i' using the following code to read 2 LDRs' and change the direction of a small robot. The code is based on the tutorial: http://www.rentron.com/Micro-Bot/CDS.htm
eyes:
gosub check_LDR ' get LDR RC values
select case light_state
case 1
IF LDR_Right_Val > LDR_Left_Val THEN 'if right brighter than left
if panic_flag = 1 then 'is it in hide mode?
eyes_output = right 'yes - right
eyes_output = left 'no - left
end if
'ENDIF
light_state = 2 'goto next state
end if
case 2
if LDR_Left_Val > LDR_Right_Val THEN 'if left brighter than right
eyes_output = left 'Yes - left
eyes_output = right 'No - right
end if
light_state = 3 'goto next state
end if
case 3
light_state = 1 'goto the first state
eyes_output = idle 'idle
end select
return 'return to start
check_LDR:
HIGH portb.6 'Right_LDR 'Make right CDS pin high
PAUSE 3 ' Let cap charge
RCTIME portb.6, 1, LDR_Right_RCdata ' Time & record discharge time
HIGH portb.7 'Left_LDR 'Make left CDS pin high
RCTIME portb.7, 1, LDR_Left_RCdata ' Time & record discharge time
LDR_Right_Val = NCD LDR_right_RCdata
LDR_Left_Val = NCD LDR_left_RCdata
i'm using a 220ohm resistor, with 0.1uF caps. The LDRs rated 27k - 94k.
The code works in that if one LDR is covered the the robot turns as required.
However In ambient light it doesnt find the brightest source of light.
Can anyone help with sugestions to improve the sensitivity..
any help is greatly apriciated
thanks
jim
