Graphical Displays with PBP3 - Page 3
+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 81 to 96 of 96
  1. #81
    Default Re: Graphical Displays with PBP3
    Your lib file looks more like an example file. Is it correct ?
    it is. it's the driver component to enable my graphics library to use a sharp memory display.
    post #1 has typical use demos!
    update to ssd1306 include to allow easier configuration for 40x72 displays
    eg
    '****************************************************************'*  Name    : SSD1306 FOR PIC 18 DEMO                           *
    '*  Author  :  Richard                                          *
    '*  Notice  :                                                   *
    '*  Date    : 27/12/2023                                         *
    '*          :18f26k22 @64Mhz                                    *
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = ON
      CONFIG  PRICLKEN = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  T3CMX = PORTC0
      CONFIG  HFOFST = ON
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
     DEFINE OSC 64
        ;set these  to match display
        ssd1306_addr con $78
        #DEFINE colours 1   ;1 mono 2 rg or 3 rgb
        width  con 72;128
        height con 40;64
        h_offset con 28
        include "grx.pbpMOD"
        include "SSD1306.pbpMOD"
        include "Arial_Narrow18x39.bas"
    '    include "bignum.bas"
    '    include "bigchr.bas"
        BUFF     VAR BYTE[10]
        J VAR word
        ANSELB=0
        ANSELC=0
        ANSELA=0
        OSCCON=$70
        gosub glcd_init
        gosub grf_clr
        SETFONT Arial_Narrow18x39
        gosub show
         while j <1000
         colour=1
         fillrect 0,0,72,40
         ARRAYWRITE BUFF,[dec2 j/10,":",dec1 j,0]
         DMDSTR 1,0,buff,0
         gosub show
         pause 10
         j=j+1
         wend
         j=0
    Nice and useful addition to a very handy include file.
    Though I wonder up to what age you can read that displays without eye glasses...
    that's kinda the purpose of this universal graphics method, fonts for it of a good size are simple to make and interchangeable
    between versions and displays.
    a 5x7 font on that display needs a magnifying glass and eye glasses for me.
    note i used a 18x39 font to test with. that i can read from many metres away easily
    bmp bug fix
    Apr 2007
    Pennsylvania, USA
    bmp bug fix
    Working much better, but in my case it is cropping 6 columns off of the right side of the image (110x64). Using the pbp file I uploaded here
    Here are 2 images of what it should look like (using SSDBM vs what is being displayed using DMDBMP.
Size:  343.9 KB Name:  20240223_133312.jpg
    Shawn
  7. #87
    the bmp image width needs to be a multiple of 8 by the look of it
    post the original bmp image if you want me to look further into it
    Apr 2007
    Pennsylvania, USA
    Ok, I assume that is due to the horizontal vs vertical byte layout? I know on the SSDBM you said height must be multiple of 8 which I have been adhering to. I'll either stick to using the SSDBM with this driver as it seems to do exactly what I need or revise the bitmaps to make width a multiple of 8.
    Shawn
  9. #89
    i have had a look at how those programs [lcdassist and glcd tool] manage the remainder bits when a bitmap is not an 8bit multiple in width
    and it defeats me , i cannot get how the "stray" bits of the image width are packed into the data
    if you lay the data out to match the actual width x height as i have done here
    [the last column i filled in manually only partially to get an idea of what the data needs to look like ]
    the "left over" 48 bytes at the end somehow represents the extreme rhs 6 bits , i don't see how to extract the data correctly.
    6 bits * 48 bytes is 384 bits , the stray 6 bits of width x 64 lines of height is 384 bits so there is enough information at least.
    [assuming i have not misconstrued the original image]
    OneIcon: '110x64 horiz
    @ db 112, 0x40
    @ db 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,0xfc
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,0x04
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0x00, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0x80, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0x80, 0x00, 0x00,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xC0, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xE0, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0xF0, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xF8, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFE, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0x00, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0x80, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0x80, 0x00  ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xC0, 0x00  ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xE0, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xF0, 0x00  ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFC, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFE, 0x00 ,0
    @ db 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0x80 ,0
    @ db 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0 ,0
    @ db 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8,0
    @ db 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC ,0
    @ db 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF  ,0
    '@ db 0xFC, 0x01, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x03, 0x00, 0x01, 0x00, 0x04, 0x00
    '@ db 0x00, 0x00, 0x03, 0x00, 0x03, 0x00, 0x01, 0x00, 0x11, 0x00, 0x00, 0x00, 0x18, 0x00, 0x01, 0x00
    '@ db 0x1A, 0x00, 0x04, 0x00, 0x28, 0x00, 0x02, 0x00, 0x38, 0x00, 0x00, 0x00, 0x4A, 0x02, 0x00, 0x00
    Apr 2007
    Pennsylvania, USA
    Is there a way to do 90 degree screen rotation (using the display in portrait mode) for the text using fonts to be displayed correct?
    Changing the SSDc $20 address to $01 seems to corrupt everything, so I'm not sure if I am going down the correct path with that, or if there is a simple way to accomplish this already built in?
    Shawn
  11. #91
    Apr 2007
    Pennsylvania, USA
    The display layout still isn't quite right. Here is a simple program that displays a 16x16 image in all 4 corners the ones on the left side are good, but the right side locations are wrong.
    'PIC18F26K22
      CONFIG  PLLCFG = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    DEFINE OSC 64
        clear
        width  con 128
        height con 64
        h_offset con 0
        BUFF     VAR BYTE[32]
        ANSELB=0
        ANSELC=0
        ANSELA=0
        OSCCON=$70
        OSCTUNE.6=1
        gosub glcd_init
        gosub grf_clr
        gosub show
    main:     ' Rotate icon clockwise around display corners
        DMDBMP 0,0,TestIcon       'top left 16x16 CORRECT PLACEMENT!
        gosub show
        gosub grf_clr
        gosub show
        DMDBMP 111,0,TestIcon       'top right 16x16 WRONT PLACEMENT!
        gosub show
        gosub grf_clr
        gosub show
        DMDBMP 111,47,TestIcon       'bottom right 16x16 WRONG PLACEMENT!
        gosub show
        gosub grf_clr
        gosub show
        DMDBMP 0,47,TestIcon       'bottom left 16x16 CORRECT PLACEMENT!
        gosub show
        gosub grf_clr
        gosub show
    TestIcon:
    @ db 0x10,0x10 ;16x16
    @ db 0xFF,0xFF;
    @ db 0xC0,0x03;
    @ db 0xA0,0x05;
    @ db 0x90,0x09;
    @ db 0x88,0x11;
    @ db 0x84,0x21;
    @ db 0x82,0x41;
    @ db 0x81,0x81;
    @ db 0x81,0x81;
    @ db 0x82,0x41;
    @ db 0x84,0x21;
    @ db 0x88,0x11;
    @ db 0x90,0x09;
    @ db 0xA0,0x05;
    @ db 0xC0,0x03;
    @ db 0xFF,0xFF;
Size:  310.6 KB Name:  Untitled-2.jpg
Size:  292.2 KB Name:  Untitled-3.jpg
Size:  280.0 KB Name:  Untitled-4.jpg
    Shawn
  12. #92
    bmp placement fixed , note that horiz placement is byte aligned ie for a 128 bit wide display there are 16 bytes therefore 16 positions max
    Apr 2007
    Pennsylvania, USA
    Excellent! All seems to be working perfectly!
    Now, how can I rotate the display for use in portrait mode?
    Shawn
  14. #94
    in theory portrait mode should be easier and faster than what i have now, the screen width 64 height 128
    and the buffer sent to the screen in horiz fill mode nice and sequentially [ might need bit reversal, could be upside down or mirrored]
    i will have a look one day time permitting
    a portrait version
    '*  Name    : SSD1306p.pbpmod                                          *
    '*  Author  : richard                                                 *
    '*  Notice  : Copyright (c) 2021                                      *
    '*  Date    : 28/12/2023                                              *
    '*  Version : 1.1                                                     *
    '*  Notes   : generic GRX graphics DRIVER FOR SSD1306                 *
    '*          :  HW I2C PIC18 ONLY                                      *
    '*          :  40x72 disp added                                       *
    '*          :    portrait version                                                     *
           ;set these  to match display IN MAIN
    '    ssd1306_addr con $78
    '    #DEFINE colours 1   ;1 mono 2 rg or 3 rgb
    '    width  con 128
    '    height con 32
    '    h_offset con 0   ;28 for 40x72
        glrot       var byte[8]
        glrb        var byte[8]
        gltmp       var byte[3]
        glcd_rad    var WORD
        glcdData    VAR byte  'DATA
        glcdBC      VAR BYTE  'gca  var
        page        VAR WORD  'gca  var
        gy          var byte  'gca  pg   address
        gy_         var byte  'gca  pg   address
        gx          var byte  'gca  row  address
        gx_         var byte  'gca  row  address
        ssd_add     var byte
        USERCOMMAND "SENDBYTE"     ;BYTE
        USERCOMMAND "SSDC"      ;cmd BYTE TO SSD1306
        ssdheight con WIDTH/8-1      ; 7 = 8 PAGES  64*128 ,  3 = 4 pages 32*128
        ssdwidth  con HEIGHT-1    ; 128 PIXELS WIDE
    goto overssd
    SSDC?C  macro Cin
        MOVE?CB  Cin , _glcdData
        L?CALL   _cmd_byte
    SSDC?B  macro Cin
        MOVE?BB  Cin , _glcdData
        L?CALL   _cmd_byte
    SENDBYTE?B  macro Dat
        MOVE?BB    Dat ,_glcdData
        L?CALL _send_byte
    SENDBYTE?W  macro Dat
        MOVE?WB    Dat ,_glcdData
        L?CALL _send_byte
    SENDBYTE?C  macro Dat
        MOVE?CB    Dat ,_glcdData
        L?CALL _send_byte
    glcd_init:
        bgcolour = 0
        colour  = 1
        SSPSTAT = 0 'High Speed Filter
        SSPADD = $14'400 kHz @64 MHz  ?
        SSPCON1 = 101000 'I2C Master Mode Enable
        SSPCON3 = 0
        ssd_add = ssd1306_addr
        SSDc $AE ' Display OFF
        SSDc $d5
        SSDc $80
        SSDc $a8 : SSDc $3f
        SSDc $D3 : SSDc $00 ; Set Display Offset Mode Set 0
        if ssdheight > 4  then
            SSDc $40   ' Set display start line 0
        elseif ssdheight > 3  then
            SSDc $68   ' Set display start line
            SSDc $60   ' Set display start line 4
        SSDc $8D : SSDc $14 ' Set Charge Pump Internal
        SSDc $20 : SSDc $01 ' Adressing mode Horizontal
        SSDc $A1   ' set segment remap column 127 as start
        SSDc $C0   ' Com Scan Direction, Flip display vertically
        SSDc $DA   ' set COM pins
            SSDc$12  ' set COM pins = 128x64=$12
            SSDc$02  ' set COM pins = 128x32=$02
        SSDc $81 : SSDc$7F  ' Set brightness to $01 to $FF  ($7F is default, $01 is faint)
        SSDc $DB : SSDc$40  ' Set VCOM Deselect Level
        SSDc $B0  ' Set Page Address From $B0 to $B7
        SSDc $2e  ; scroll off
        SSDc $A4  ' display ON continue
        SSDc $A6  ' $A6=NORMAL MODE;  $A7=INVERSE MODE
        SSDc $AF  ' Display ON
    show:
    '    gosub flip
        SSDc $22
        SSDc  0
        SSDc  ssdheight
        SSDc $21
        SSDc  h_offset
        SSDc  ssdwidth + h_offset
        SSPCON2.0 = 1 ; SEN - Start Condition Enable Bit
        WHILE SSPCON2.0 = 1 : WEND ; Wait for Start to complete
        SSPBUF = ssd_add ; Move data to SSPBUF
        WHILE SSP1STAT.2 = 1 : WEND ; SSPSTAT = 1 Transmit in progress
        While SSP1CON2.6 = 1 : WEND ; Wait for Acknowledge from slave
        SSPBUF = $40 ; Move data to SSPBUF
        WHILE SSPSTAT.2 = 1 : WEND ; SSPSTAT = 1 Transmit in progress
        While SSPCON2.6 = 1 : WEND ; Wait for Acknowledge from slave
        for glcd_rad = 0 to  width/8 * height -1
            SENDBYTE fbr[glcd_rad ]
        next
        SSPCON2.2 = 1
    '    gosub flip
    send_byte :  'DATA
        SSPBUF = glcdData; Move data to SSPBUF
    cmd_byte:  'send command sequence "glcdData "
        SSPBUF = 0 ; Move data to SSPBUF
        SSPBUF = glcdData ; Move data to SSPBUF
        SSPCON2.2 = 1 ; PEN - send stop bit
        While SSP1CON2.2 = 1 : Wend ; Wait for SSP to complete
     overssd:
    with demo
    'PIC18F26K22#CONFIG
      CONFIG  PLLCFG = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    DEFINE OSC 64
        clear
        width  con 64
        height con 128
        h_offset con 0
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        LATB.7=1
        trisb.7=0
        include "SSD1306p.pbpMOD"
        include "font.bas"
        BUFF     VAR BYTE[32]
        ANSELB=0
        ANSELC=0
        ANSELA=0
        OSCCON=$70
        OSCTUNE.6=1
        SETFONT FONT5x7
        gosub glcd_init
       gosub grf_clr
        gosub show
        ARRAYWRITE BUFF,["GLCD",0]
        DMDSTR 3,75,buff,1
        DMDBMP 0,0,TestIcon
        gosub show
        pause 5000
    TestIcon:
    @ db 0xFF,0xFF;
    @ db 0xC0,0x03;
    @ db 0xA0,0x05;
    @ db 0x90,0x09;
    @ db 0x88,0x11;
    @ db 0x84,0x21;
    @ db 0x82,0x41;
    @ db 0x81,0x81;
    @ db 0x81,0x81;
    @ db 0x82,0x41;
    @ db 0x84,0x21;
    @ db 0x88,0x11;
    @ db 0x90,0x09;
    @ db 0xA0,0x05;
    @ db 0xC0,0x03;
    @ db 0xFF,0xFF;
    Apr 2007
    Pennsylvania, USA
    Excellent work Richard!!!
    This will work well for my use, but with a little more tweaking it would be nice to have a define to set 1 of 4 different viewing directions to make a more universal driver.
    Shawn
  1. Replies: 3
    Last Post: - 1st January 2021, 21:28
  2. problem using Graphical LCD
    By Mostafa in forum mel PIC BASIC Pro
    Last Post: - 18th July 2007, 18:15
  3. Graphical LCDs
    By T.Jackson in forum General
    Last Post: - 14th May 2007, 06:29
  4. Vb 6.0 Graphical plug in
    By rocky79 in forum Serial
    Last Post: - 8th March 2006, 18:42
  5. Graphical user interface
    By rocky79 in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 12:25
Members who have read this thread : 18
