How to detect variable going below zero, without using PBPL ?
Results 1 to 19 of 19
    Default Re: How to detect variable going below zero, without using PBPL ?
    I came into another issue.
    I have font array in EEPROM, and need to set offset for reading it. Depending on charset, this offset can be negative and positive.
    So I have to do it in a way like this:
    if langvar[x]=0 then
    Y=(topline[x])*8+OFS
    if langvar[x]=1 then
    Y=(topline[x])*8-OFS
    Can these two joined into single operation somehow?
    No, I meant changing the value of OFS in the way, that addition will cause actual subtraction, due to overflow.
    As long as both variables are of the same size adding a two's compliment value to another is the same as subtracting the absolute value of one from the absolute value of the other.
    In these examples all variables are bytes.
    X = 0
    OFS = 1
    Y = X + OFS Y will have the value of 1.
    X = 0
    OFS = -1 OFS will have the value 255
    Y = X + OFS Y will contain the value 255 (which is -1)
    X = 10
    OFS = -5 OFS will have the value 251
    Y = X + OFS Y will have the value value 5
    X = -10 X will have the value 246
    OFS = - 15 OFS wil have the value 241
    Y = X + OFS Y will have the value 231 which is the same as -25
    in simple terms adding the two's compliment of a var to a number is equivalent to subtracting the var from a number
    providing they are all the same integer var type
  1. How to detect variable decrease moment?
    Last Post: - 4th February 2014, 23:02
  2. PBPL and TCP/IP
    By edtp in forum Ethernet
    Last Post: - 4th March 2011, 20:35
  3. Help, PBPL and DIV 32.
    By Rogerio in forum mel PIC BASIC Pro
    Last Post: - 16th March 2010, 11:37
  4. PBP and PBPL
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 18:58
  5. IF..AND/OR..THEN and PBPL
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 17:45
