Howdy.... I've been trying to get a light dimmer working now for about a week. I did a good bit of reading about using a triac and zero cross over detector prior to taking on this project but I'm stuck
I believe I have all the correct code and can see on my scope things look good I'm including a picture.
What we see here on the scope is the 120vac wave along with my trigger output based on getting triggered at the zero crossover point.
I'm using INT on the 12F683 and on interrupt to detect the zero crossover from an H11AA1 and then triggering a pulse out for 1500 microseconds which you can see here. So far so good this looked great to me. I am feeding this pulse to an MOC3011M in turn using the MOC3011M to trigger the gate on a BT136/BT137 (I've tried both) however even though I am only feeding what looks like an "On" pulse for 1500 microseconds the bulb appears full on no matter what I do. The logic in the on interrupt routine is pretty basic for the time being.
light=1
pauseus 1500
light=0
I'm beginning to think that the triacs I have chosen. Any ideas what type of triac I should be using if someone out there has successfully gotten this to work. If anyone has any thoughts and/or would like to see my code and schematic if they think this will help I can upload those. I'm not sure if it is my programming or schematic since I am getting a good interrupt triggering pretty much dead on the zero crossing and in turn able to turn on an output for a period of time at that zero cross over point.
David
