Leaves the mainloop???
+ Reply to Thread
Results 1 to 40 of 46
    Apr 2016
    Plainfield, Illinois
    Default Leaves the mainloop???
    I'll ask again - why does my program leave the mainloop?
    porta.1 goes high and low..continuously
    OUTPUT PORTA.1
    OUTPUT PORTA.4
    HIGH PORTA.1
    PAUSE 10000
    mainloop:
    LOW PORTA.1
    HIGH PORTA.4
    GOTO mainloop:
    My dad never liked you...
    Default Re: Leaves the mainloop???
    You've written
    GOTO Mainloop:
    Try removing the colon as that's not supposed to there.
    Apr 2016
    You've written
    GOTO Mainloop:
    didnt help..
    OUTPUT PORTA.4
    OUTPUT PORTA.1
    HIGH PORTA.1
    PAUSE 10000
    mainloop:
    HIGH PORTA.4
    LOW PORTA.1
    GOTO mainloop
    its a classic RMW (read modify write error) i expect the load on porta.1 exceeds the
    ability of the pic to maintain the logic level.
    if your chip has latx regs use them
    'OUTPUT PORTA.4
    'OUTPUT PORTA.1
    'becomes
    out1 var lata.4
    out2 var lata.1
    trisa = % 11101101
    'HIGH PORTA.1
    'becomes
    out2=1
    PAUSE 10000
    mainloop:
    'HIGH PORTA.4
    out1=1
    'LOW PORTA.1
    out2=0
    GOTO mainloop
    Apr 2016
    Well I feel like an idiot.
    I connected a 2.5 ohm 100 watt resistor as my load instead of the electronic load (5 amps).
    No issues....works like it should. So the electronic (programmable) load must be the culprit. I could get the scope out and find out if its really introducing excess current draw and/or spikes on my supply.
    What did I learn?
    How to setup the 16F15324 registers and use the LAT function instead of port(x)...
    Slow down and organize my code, schematic, and the real issue before throwing crap at you guys.
    Dont be so sensitive to critique...
    And the Cubs still suck.
    for that type of thing, I would think a relay would be appropriate.
    Apr 2016
    The massive output FETs are to supply 12V to service vehicle equipment. Its an automotive environment, but - by the time it gets to my circuit, the voltage is isolated from the alternator noise, etc, etc..
    My circuit actually works in the field - somehow - which tells me that my electronic load is the culprit. So I'm changing my load to something that emulates my true load in the field. I have some police car flasher lights coming.
    That being said, I want to know why this particular type of load resets my PIC. Good to know stuff.
    At first I thought with the 16F15324 I was setting up the registers wrong - a software reason. Using port instead of latch feature for example. Richard showed me how to setup registers properly but problem still exists.
    Beefy PS - I use a 15amp supply, but if load shorts in first milliseconds the draw is much higher than 15 amps. Thats why if the load is on first the inrush current draw has passed. I think that makes sense. If I used a car battery would the result be the same? I need to try that.
    BTW - Its amazing how you PICBASIC guys know things about PICBASIC code. I'm like - "how in the world did you figure that out" ! Its like you have this magic code book. (I know - its in the docs)..I guess if you do it enough it.......
    for example - from another thread :
    ansela = ~ 16
    lata = ~ 16
    trisa = ~ 16
    Get the scope out. - should be my quote on my forum slogan
    Quote Originally Posted by pescador View Post
    After what you have seen ... I wouldn't even try !!!
    that means your electronic load draws lots of current @ start ( called an overshoot ) and you are not sure it's internal circuits can withstand, say, 40, 50 or more Amps the car battery could easily give ...
    " magic smoke " probably in sight ...
    Glad you got it in the end ...
    My personality is hurry up and ask questions and get an answer. I need to slow down and think of my questions first and organize them. I want the asnwer in miliseconds - lol.
    no no no - asking me if I had a scope was not rude. I was trying to edit my post and the 30 minute limit hit and my post didnt mean to infer that - sorry for that. I thought the rude remarks came from someone else and if you read the thread you can see from who. On top of all that I'm asked if I had a scope and I took it the wrong way. Email and texts and forums can suck sometimes because you cant hear tone.
    currently I still do not know whats up. I brought my circuit to my EE friends at work and they think the load is a resistive load where it really should be an inductive load (service vehicle lights etc) - they are thinking the for the first turn on its shorting my supply for a very short time, resetting the PIC. The supply I use has 15 amps capability, so IMO its beefy enough. I aslo put a larger cap across the 5V with no luck.
    The circuit works under 1 amp so that might be true of load dumping the supply > 1 amp. The scope I have should catch this, I agree. My next idea was to change the load from resistive to inductive.
    And read more ideas here on this forum.
    No hard feelings. We are here to help each other and not to argue or fight. More info you give the better the answer you 'll get.
    It the first time that I see you use electronic load to test the circuit. So, what is that load? DIY or a ready made device? How is that set up? Can you adjust it?
    a RESET could be a good explanation ...
    Hi, Richard
    I tried this some years ago ... HIGH and LOW do not show the RMF " feature " ... even with a 3.3µF Tantalum capacitor as a load !
    try again with a red led and no resistor, i'm talking overloaded pin
    Apr 2016
    yout lat code worked but...
    I used this
    WDTE_OFF and it didnt come out of mainloop - worked
    I also tried this
    PWRTE_OFF - and I was able to write to my fet which had a load connected to it - didnt work right before I changed PWRTE_ON. (NOT SURE WHY)
    Also - I know trisa = % 11101101 makes the inputs and outputs - but what does your code indicate? (why 8?)
    I have this:
    A0 - Led1 output
    A1 - led2 output
    A2 - Analog in
    A3 - CLR
    A4 - TTL Output to turn on FET
    A5 - Input (TTL)
    Ports C are all ttl inputs
    can you help me set these registers up richard? -
    VERY MESSY
    OSCCON1=%00000011
    OSCCON2=%00000011
    INLVLA = %00000
    INLVLC = %00000
    TRISC = %11111 ' MAKE INPUTS
    OSCFRQ_4MHZ
    ANSELA = PORTA.2 ' MAKE ANALOG INPUT
    ANSELC = %00000 ' MAKE DIPSWITCH INPUTS DIGITAL
    would be a bad move , st inputs are less susceptible to noise leave INLVLX as default
    WDTE_OFF has no effect unless u had defined NO_CLRWDT 1
    PWRTE_OFF
    Clutching at straws and randomly poking at register settings is not a good solution
    to noise induced issues and or defective code
    as pointed out by tumbleweed won't do anything like what you need
    Apr 2016
    PWRTE_OFF
    I need porta.2 to be a analog input - the rest are not analog - so how do I do that?
    all pic TRIS registers are 8 bits wide, the port pins are mapped onto those bits one for one , bits that don't match a pin do nothing
    i cannot be bothered to look at the data sheet to see how many pins PORTA has on that chip so i play it safe and allow for all 8.
    why 8 why not
    putting you email on a public forum is not a wise move , i suggest you delete it pronto
    pm me here on the forum if you have to
    a pointless statement without the code that's in play
    Apr 2016
    Here's what I need
    A0 - Led1 output
    A1 - led2 output
    A2 - Analog in
    A3 - CLR
    A5 - Input (TTL)
    PortC - dipswitch inputs - stable on or off.
    Apr 2016
    please email me if you can - easier to explain and I'd like to talk for 5 mins
    what voltage do you expect on the ignition input ?
    is this expected to work in an automobile environment ?
    Apr 2016
    I should just say 12V, not IG - its 12V
    BTW ...
    What kind of load do you intend to drive ???
    Apr 2016
    The schematic shows it drives 2 P channel Mosfets which supply power to a resistor load. - the 10k and 6k on the collector drive the gate when the npn is on.
    The odd thing about this is when it powers up with resistor load attached - it will not drive the base of the npn. Release load and re-apply load - it stays on and works..
    I tried this code this w same results - it tries to turn on the npn but cant, green led flutters on and off - release the load - green led turns on steady - re-apply load - it drives the npn. WTH...
    MAIN:
    FET = 1
    GREEN = 1
    GOTO MAIN
    Apr 2016
    SCHEMATIC1 _ PAGE1.pdf
    here's rough schematic again - sorry for the wild goose chase guys - really appreciate the help.
    Q2 is only driving the gate of some P channel mosfets. With the load attached to the drain of the mosfets, pin 3 on PIC wont drive the base - the program leaves the main loop - it resets.
    If I release the load and turn on NPN and then turn on load, it stays on.
    I was aslo thinking of changing the circuit to a double npn and reverse the logic - thus the PIC wouldnt see the 2nd NPN, but I'd like to know why its behaving this way.
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    you are making this very difficult,
    every schematic so far is different some are worse than others
    the latest is doubtful r17 is too big 3k3 would be more realistic
    this is very bad
    given that vin high is vdd*0.8 and vin low is vdd*0.2
    a 12 volt input lands slap bang in the middle nowhere land , the slightest bit of noise could swing it either way
    r8 should be about 27k
    you keep posting code snippets or incomplete fragments that are impossible to evaluate
    this is a nonsense , and will continually reset because it has no loop it just wander off into lala land
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
    __config _CONFIG2, _MCLRE_ON & _PWRTE_OFF & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_6 & _WDTCCS_SC
    __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_OFF
    __config _CONFIG5, _CP_OFF
    OSCCON1=%00000011
    OSCCON2=%00000011
    trisa = %11101100
    trisc = %11111111
    ANSELC = 0
    ANSELA = 4
    FET var LATA.4 ' FET output
    IG VAR PORTA.5 ' Ignition input
    GREEN VAR LATA.0 ' TIMING LED
    RED VAR LATA.1 ' FAULT LED
    MAIN:
    IF ig = 1 THEN
    FET = 1
    GREEN = 1
    FET = 0
    GREEN = 0
    i'm going to let it stew for a few days till you get your act together
    Apr 2016
    uncle.... do they have that expression down under? It means enough...
    if the problem is spikes, bad earth loop, filtering etc, then by posting here I feel it will ever be nailed down.
    Can you post a video of the process, connections etc? Also an oscilloscope on that offending pin as you say that flatters, may show other things. Do you have an oscilloscope?
    Apr 2016
    Is there a way to kill a thread?
    Apr 2016
    see attached - do I own an oscillopscope I was asked? This is my proto lab.
    I'm 67 years old who survived open heart surgery 4 months ago at NU hospital in Chicago, so not in the mood for rude comments.
    I still do my own pcb layout, order boards, solder paste, pick and place machine, and IR oven my protos. And I attempt to do code using PIC Basic.
    Yeah I was all over the place with my questions, my code constantly changed, my schematic was actually not correct in a few spots, which were actually corrected long ago - the V divider supplying 0-5V to my PIC input for example.
    I did have a "goto main" in my code that was not shown by accident - getting a "its in lala land" comment.
    I do apologize for being a bit scattered on this thread.
    Cool Re: Leaves the mainloop???
    Hi Pescador,
    Take it easy ...
    Some of us here live thousands miles away from you ... and don't know about the first bit of your programming or electronics design skills ...
    So, the first of all things for us is to understand what you intend to build, how you want to proceed, and what you use to build it ... That implies a full description of the project and the problems encountered.
    That also implies you have read carefully your PBP Manual ( THE Holy Bible ) AND the Pic Datasheet.
    Not so simple and a crystal ball is THE most useful tool for about 90% ( 99% ? ) of the questions sent here ...
    I easily understand it's a headache for you to find what is the real problem and you already have wasted hours scratching your head. We all lived that some day : that is called knowledge.
    That said ...
    a forum is a place where everybody can give an answer, considering everybody have its own fads ... beliefs and so on.
    the answers may be right spot on or sending to la la land.
    That's it and we must cope with that. Or rent highly skilled professionnals ... ( of course Fine advices : you've paid for it !!! )
    Now ... just a bit of my story here ...
    I was a contributor and one of the super Mods here, some years ago ( Yess ... ) , but some new guys ( other mods ) went here, thinking they knew everything and being God's children : kind of "knowledge war" where the strongest shouting was truth ... ( elders here just have a look towards Canada ... )
    I simply preferred to come back to " simple forumer " status ... not having to re-demonstrate that 1+1 = 2 @ each time. Our discussions just led others to ... nowhere.
    That to tell you everywhere somebody thinks he is the unique blessed owner of The Truth ... even believing he just helps !!!
    BTW ... the one asking must also understand he is the unique one who knows what he has done ...
    Back to your electronics problem ( it's NOT a programming problem ... for that you have shown here ...) just think how you can design the Pic supply to withstand some 100th of milliseconds main supply shut down ... without resetting
    and you'll be fine.
    Alain " the Frenchie "
    You never said that you have a lab and tools to check signals. Also never showed the signal out of the PIC.
    Asking if you have access to a tool is rude comment?
    Being aggressive while we try here to help you does not really help at all.
    After all, even if you received my comment as rude one, consider that we are spending time on this forum trying to help others. We may be located in countries too far away from mother america and our language may not be english. Do you really speak Greek?
    Wish well recover and leave all the health problems in the past. But that does not make us rude people.
    So, if you really want our help, as Alain said, please do give some details that we can understand your problem.
    For one, you may show us the output pin of that PIC reseting as you suspect. Is it really reseting?
    P.S. I am very happy that I am member of this extremelly helpful forum, for the wonderful giving people I happend to meat here and believe that there are no many forums with the quality we have here.
    Hi, Ioannis,
    How are you ???
    That could be done just checking the dedicated bits of the processor, then powering small LEDS showing what happened.
    BUT that needs some more datasheet reading, and I do think our friend has to be led to Pic datasheet § 8.13 ... just for that checking.
    It's a long way from idea to working device ... but you already know that
    Best Regards
    Hi Alain.
    All good! Thanks for your concern. Hope and wish for you too.
    Well, pescador said that with the (strange) load he places on the output, the PIC seems to reset. So, that is why I asked for an oscilloscope to see what actually the PIC does on that pin while trying to change the state. It may reveal more that way, for example:
    1. Previous state
    2. New state
    3. How long the new state is output
    4. Is it overloaded as initially was suspected?
    5. Is it tristated?
    Apr 2016
    my main question is ... Why having chosen such " monster size " mosfets ???
    1) Imagine some kind of Halogen lights as a load: the inrush current can easily overload the switching supply ...
    2) have a look to the pic voltage regulator : no big caps around it ... so, no supply weakness could be dampened. ( switching supplies ALWAYS have load response time - enough to lead to a pic reset )
    as everyting fine without heavy load , it's correlated to load inrush current ...
    just need a test, powering the Pic with a small "Duracell" battery - say 4v5 - and the load with that big power supply ...
    Sure you have a good point on that.
    Again, a scope can show all these problems, nail them down for good. Either Power supply or output or anything else.
    OK
    Just a shot in the dark; when I design a power supply for my PICs, I isolate the 5v (or 3.3 or whatever) regulator with a 10 ohm resistor from 12v (or whatever) and place a 10 uF and 0.1 uF cap on the regulator input side. Then I put a 100 uF and 0.1 uF (and sometimes a 0.01 uF) parallel caps on the output side (5v side) of the regulator. In addition, there will be some distance between the regulator and the PIC. The VCC pin(s) get(s) an additional 0.1 uF cap to help filter any spikes. These larger electrolytic power supply caps add reserve when a brief power drain occurs, and the small disc caps filter noise. Microchip has released numerous Application Notes regarding power supply filtering and the importance of it. Just for kicks & giggles, give additional power supply caps a try and see if anything changes.
    [I have a large periodical table of elements I hang in my work area. I write often-used formulas there, as well as a resistor color band chart. I made a note to "Add more filter caps" and "Add more test points on PCBs" on my table because of issues I've had in the past.]
    totally agree and in an automotive enviro would make that 10 ohm R a RFC .
    also for high current switched loads pcb layout and wiring design are crucially important
    I have a suspicion about what the problem is, but I can't confirm it without knowing more detail. I'm not going to go out of my way on this just for the chance to learn later that that's not actually the problem and the goal posts have moved again.
    OK
    Another trick you might try is to initialize your SFRs, but put a PAUSE 100 before activating anything. This will give time for the power supply to stabilize. You said if you turn it off and turn it on again it works. This would skip the first turn on and jump to the one that works.
  1. Time taken to do mainloop
    By Gerald in forum mel PIC BASIC Pro
    Last Post: - 29th March 2023, 14:16
  2. Outside the Mainloop
    By pescador in forum General
    Last Post: - 26th April 2016, 17:34
Members who have read this thread : 13
