out why.
    The setup:
    PIC 16F876 @ 20 MHz
    I have connected LEDs to the ports c0, c3, c4 and c5 to check what happens
    The input switches are connected to ports b1-b4
    The code looks something like this:
    define OSC 20
        INT_Handler    RBC_INT,  _PortBInterrupts,   PBP,  yes
    @    INT_ENABLE   RBC_INT     ; enable PortB change interrupts
       toggle led              ' Toggles a LED that indicates if the program still runs :-)
       pause 250
       low portc.0
       low portc.3
       low portc.4
       low portc.5
    PortBInterrupts:
        if portb.1 = 1  then
            high input1
        if portb.2 = 1  then
            high input2
        if portb.3 = 1 then
            high input3
        if portb.4 = 1  then
            high input4
    @ INT_RETURN
    What happenes is the following:
    If I press any button except of b4, nothing happens.
    If I press only button b4 nothing happens
    If I press b1 just before b4 then the LED according to b4 lits.
    If i press any other button along with b4, the right LEDs light up.
    It seems that button b4 is the mainswitch for all other buttons within the interrupt routine. Without b4 nothing happens.
    So to verify the code I wrote something like this without interrupts:
    if portb.1 = 1 then high portc.0
    if portb.2 = 1 then high portc.3
    if portb.3 = 1 then high portc.4
    if portb.4 = 1 then high portc.5
    pause 250
    low portc.0
    low portc.3
    low portc.4
    low portc.5
    With this code everything works fine. Every input lits the according output LED. So it must be a interrupt handling issue that makes the errors...
    any ideas?
    Pls. Excuse my bad english, it's not my mother tongue...
  21. #661
    The 16F876 only has "Interrupt On Change" on RB4-7.
    Feb 2008
    Hm, thanks Darryl. The datasheet isn't really clear in this case (written in the datasheet is only PORTB<7:4>). I always thought portb change is the whole portb as the name says.
    I'll check this out tomorrow. Hope it works.
    That complicates my circuit a little 'cause I wanted the rb7 and rb6 only for ICSP. Now I have to solder in some jumpers :-)
  23. #663
    A couple of resistors maybe are enough to isolate the ICSP from the rest of the circuit without need of any jumpers.
    Nov 2009
    DFW area of Texas
    Default pbppi14e.lib errors
    DT, you have given the PBP & PIC users a great gift with your instant interrupts!
    My application can't wait for the current statement execution to complete for 'ON INTERRUPT' use.
    I've implemented your latest creations after reading your website on DT_INTS-14.
    Also, have studied many similar threads with similar problem & tried the posted solutions, but I still get compile errors:
    (using PIC16F1826 / PBP2.60C / MPASM )
    Error[113]c:\pbp\pbppi14e.lib 1182 : Symbol not previously defined (INT_ENTRY)
    Error[113]c:\pbp\pbppi14e.lib 720 : Symbol not previously defined (INT_EXIT)
    Error[113]c:\pbp\pbppi14e.lib 733 : Symbol not previously defined (INT_EXIT)
    Error[113]c:\pbp\pbppi14e.lib 737 : Symbol not previously defined (INT_EXIT)
    Warning[207]c:\microc~2\pi34cc~1.asm 720: Found label after column 1. (INT_Create)
    complete code:
    OSCCON = $73 'or %01110011 is for use intosc of 8Mhz
    'OSCCON = %11110000  '32Mhz intosc use
    Define OSC 8         'define the timing for PBP timing such as pause & serout
    'Tris register 1=input(PORdefault) 0=output
    'Ansel register 1=analoginput(PORdefault, digital reads are 0) 0=digitalinput
    ANSELA = %00001100     '1 = Analog used  / Vref+(A3) and Vref-(A2)
    ANSELB = %00100000     '1 = Analog used  / ADC in (B5 / AN7)
    TRISA =  %00111100      '0 is output ;  1 is an input(POR Default)
    TRISB =  %10111111      'Port B
    'OPTION_REG.6 = 1        'INT interrupt acts on RISING EDGE
    'CLKRCON = %11010000  'Turn on ref clock output  BE SURE TO DISABLE "CLOCK OUT" IN MEPROGRAMMER
    '*******Variables*************************
    'HeadUnit Connections
    HUdat   var PORTB.0  'Headunit communications  Input or Output
    'Strain Gage Connections
    GagePwr var PORTA.1  'PowertoStrainBride Output
    ADCPin  VAR PORTB.5  'StrainSample AN7 Input
    'Hall Effect Sensor Connections
    SpdDat  var PORTB.3  'HallSensor Input
    'Digital Pot Connections
    PotCS   var PORTA.0  'CS DigiPot Output
    PotClk  var PORTA.7  'SCK DigiPot Output
    PotDat  var PORTA.6  'SDI DigiPot Output
    'Temperature Sensor Connections
    TmpSDA  var PORTB.4  'SDA Data TempSensor Input
    TmpSCL  var PORTB.6  'SCL Clock TempSensor  Output
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    Y       var byte
    Neg     var byte
    Pos     var byte
    X       var word '16bit variable for PULSIN, 0 to 65,535
    SData1  var word 'Speed data
    SData2  var word 'Speed data to be sent (Use prior pulse)
    WiprPos var byte 'Digipot Command
    WiprNeg var byte 'Digipot Command
    Mark    var byte
    Space   var byte
    Strain  var word 'Sampled Strain Value from WheatstoneBridge
    wiprneg=%00100000           'Wiper0 v 0000 0000 (nv 0010 0000) write
    wiprpos=%00110000           'Wiper1 v 0001 0000 (nv 0011 0000) write
    mark=60
    Y=0
    neg=0
    pos=0
    x=0
    input hudat         'start HUdat as an input pin
    'Interrupt system works on "INT" pin B.0 that is named "HUdat" in the above
    include "DT_INTS-14.bas"    ;Interrupt System
    INCLUDE "ReEnterPBP.bas"    ;to use with PBP Interrupt handlers
           INT_Handler INT_INT, _HandleInt, PBP, yes
        INT_Create      ;create interrupt processor
    endasm
    @ INT_ENABLE  INT_INT ;enables external interrupts
    Start:
    'Set Digital Pots
    pause 10
    neg=240     '257 is ground
    pos=60     '0 is full +V supply
    low potcs     'Use Digital Pot's mode 0,0 and its MSB first & Clk idles low
    shiftout potdat, potclk, 1, [wiprneg, neg]  '8bit digi pot
    high potcs
    pause 50
    shiftout potdat, potclk, 1, [wiprpos, pos]  '8bit digi pot
    high potcs
    pause 10
    pauseus 10
    pulsin spddat,1,sdata1
    sdata2 = sdata1         'store speed data into another var as keep-safe vs. INT
    'if hudat then
    ''  pauseus 2100
    '  output hudat
    '  serout2 hudat,16530,[strain.highbyte,strain.lowbyte]
    'endif
    goto Main
    HandleInt:
    output hudat         'make HUdat an output pin to send data
    strain=24650   'test value
    input hudat          'switch HUdat back to an input pin to receive interrupt
    @ INT_RETURN
    Your help would be greatly appreciated, since my application must have an 'instant interrupt'.
    [ In this application I have a sensor-unit(code shown above) connected to a head-unit. HUdat pin is on the sensor-unit and awaits a simple signal from the head-unit to activate an interrupt and send data on the same connection. ]
    You guys are the best & thanks in advance!
    -ray
    -ray
    "Imagination is more important than knowledge", Albert.E.
  25. #665
    Nov 2009
    DFW area of Texas
    My code had
    INT_Create
    instead of
    INT_CREATE
    I suppose I should wear my glasses more often.
    DTaylor's instant interrupt works great now in my application.
    thanks for your patience,
    -ray
  26. #666
    Aug 2011
    Sorry if I'm in the wrong thread but this is the only one that came up when I searched for PWPS.
    This question is for Darrel, but if anyone else can answer I would appreciate the response just as much.
    The PWPS servo code is almost ideal for what I need........I only want 0.5us resolution instead of 1us. Am I able to get 0.5us resolution by simply defining my code to use an 8 MHz OSC and then changing the 4 value in the code snippet below to 8?
    GetOsc: ' Retreive defined OSC value on Reset
    asm
    ifdef OSC
    MOVE?CB OSC, _PicOSC
    MOVE?CB 4, _PicOSC
    endasm
    Sorry if my terminology isn't 100% correct....I'm a bit of a NOOB to picbasic.
  27. #667
    DEFINE OSC 8 will do but also alter everything based on timing such as HSEROUT/HSERIN/PAUSE etc etc.
    OSC is always defined anyways, even if you don't type the DEFINE OSC line. If you don't type the DEFINE OSC, PBP assume 4MHz.
  28. #668
    Yes, use DEFINE OSC 8 just like you always should.
    But if you change PicOSC, it will change all parts of PWPS including the 50Hz pulse frequency.
    If you only want to change the resolution, you can modify one line in the .inc file ...
    ; W1 = TicksPeruSx100 * Position ; original line
    W1 = TicksPeruSx100 * Position / 2
    Then instead of 0-900, the position variable will be 0 - 1800
    1uS resolution (0.1 degrees) was already better than the maximum performance of hobby servo motors.
    A resolution of 0.5uS will not have any affect if that's what you are doing.
    Aug 2011
    Thank you for the quick reply.
    I'm actually working with an ESC that has 11 bit resolution so that is why I was looking for 0.5us steps. I'm not sure how much difference it will make but I wanted to try it out anyway.
    I really appreciate the help!
  30. #670
    Aug 2010
    Maryland, USA
    Really? Who makes the ESC? On the other hand, I doubt you will notice a difference, but hey go for it!!
    -Bert
  31. #671
    Aug 2011
    It is a Castle Creations ESC........when I spoke to one of their engineers they said all of their ESCs have 2048+ speed steps. I know I can get away with the 8 bit resolution of a standard ESC......but as an engineer I need to get the best (i.e. overkill!) solution!
  32. #672
    Aug 2010
    Maryland, USA
    The part I can't get through my thick head is this, how small of a change can we cause to happen in 20mS to a spinning mass? So if the motor were actually spinning 20,000, then thats 9.75 rpm per bit at 11 bit resolution. On the other hand, getting the extra bit from the PIC may cause less time available to do other things. Mind you I have never looked at PWPS.
    -Bert
  33. #673
    Hi. I am trying to make this Rotary Encoder work with DT-INTS on a 16F1827 device.
    It gets once in the interrupt routine and never seem to exit.
    Here is the code so far driving me crazy.
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_ON & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _LVP_OFF & _STVREN_OFF & _BORV_25
    DEFINE OSC 32
    OSCCON= %11110000   'PLL enabled, Internal RC-8MHz
    ' Set LCD Data port
    DEFINE LCD_DREG PORTA
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTA
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 4
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 3
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    'Initializing Registers
      PORTB = 0:PORTA = 0
      TRISB = $33
      TRISA = 0
      ADCON0 = 0
      ADCON1 = 0
      ANSELA = 0
      ANSELB = 0
      INTCON = $88 ' Binary 10001000
      IOCBP=$30
      IOCBN=$30
      OPTION_REG = 0
      WPUB=$33
    eeprom 0,[2,0,3,1,1,3,0,2]
    led       var portb.4
    Flag      var bit
    wsave     VAR BYTE    $70     SYSTEM  ' alternate save location for W
    Q_New     var Byte
    Q_Old     var byte
    M_Count   var byte [4]
    P_Count   var byte [4]
    Q_Count   var word
    temp      var byte
    clear
    For Q_Old = 0 to 3
    Read Q_Old,M_Count[Q_Old]
    Read Q_Old + 4,P_Count[Q_Old]
    Next Q_Old
      Q_Count = 0
        Q_New = 0
        Q_Old = 0
         Flag = 0
    INT_LIST  macro    ; IntSource,        Label,  Type,  Resetflag?
            INT_Handler    IOC_INT,      _Encoder,  pbp,     yes
    @ INT_ENABLE IOC_INT            ; enable external (INT) interrupts
    '---------------------------- Initialize LCD ----------------------------
    Lcdout $fe, 1                               ' Clear LCD screen
    Lcdout "System Ready"                       ' Display message
    Pause 500                                   ' Wait .5 second
    Q_Count=50
    Goto Main_Loop
    Encoder:                                    ' ISR
        Q_New = PortB.5 + PortB.5 + PortB.4         ' get port status
        If M_Count[Q_Old] = Q_New then              ' if M_Count code satisfied then minus
                  temp=temp+1
                  if temp=4 then
                    temp=0
                    Q_Count = Q_Count - 1
                    Flag = 1                       ' set flag to true to update display
        goto Q_Skip
        If P_Count[Q_Old] = Q_New then              ' if M_Count code satisfied then plus
                  temp=temp+1
                  if temp=4 then
                    temp=0
                    Q_Count = Q_Count + 1
                    Flag = 1
                  endif                       ' set flag to true to update display
    Q_Skip:
        Q_Old = Q_New
        toggle portb.6                               ' update Q_Old Byte
    @ INT_RETURN
    Main_Loop:
    if Flag = 1 then
        Lcdout dec Q_Count                         ' Display encoder position (counts)
        Flag = 0                                   ' reset flag to false, display updated
    goto Main_Loop
    Ioannis,
    On those chips, the IOCIF bit is read-only and only gets cleared when ALL of the IOCBF flags are clear.
    So you can set the INT_Handler's ResetFlag option to NO.
    Then be sure the IOCBF flags are cleared before exiting the ISR.
    Also, take a look at section 13.4 in the datasheet regarding clearing the flags.
    Excellent! Works terrific now.
    These chips are a little pain in setting them.
    Thanks Darrel.
    May 2008
    Italy
    Use the code in post#27, (new approch to rotary encoder) is more efficient and you can achieve even higher frequency.
    Cheers
    Al.
  37. #677
    Hi Al. I am using the #27 ISR.
    The thing that I added was the check for the 4 counts before Q_Count variable is incremented or decremented.
    Thats because the encoder I use produces 4 pulses on every step I turn the knob. Thanks Henrik for noting this.
    May 2008
    Italy
    The code was written to read quadrature count. Any rotary encoder with two channels will generate quadrature count.
    Al.
  39. #679
    Yes that is correct. So the Q_count variable is incrementing by 4.
    Sep 2010
    Las Vegas, NV
    If this topic was previously mentioned, I apologize for not finding it.
    I'm using a 16F877A with a 4 MHz crystal and two 22pf caps with a LED hooked up to portb.1 and the code from example 2 of DT_ints-14.bas on DTs site. I'm using a oscope to look at the timing of the LED flashes and they are occuring around 950msec apart.
    My question is, is there a way to tune the oscillator or modify DT interrupts to get it closer to a true 1 second pulse time? I know it's not far off but I was trying to learn something and maybe make it more accurate at the same time. Your help would be appreciated.
    Yes I did read the datasheet but I couldn't find anything like OSC tune that I've seen for the 12F683.
  1. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  2. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  3. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  4. Keypad and DT's Instant Interrupts
    By Homerclese in forum General
    Last Post: - 27th April 2007, 06:32
  5. Replies: 1
    Last Post: - 1st November 2006, 03:11
Members who have read this thread : 8
