Variables change depending on a SEROUT2 command placement in code
Results 1 to 3 of 3
    SWITZERLAND (french speaking)
    Default Variables change depending on a SEROUT2 command placement in code
    Hi all,
    I've been spending a few hours now (this is an euphemism, of course ) on trying to find out why the program I'm currently working on has his variables "changing" values without any obvious reason.
    Let me explain.
    In this first image, the green field shows correct values and the red one, the wrong values. Amazingly, the program works (by chance...) but the reported values by the SEROUT command are wrong (in the "red" case).
    These values change depending on the placement of a few lines of code as you can see herunder.
    Correct
    NOT Correct
    So, is there any scientific reason why my values change depending on the placement of the DEBUG (yellow frame) lines?
    The variables Now and Prev are declared as BYTE and have respectively values 15 and 255 at program startup.
    Thanks for any explanation that will stop me jump out of my window!!! Okay, I leave on the groundfloor...
    Roger
    Bombay, India
    Default Re: Variables change depending on a SEROUT2 command placement in code
    Your Key_Cnt variable increments inside the IF condition and therefore, placing the SEROUT statement before the IF works correctly.
    You need to investigate that IF statement with this in mind.
    Thanks a lot Jerson
    Roger
  1. Change variable allocation to save code space
    By aberco in forum mel PIC BASIC Pro
    Last Post: - 5th September 2011, 01:28
  2. SERIN2, SEROUT2 with long variables
    By pedja089 in forum mel PIC BASIC Pro
    Last Post: - 18th November 2010, 23:22
  3. Serial code placement
    By nirvdrum in forum Serial
    Last Post: - 9th January 2007, 18:58
  4. Embedding Variables into Code Memory
    By JoeSolar in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 17:58
  5. oscillator code and placement within program
    By bartman in forum mel PIC BASIC
    Last Post: - 14th December 2004, 02:39
