Converting Knots to MPH with ascii numbers
Results 1 to 6 of 6
    Mar 2004
    Default Converting Knots to MPH with ascii numbers
    I'm working on a project where I'm reading data from a gps.
    Here's my problem, the GPS Knots string changes in length
    When stationary it reads e.g. ,0.0,
    When the slightest movement e.g. ,2.28,
    With more movent ,38.71,
    More ,78.97,
    Breaking the speed limit ,100.73,
    I tried using DEC to grab the numbers but this didn't work reliably
    So I used STR and looked for the , before and , after the string which works well. But when trying to convert the string from Knots to MPH (x 1.15) here I hit my problem.
    As the string varies in length the Knots 100x 10x 1x etc move around in the Knots[6]
    eg.
    0.0????
    0.11???
    11.11?
    111.11
    And lastly once converted i need to be able to read the MPH out one chr at a time to write to screen. And i'm only looking the whole MPH nothing after to .
    Any pointers are welcome.
    Rob
    A few example strings below
    $GPRMC,201639.219,A,5124.2293,N,00029.3233,E,0.0,0 00.0,020304,,*01
    $GPRMC,201651.219,A,5124.2280,N,00029.3227,E,2.28, 291.1,020304,,*3B
    $GPRMC,201854.211,A,5124.5346,N,00029.7814,E,38.71 ,079.8,020304,,*02
    $GPRMC,201948.207,A,5124.6416,N,00029.1546,E,78.97 ,279.9,020304,,*0B
    $GPRMC,202200.199,A,5124.6983,N,00030.1561,E,100.7 3,080.1,020304,,*3F
    KNOTS[6]
    SERIN2 PORTb.1,188,1000,NoData,[WAIT("$GPRMC,"),dec2 HH,DEC2 MM, dec2 ss,_
    skip 5,Lock,_ 'Looks for V or A
    wait(","),dec2 latA,Dec2 LatB,_ 'Looks for Lat 2 digits
    wait("."),DEC2 LatmsA,DEC2 LatmsB,_
    wait(","),NS,_
    wait(","),LonA,Dec2 LonB,dec2 Lonc,_
    wait("."),DEC2 LonMSA,DEC2 LonMSB,_
    wait(","),EW,_
    wait(","), str Knots\6\",",str head\5\",",dec2 d,dec2 m,dec2 y]
    When reading the numbers in, zero a Byte variable when the decimal point is encountered. Let's call this byte variable our Multiplyer. Then when each subsequent number is encountered (until the next comma), increment the multiplyer.
    Now, knowing how many decimal points you're playing with. You can then construct a word integer variable to do your math with knowing exactly where you stand. So using your last example, you can have an integer loaded with 10073, with the Multiplyer standing at 2, you know there are two decimal places.
    You can then multiply 10073 by 115 and use DIV32 to divide by 100 and extract your answer. The Multiplyer byte will still indicate where to drop-in your decimal place when displaying, outputting or otherwise processing your final answer.
    Naturally you can't spill out of your word variable, but with two decimal places you can go to 569.86 knots (which equates to 655.33 mph by your calculation and PBP's integer math limitations) and should be enough for the majority of applications).
    Melanie
    Mar 2004
    Melanie
    I can understand what you are saying but not sure is will help.
    My knots[6] for 100.73 would by $31,$30,$30,$2E,$37,$33
    So how do I get this lot into one WORD then do my maths then back to Ascii again? I know I can -$30 to get it close but how do i get it all in to one WORD.
    once I've done that is there a way to convert 10075 = $2759 back to 10075 as individual bytes?
    Hope that makes sense.
    Rob
    Just think about what you need to accomplish in each step as I have outlined in my previous reply. There are probably more elegant ways of doing this but I've thrown this together in the short time available to me today (I have kept comments to a minimum so you can work-out what I’m doing in each section)...
    Lets break the job down into steps...
    We start with Knots array holding an ASCII numeric string with a Decimal place somewhere within it.
    CounterA var Byte
    DataA var Word
    DataB var Word
    Knots var Byte [6]
    KnotsW var Word
    Multiplyer var Byte
    MPH var byte [6]
    MPHW var Word
    ' Step 1
    ' This section loads the Word variable KnotsW
    ' from the ASCII String variable Knots
    ' and ensures there are ALWAYS 2 decimal places
    ' regardless where the decimal place is in the string.
    ' Any more than 2 decimal places are truncated.
    ' Any less than 2 decimal places are multiplied up.
    KnotsW=0
    Multiplyer=$FF
    For CounterA=0 to 5
    If Knots(CounterA)=$2E then
    Multiplyer=0
    Else
    If Multiplyer<2 then
    KnotsW=(KnotsW*10)+Knots(CounterA)-48
    If Multiplyer<5 then Multiplyer=Multiplyer+1
    Endif
    Endif
    Next CounterA
    If Multiplyer=$FF then Multiplyer=0
    DecimalAdjust:
    KnotsW=KnotsW*10
    Multiplyer=Mutiplyer+1
    Goto DecimalAdjust
    ' Step 2
    ' This next section converts to MPH
    ' The resultant is an Integer called MPHW
    DataA=115
    DataB=KnotsW*DataA
    MPHW=DIV32 100
    ' Step 3
    ' Finally you want individual ASCII Bytes
    ' So we'll load our result MPHW into the array MPH
    ' and Right-justify with Leading Zero Suppression
    MPH[0]=MPHW DIG 4
    MPH[1]=MPHW DIG 3
    MPH[2]=MPHW DIG 2
    MPH[4]=MPHW DIG 1
    MPH[5]=MPHW DIG 0
    DataA=0
    For CounterA=0 to 5
    If CounterA=3 then
    MPH[3]=$2E
    Else
    If CounterA=2 then DataA=1
    If MPH[CounterA]=0 then
    If DataA=0 then
    MPH[CounterA]=$20
    Else
    MPH[CounterA]=MPH[CounterA]+48
    DataA=1
    Endif
    Endif
    Endif
    Next CounterA
    At the end we have Miles Per Hour ALWAYS with 2 decimal places. If you want variable decimal places, then remove the DecimalAdjust section, and use the Multiplyer variable accordingly when loading your MPH array.
    Now it wasn’t that difficult to break-down into steps was it?
    I've not tested this code, but I'm sure you will once you've worked out the logic.
    Melanie
    mikep's Avatar
    mikep Guest
    Default Reading GPS
    I use this little routine
    ' Get the value of a numeric field
    ' The size of the field cannot pass a word
    GetNumField:
    tempbyte=1 ' Used for field position of GPS Data
    factor = 1 ' Used to retun the factor that we multiplied the value
    FOR i = 0 to MAXDATA
    IF gpsdata[i] = "," THEN
    tempbyte = tempbyte + 1
    IF tempbyte = field THEN
    ' isolate the value here
    tempword=0
    tempbyte=1
    WHILE i < MAXDATA
    i = i + 1
    IF gpsdata[i] = "," OR gpsdata[i] = "*" THEN
    IF gpsdata[i] = "." THEN
    factor = factor * 10
    tempword = tempword * 10
    tempword = tempword + (gpsdata[i] - 48)
    WEND
    NEXT i
    gpsvalid = 0
    You can see all of it at:
    http://cvs.sourceforge.net/viewcvs.p....2&view=markup
    It also does the checksums etc.
    This was a way to actually not need to know the exact format of the data since it changes on different models of GPS.
    I've seen many GPS reading routines in PBP and almost all of them would break if you ever used a different GPS. Also none of them ever checked the checksum.
    Mike
    Mar 2004
    Thanks Melanie & Mike
    I give both ways a try when I get home later today.
    Rob
  1. Replies: 4
    Last Post: - 15th April 2009, 01:54
  2. Need help converting to ASCII Hex format
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 19:14
  3. Converting ASCII to HEX
    Last Post: - 27th September 2006, 10:21
