PBP3 download trial and purchase links
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 40 of 42
    Sep 2023
    Default PBP3 download trial and purchase links
    Hi all,
    I wanted to try out PBP3 but can't seem to find a working download.
    And when I press purchase I see "Out of stock".
    Can anybody help me?
    I tried these links:
    https://picbasic.co.uk/
    https://www.picbasic.co.uk/forum/con...BASIC-Compiler
    https://www.crownhill.co.uk/melabs-p...-compiler.html
    https://pbp3.com/downloads/PBP3_Setup.exe
    Default Re: PBP3 download trial and purchase links
    For a strange reason I had to reload the page many times before it showed up.
    https://store.melabs.com/prod/PBP/PBP3-4.html
    But it works.
    Sep 2023
    https://melabs.com/
    Gives me continuously error
    DNS_PROBE_FINISHED_NXDOMAIN
    The link I posted is showing this at my end:
    Sep 2023
    I tried it now many many many times on 4 pc's (2x Win7, 2x Win10) and 3 Cell Phones without any luck.
    Why should it be so hard to open a single webpage?
    I can now find another working webpage that offers PBP3.1
    https://www.mecanique.co.uk/shop/index.php?route=product/product&product_id=52
    I
    s this the same software?
    It is another company that makes the IDE and co-operates with Melabs.
    You can also buy from them or https://www.crownhill.co.uk/02863.html (our boss that offers us this forum for free, Mr. Lester Wilson).
    Sep 2023
    At the url page I read: "Availability No stock".
    When I select "ADD TO WISH LIST" I still get the message PBP3, "No stock", £250.
    I am sorry for the difficulties you face.
    I am still able to access the main Melabs page here: http://store.melabs.com/cat/PBP.html for direct order.
    You can also contact Lester Wilson at [email protected] to clarify why you cannot add to basket the product at his site.
    Where are you located?
    Apr 2003
    Cambridge - UK
    Hi
    Sorry about the no stock situation
    We will correct that. Just awaiting some info from melabs
    Lester - Forum Administrator
    www.crownhill.co.uk
    Sep 2023
    @Ioannis, I am located in the Netherlands.
    @Lester, Thanks for the help.
    1. Will this PBP3.1 work with MicroCodeStudio and which version to use and where to buy eventually?
    2. Way back in the past I saw that with a USBwizard they could program 28pins and 40pins USBchips.
    I don't know which version that was.
    I read that PBP3.1 supports 20pins USBchips (18F14K50) but does it work in the USBwizard too?
    The package of PBP 3.1 includes the Micro Code Studio IDE, so no worries about this.
    But you have to stick with MPLABX 5.35 and NOT any newer version.
    USBwizard, you mean the MIKROE one?
    Sep 2023
    Ok, PBP 3.1 incl. MCS.
    Ok,
    MPLABX 5.35 only.
    (But can I have two MPLABs version installed and let
    PBP 3.1 only work with MPLABX 5.35 version?)
    Not MIKROE(don't know what that is) but: PullDown->View->"EasyHID USB Wizard".
    About USB I have the least experience so cannot help on that. Hopefully some other kind member may know more.
    The MPLABX can coexist with older 8.xx versions. Checking my Program Files (x86) folder, Microchip installs MPLABX on separate folders, so I am pretty sure you can have different versions at the same time. Have not tested that, as I had no interest so far. Just make sure PBP compiler is directed to the proper MPLABX assembler.
    Sep 2023
    Directed to MPLABX while installing or in settings?
    How does the license work knowing that I will change(from Windows7 2010 Alienware laptop) to another laptop(Windows11) soon, then the license is transferable?
    And how do software & new Microchips updates/upgrades work?
    Sorry for so many questions, I'm new to this.
    The license is good for three installations as I recall. So no problem with this.
    Once you install the PBP and the MPLABX 5.35, the only update you may do is on the compiler itself if and when there will be one. MPLABX will not be updates as the PBP does not support any newer than 5.35 version.
    From the settings of the MCS IDE/View/Compile and Program Options, you have two buttons (Default Path and Find Manually...) to direct IDE to the correct MPLABX assembler.
    My settings are these on the attached screenshot.
    Although Ioannis is correct in that you are indeed allowed to activate PBP on more than one machine don't forget to use the PBP Activation Manager to "deactivate" the license on that Alienware laptop before dispoing of computer in order to free up that instance of the license.
    Sep 2023
    In your screenshot I can only see the "Default Path and Find Manually" of the PBP compiler and not, as you mentioned, path to the MPLABX assembler.
    @HenrikOlsson
    I hope that I wil be in time to use the PBP activation Manager to deactivate the license because when problems happen it's already to late like a drive crash.
    Can I work offline with this PBP license?
    If the drive crashes and you're not able to deactivate the license I'd contact MeLabs and ask them for help. Given their record I'm sure they'll help you out.
    The Activation Manager needs internet access during the activation process. Once activated the compiler will work without internet connection. There IS also a way to "manually" activate the license on a machine without internet access.
    If/when MeLabs shuts down business I hope they will release a version of the compiler that has the license activation removed completely.
    Quote Originally Posted by Richards View Post
    I am not sure what you want to see in the path.
    You just select either manually or by default. You will not see the actual path.
    Someone is overthinking and overcomplicating things. This is not Linux :-)
    The confusion likely comes from the following:
    In the referenced dialog you do set the path to the compiler, ie PBP and not the assembler. There is a checkbox to tell it to use MPASMX assembler instead of the old MPASM assembler but no way to set the path to IT.
    When PBP3 installs it automatically launches a tool that should find the path to the assembler. That tool is available in the PBP3 Start Menu folder after installation and can be run manually if needed.
    Just run the installer and follow the instructions.
    Sep 2023
    Cool Re: PBP3 download trial and purchase links
    It all makes sense now, thanks to you both.
    Could be that while installing and using the software I wil need some help.
    I'm now waiting patiently to buy PBP3.1 online
    You still not been able to purchase it?
    My guess is sales of PBP is pretty low these days so it's a pitty that someone who actually wants to buy it seems to not be able to...
    In the meantime you can download and install MPLABX 5.35 from here:
    https://ww1.microchip.com/downloads/...-installer.exe
    The direct link http://store.melabs.com/cat/PBP.html works just fine for me.
    Sometimes, I do not know why, the page needs 6-10 time of refreshing to load completely (I am on Opera if that matters), but can order just fine.
    Sep 2023
    I already installed MPLABX 5.35 correctly.
    On two computers I installed opera to buy and download PBP3.1 that also did not work.
    Name:  Melabs in Opera-1.jpg
    Even on my Android phone I get...
    Try to insist on, refreshing page many times.
    I had to do this 15-20 times to succeed!
    me too... and judging by spam content that is going unmoderated on the official forum it may be not that far off
    Sep 2023
    I've tried it about 30 times.
    OK... Any news from Lester?
    Sep 2023
    No sadly no response yet other than on 15 september the post #10 of this thread.
    Maybe if you contact directly Charles Leo, owner of Melabs?
    Strange - and sad. Very sad.
    I would have given up already and went to a competing product.
    Crownhill (the company that hosts this forum) did have their own compiler. It's now end of life but available free of charge (though it looks like you need to register to actually download it):
    https://www.crownhill.co.uk/category-41.html
    The Positron compilers (seems to be a spin-off or continuation of the Proton compiler) is another attractive alternative:
    https://sites.google.com/view/rosetta-tech/home
    If you're targeting 2only" the PIC18 series then Swordfish might be interesting:
    https://www.sfcompiler.co.uk/swordfish/
    Then we have the offerings from MikroE:
    https://www.mikroe.com/mikrobasic-pic
    Personally I've been somewhat interested in Positron but have not tried it yet.
    I'm sure there are others that I've missed.
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    The MikroE seems also to slowed down development.
    There is also this, the Great Cow Basic, open source:
    https://sourceforge.net/projects/gcbasic/
    None of them are in any way a close fit to what you have learned from pbp so it will be a big learning cure only to sink into another programming cul de sac.
    its C all the way down for me
    Sep 2023
    @HenrikOlsson & @Ioannis
    Thanks for the software alternatives.
    I was not aware of most of them.
    @richard
    "None of them are in any way a close fit to what you have learned from pbp..."
    PBP is better?
    How can I do that?
    PBP is better?
    You would need to define what better means to you
    pbp has no Strings, no floats, no ability to select between signed and unsigned procedure's
    pbb cannot do 32 bit math on anything but pic18 chips and then only if you compile for longs
    pbp has a very limited range of variable types and no inherent ability to use user defined memory structures
    pbb cannot use pointers [address of objects in memory] natively
    pbp is very efficient, can have user defined functions, works well with limited memory chips
    pbp allows assembly code to woven in seamlessly
    pbp has a good forum with heaps of example code
    pbp has lots of ways to side step its limitations due to its very open architecture
    Email him here:
    Charles Leo
    [email protected]
    Sep 2023
    @richard
    Thanks for the short summary of all Pro's & Con's of PBP.
    I will keep that in mind when choosing a software package.
    Thanks for the contact info.
    MikroE said that they have put all of their resources to the Necto environment and left other products a bit behind, but will pick from where they left them.
    I guess is the same old story repeating again as Melabs. Product does not sell as it used to be, so they leave it...
    Sep 2023
    Question Re: PBP3 download trial and purchase links
    I have some more questions if I may:
    Attachment 9465
    a) Can someone send me a screenshot of the Products page of the website?
    I also want to purchase the manual and can't see the price and if it is selectable as paperbook or digital.
    b) I remember reading somewhere that MicroCodeStudio can be purchased separately, but why sell it separately if it's already bundled in PBP3.1?
    c) I am using the microchip 18F47K40 that is not (yet) supported by PBP3.1 according to the PBP-chiplist.
    Can this chip, and maybe others in the near future, be added to the software as supported chips?
  1. Trial period is 0 days
    By ChrisKiwi in forum PBP3
    Last Post: - 8th June 2014, 14:04
  2. How to purchase MicroCode Studio Plus
    By david1800 in forum Off Topic
    Last Post: - 12th April 2010, 15:24
  3. ICD, ICD2, Pre-Purchase Opinions
    By mslaney in forum Schematics
    Last Post: - 29th December 2004, 16:55
  4. MT8870D touch tone where to purchase
    By n0oxv in forum mel PIC BASIC Pro
    Last Post: - 26th June 2004, 04:00
Members who have read this thread : 19
