Tiny bootloader and pbp
Results 1 to 27 of 27
    Feb 2012
    PERTH AUSTRALIA
    Default Tiny bootloader and pbp
    hi guys ,
    i would like to try to use the tiny bootloader and PBP to make the bootloader hex file ,
    has anyone an example of how to make this work for 18f67k22 chip , or k40 chip series
    cheers
    sheldon
    Default Re: Tiny bootloader and pbp
    Sheldon, Just modify this file extension from .txt to .asm. Then modify for the frequency and chip config and then assemble with MPLABX to get the .hex file for flashing. Then use TinyMultiBootLoader.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    hi dave
    yes found the file as part of the references for tiny bootloader
    i have mplabx , but compiler for pbp loaded only
    it appears to need c compiler ??
    would like to rewrite file so that is loaded as pbp file and compile in pbp , where i can take a copy of the my existing chip structure and make the hex file
    doing this approach allows for an easy migration of other chips support for the bootloader using pbp
    have you a version example that could be used in pbp to make the hex file
    Sheldon, You don't have to compile it as the source ia already an .ASM file. It only needs to be assembled with MPLABX. That will give you an .HEX BootLoader file that needs to be FLASHED into the processor.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    sent you PM on this
    cheers
    sheldon
    Sheldon, Where did you get the .ASM file for the processor? Looking at and comparing the two different files the one that you modified is rather old from 2016.01.15 revision 5 and the one I sent you is from 2018.04.18 revision 6. There are only a few values that need to be changed for it to assemble.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    it was with the version from the download site
    Feb 2012
    PERTH AUSTRALIA
    bootloader pc v0.11.2.11
    https://sourceforge.net/projects/tinypicbootload/
    https://sourceforge.net/p/tinypicboo...z_19200_r5.asm
    lookd like the ver you have is not the same as i have found on the download site
    can you link me to where you found that version and the other files ?
    Feb 2012
    PERTH AUSTRALIA
    ok have have used your asm and filled it it
    here the results - i am assuming i have the got mplab setup correctly
    radix DEC
    list  p=18f87k22
    	; change these lines accordingly to your application
    #include "pic18f87k22.inc"
    IdTypePIC = 0x6F		; Please refer to the table below, must exists in "piccodes.ini"
    #define max_flash  0x20000	; in WORDS, not bytes!!! (= 'max flash memory' from "piccodes.ini" divided by 2), Please refer to the table below
    #define	SELECTEUSART 1		; EUSART(1/2), Please refer to the table below
    #define	PDIP 80			; PIN Count of Device (64/80), Please refer to the table below
    xtal 	EQU 	64000000	; you may also want to change: _HS_OSC _XT_OSC
    baud 	EQU 	19200		; standard TinyBld baud rates: 115200 or 19200
    ;   The above 7 lines can be changed and buid a bootloader for the desired frequency (and PIC type)
    ; |IdTypePIC| Device | Write_Page | Erase_Page |   TX1/TX2   |   RX1/RX2   | max_flash | EEPROM | TQFP |
    ; |   0x6C  |18F65K22|  32 words  |  32 words  |C6(31)/G1(4) |C7(32)/G2(5) |   0x8000  |  1024  |  64  |
    ; |   0x6C  |18F85K22|  32 words  |  32 words  |C6(37)/G1(6) |C7(38)/G2(7) |   0x8000  |  1024  |  80  |
    ; |   0x66  |18F66K22|  32 words  |  32 words  |C6(31)/G1(4) |C7(32)/G2(5) |  0x10000  |  1024  |  64  |
    ; |   0x66  |18F86K22|  32 words  |  32 words  |C6(37)/G1(6) |C7(38)/G2(7) |  0x10000  |  1024  |  80  |
    ; |   0x6F  |18F67K22|  64 words  |  64 words  |C6(31)/G1(4) |C7(32)/G2(5) |  0x20000  |  1024  |  64  |
    ; |   0x6F  |18F87K22|  64 words  |  64 words  |C6(37)/G1(6) |C7(38)/G2(7) |  0x20000  |  1024  |  80  |
     #IF (SELECTEUSART == 1)
    #define _TXSTA TXSTA1
    #define _SPBRG SPBRG1
    #define _RCSTA RCSTA1
    #define _TXREG TXREG1
    #define _PIR PIR1
    #define _RCIF RC1IF
     #ELSE
    #define _TXSTA TXSTA2
    #define _SPBRG SPBRG2
    #define _RCSTA RCSTA2
    #define _TXREG TXREG2
    #define _PIR PIR3
    #define _RCIF RC2IF
     #ENDIF
    	;	Tiny Bootloader		18F6XK22/18F8XK22   Size=100/132words
            ;       [email protected]
            ;       http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
    	;	(2018.04.18 Revision 6)
    	;	This program is only available in Tiny Multi Bootloader +.
    	;	Tiny Multi Bootloader +
    	;	https://sourceforge.net/projects/tinypicbootload/
    	#include "spbrgselect.inc"	; RoundResult and baud_rate
    #if(IdTypePIC == 0x6F)
    		#define first_address max_flash-264		;132 words
    #else
    		#define first_address max_flash-200		;100 words
    #endif
    	;Setup CONFIG1L
    		config RETEN = ON	;Enabled - Controlled by SRETEN bit
    		config INTOSCSEL = HIGH	;LF-INTOSC in High-power mode during Sleep
    		config SOSCSEL = DIG	; Digital (SCLKI) mode; I/O port functionality of RC0 and RC1 is enabled
    		config XINST = OFF	;Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    	;Setup CONFIG1H
    		config FOSC = HS2	; HS oscillator (High power, 16 MHz - 25 MHz) - makes OSC1 input PREAMP active for TCXO 16.386 0.8VPP
    		config PLLCFG = ON	;PLL x4 Enable bit Disabled
    		config FCMEN = OFF	;Fail-Safe Clock Monitor disabled
    		config IESO = OFF	;Oscillator Switchover mode disabled
    	;Setup CONFIG2L
    		config PWRTEN = ON	;PWRT enabled
    		config BOREN = SBORDIS  ; Enabled in hardware, SBOREN disabled
    		config BORV = 2		;VBOR set to 2 V nominal
    		config BORPWR = ZPBORMV ; ZPBORMV instead of BORMV is selected
    	;Setup CONFIG2H
    		config WDTEN = ON	;WDT is controlled by SWDTEN bit of the WDTCON register
    		config WDTPS = 512	;Watchdog Timer Postscale Select bits 1:512
    	;Setup CONFIG3L
    		config RTCOSC = SOSCREF	;RTCC uses SOSC
    #if (PDIP == 80)
    		config EASHFT = ON	;Address Shifting ENABLED
    		config ABW = MM         ;Microprocessor mode , External Memory bus not used - allows portsD,E,H,J  for I/O use
                                            ;MM = also ignores MEMCON.7=0 (default POR)  setting for EMB use
    		config BW = 16		;16-bit external bus mode
    		config WAIT = OFF	;Disabled
    #endif
    	;Setup CONFIG3H
    		config CCP2MX = PORTC	;CCP2 input/output is multiplexed with RC1
    #if (PDIP == 80)
    		config ECCPMX = PORTE	;Enhanced CCP1/3 [P1B/P1C/P3B/P3C] muxed with RE6/RE5/RE4/RE3
    #endif
    		config MSSPMSK = MSK7	;7 Bit address masking mode
    		config MCLRE = ON	;MCLR pin enabled RG5 input pin disabled
    	;Setup CONFIG4L
    		config STVREN = OFF	;Stack full/underflow will not cause Reset
    		config BBSIZ = BB1K	;1K word Boot Block size
    		config DEBUG = OFF	;Background debugger disabled, RA0 and RA1 configured as general purpose I/O pins
    	;Setup CONFIG5L
    		config CP0 = ON		;  MEMORY BLOCK 0 CODE PROTECT BIT - 7KW 800h  - 3FFFh ( when 1K BOOT OPTION used )
    		config CP1 = ON         ;  MEMORY BLOCK 1 CODE PROTECT BIT - 8KW 4000h - 7FFFh
    		config CP2 = ON         ;  MEMORY BLOCK 2 CODE PROTECT BIT - 8KW 8000h - BFFFh
                    config CP3 = ON         ;  MEMORY BLOCK 3 CODE PROTECT BIT - 8KW C000h - FFFFh
    #if (IdTypePIC == 0x6F)
    		config CP4 = ON         ;  MEMORY BLOCK 4 CODE PROTECT BIT - 8KW 10000h - 12FFFh
    		config CP5 = ON         ;  MEMORY BLOCK 5 CODE PROTECT BIT - 8KW 14000h - 17FFFh
    		config CP6 = ON         ;  MEMORY BLOCK 6 CODE PROTECT BIT - 8KW 18000h - 1BFFFh
    		config CP7 = ON         ;  MEMORY BLOCK 7 CODE PROTECT BIT - 8KW 1C000h - 1FFFFh
    #endif
    	;Setup CONFIG5H
    		config CPB = OFF	;Boot block not code-protected
    		config CPD = ON		;Data EEPROM  code-protected
    	;Setup CONFIG6L
    		config WRT0 = OFF	;Block 0 not write-protected
    		config WRT1 = OFF	;Block 1 not write-protected
    		config WRT2 = OFF	;Block 2 not write-protected
    		config WRT3 = OFF	;Block 3 not write-protected
    		config WRT4 = OFF	;Block 4 not write-protected
    		config WRT5 = OFF	;Block 5 not write-protected
    		config WRT6 = OFF	;Block 6 not write-protected
    		config WRT7 = OFF	;Block 7 not write-protected
    #endif
    	;Setup CONFIG6H
    		config WRTC = ON	;Configuration registers write-protected
    		config WRTB = ON	;Boot block write-protected
    		config WRTD = OFF	;Data EEPROM not write-protected
    	;Setup CONFIG7L
    		config EBRT0 = OFF	;Block 0 not protected from table reads executed in other blocks
    		config EBRT1 = OFF	;Block 1 not protected from table reads executed in other blocks
    		config EBRT2 = OFF	;Block 2 not protected from table reads executed in other blocks
    		config EBRT3 = OFF	;Block 3 not protected from table reads executed in other blocks
    		config EBRT4 = OFF	;Block 4 not protected from table reads executed in other blocks
    		config EBRT5 = OFF	;Block 5 not protected from table reads executed in other blocks
    		config EBRT6 = OFF	;Block 6 not protected from table reads executed in other blocks
    		config EBRT7 = OFF	;Block 7 not protected from table reads executed in other blocks
    #endif
    	;Setup CONFIG7H
    		config EBRTB = OFF	;Boot block not protected from table reads executed in other blocks
    ;----------------------------- PROGRAM ---------------------------------
    	cblock 0
    	buffer:14
    	crc
    	i
    	flag
    	cnt1
    	cnt2
    	cnt3
    	endc
    ;0000000000000000000000000 RESET 00000000000000000000000000
    		ORG     0x0000
    		GOTO    IntrareBootloader
    ;view with TabSize=4
    ;&&&&&&&&&&&&&&&&&&&&&&&   START     &&&&&&&&&&&&&&&&&&&&&&
    ;----------------------  Bootloader  ----------------------
    ;PC_flash:		C1h		U		H		L		64/128  ... <64/128 bytes> ...  crc
    ;PC_eeprom:		C1h		40h   		EEADRH  	EEADR   	1		EEDATA		crc
    ;PC_cfg			C1h		U OR 80h	H		L		14  ... <14 bytes>   ...  crc
    ;PIC_response:	   type `K`
    	ORG first_address			;space to deposit first 4 instr. of user prog.
    	nop
    	nop
    	nop
    	nop
    	org first_address+8
    IntrareBootloader:
    						;Init int clock & serial port
    	lfsr	FSR1,_TXREG			;FAR1 = TXREG1 or TXREG2
    	bsf	OSCCON,IRCF0			;int clock 16MHz
    #if (SELECTEUSART == 2)
    	movlb	.15				;bank0 -> bank15
    	clrf	ANCON2,BANKED	  		; setup digital I/O
    #endif
    	movlw 	((1<<TXEN) | (1<<BRGH))		;init serial port
    	movwf 	_TXSTA,BANKED
    	movlw	spbrg_value
    	movwf	_SPBRG,BANKED
    	movlw	((1<<SPEN) | (1<<CREN))
    	movwf	_RCSTA,BANKED
    	movlb	.0				;bank15 -> bank0
    						;wait for computer
    	rcall 	Receive
    	sublw 	0xC1				;Expect C1h
    	bnz 	way_to_exit
    	movlw   IdTypePIC			;send PIC type
    	movwf   INDF1
    MainLoop:
    	movlw 	'C'				; "-Everything OK, ready and waiting."
    mainl:
    	movwf   INDF1
    	clrf 	crc
    	rcall 	Receive				;Upper
    	movwf 	TBLPTRU
    	movwf 	flag
    	rcall 	Receive				;High
    	movwf 	TBLPTRH
    	movwf 	EEADRH				;(for EEPROM case)
    	rcall 	Receive				;Low
    	movwf 	TBLPTRL
    	movwf 	EEADR				;(for EEPROM case)
    	rcall 	Receive				;Count
    	movwf 	i
    	clrf	FSR0L				;FSR0 = Buffer TOP
    	tblrd*-					;TBLPTR = TBLPTR - 1
    rcvoct:
    	rcall 	Receive
    	btfsc 	flag,7				;Skip if not Config
    	movwf 	POSTINC0			;(for Config case)
    	movwf 	EEDATA				;(for EEPROM case)
    	movwf 	TABLAT				;(for PFM case)
    	tblwt+*
    	decfsz 	i,F
    	bra 	rcvoct
    	rcall 	Receive				;CRC
    ziieroare:					;CRC failed
    	movlw	'N'
    	bnz	mainl
    	bra	wr_cfg				;Write Config
    	movlw 	(1<<WREN)			;Setup EEPROM
    	btfss 	flag,6				;Skip if EEPROM
    	rcall 	Erase
    	rcall 	Write
    	bra 	MainLoop
    wr_cfg:
    	decf	FSR0L,F				;FSR0 = FSR0 - 1
    	movf	INDF0,W				;Set TABLAT
    	movwf	TABLAT
    	movlw	((1<<EEPGD)|(1<<CFGS)|(1<<WREN));Setup cfg
    	rcall 	Write
    	tstfsz	FSR0L				;FSR0L = 0 ?
    	bra	wr_cfg
    	bra 	MainLoop
    ;************************ Subroutines ************************
    Erase:
    	movlw	((1<<EEPGD)|(1<<FREE)|(1<<WREN)); Setup erase
    Write:
    	movwf	EECON1
    	movlw	0x55
    	movwf 	EECON2
    	movlw 	0xAA
    	movwf 	EECON2
    	bsf 	EECON1,WR
    	retlw	((1<<EEPGD)|(1<<WREN))		; Setup writes
    Receive:
    	movlw 	(xtal/2000000+1)		; for 20MHz => 11 => 1second delay
    	movwf 	cnt1
    rpt2:
    	clrf 	cnt2
    rpt3:
    	clrf 	cnt3
    rptc:
    	btfss 	_PIR,_RCIF			;test RX
    	bra 	notrcv
    	incf	FSR1L,F				;FSR1 = RCREG1 or RCREG2 -> TXREG1 or TXREG2
    	movf 	POSTDEC1,W			;return read data in W
    	addwf 	crc,F				;compute crc
    notrcv:
    	decfsz 	cnt3,F
    	bra 	rptc
    	decfsz 	cnt2,F
    	bra 	rpt3
    	decfsz 	cnt1,F
    	bra 	rpt2
    						;timeout
    way_to_exit:
    	clrf	EECON1				; deactivate EECON
    	movlb	.15
    	bcf	_SPBRG,SPEN			; deactivate UART
    	movlb	.0
    	bra	first_address
    ; After reset
    ; Do not expect the memory to be zero,
    ; Do not expect registers to be initialised like in catalog.
    Errors shown when build done
    ake -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory 'C:/Users/SMW OFFICE/MPLABXProjects/bootloader18f87k22.X'
    make  -f nbproject/Makefile-default.mk dist/default/production/bootloader18f87k22.X.production.hex
    make[2]: Entering directory 'C:/Users/SMW OFFICE/MPLABXProjects/bootloader18f87k22.X'
    "C:\Program Files\Microchip\xc8\v2.20\bin\xc8-cc.exe" -c  -mcpu=18F87K22   -mdfp="C:/Program Files (x86)/Microchip/MPLABX/v5.40/packs/Microchip/PIC18F-K_DFP/1.4.87/xc8"  -fno-short-double -fno-short-float -memi=wordwrite -O0 -maddrqual=ignore -xassembler-with-cpp -I"../../.mchp_packs/Microchip/PIC18F-K_DFP/1.3.84/xc8/pic/include/proc" -mwarn=-3 -Wa,-a -DXPRJ_default=default  -msummary=-psect,-class,+mem,-hex,-file  -ginhx032 -Wl,--data-init -mno-keep-startup -mno-download -mdefault-config-bits -std=c99 -gdwarf-3 -mstack=compiled:auto:auto:auto   -o build/default/production/_ext/1392730598/tinybootloadersmw18f87k22.o  ../../PROJECTS/tinybootloadersmw18f87k22.asm
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:34:9: warning: '_TXSTA' macro redefined [-Wmacro-redefined]
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:27:9: note: previous definition is here
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:35:9: warning: '_SPBRG' macro redefined [-Wmacro-redefined]
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:28:9: note: previous definition is here
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:36:9: warning: '_RCSTA' macro redefined [-Wmacro-redefined]
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:29:9: note: previous definition is here
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:37:9: warning: '_TXREG' macro redefined [-Wmacro-redefined]
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:30:9: note: previous definition is here
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:38:9: warning: '_PIR' macro redefined [-Wmacro-redefined]
    #define _PIR PIR3
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:31:9: note: previous definition is here
    #define _PIR PIR1
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:39:9: warning: '_RCIF' macro redefined [-Wmacro-redefined]
    #define _RCIF RC2IF
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:32:9: note: previous definition is here
    #define _RCIF RC1IF
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:55:29: warning: extra tokens at end of #include directive [-Wextra-tokens]
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:82:6: error: token is not a valid binary operator in a preprocessor subexpression
    #if (PDIP == 80)
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:8:19: note: expanded from macro 'PDIP'
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:91:6: error: token is not a valid binary operator in a preprocessor subexpression
    #if (PDIP == 80)
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:180:6: error: token is not a valid binary operator in a preprocessor subexpression
    ../../PROJECTS/tinybootloadersmw18f87k22.asm:7:25: note: expanded from macro 'SELECTEUSART'
    7 warnings and 3 errors generated.
    (908) exit status = 1
    nbproject/Makefile-default.mk:113: recipe for target 'build/default/production/_ext/1392730598/tinybootloadersmw18f87k22.o' failed
    make[2]: Leaving directory 'C:/Users/SMW OFFICE/MPLABXProjects/bootloader18f87k22.X'
    nbproject/Makefile-default.mk:91: recipe for target '.build-conf' failed
    make[1]: Leaving directory 'C:/Users/SMW OFFICE/MPLABXProjects/bootloader18f87k22.X'
    nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
    make[2]: *** [build/default/production/_ext/1392730598/tinybootloadersmw18f87k22.o] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    BUILD FAILED (exit value 2, total time: 1s)
    if you aren't using some ancient version of mplab then use
    #include "p18f87k22.inc" not #include "pic18f87k22.inc"
    Feb 2012
    PERTH AUSTRALIA
    hi richard
    using xc8 ver 2.20 - latest i believe -
    path for include show no "p18f87k22.inc" , only "pic18f87k22.inc"
    unless there is another location to look for this include ?
    its not C , its asm
    Sheldon, Here is the source directory I use here. The forum does not allow files bigger than 1M so I can't send you the x0.11.2 executable.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    thanks richard
    made me go back and have a look at the files in 5.40 mplab , there is no /mpasmx directory , and i checked this 2 times by re downloading ver 5.40 being the latest version
    i made the error or removing prev versions of mplab because of updating to the latest version
    so now have reinstalled 5.35 , which is last version and has /mpasmx directory , and has mpasm.exe ver 5.87 , which appears to be the last version available from now on ???
    after adding it to the tool chain , mplab complains that the mpasm is not supported in 64 bit systems and to migrate the project or use earlier ide
    its seems microchip use of mpasmx for the 8bit chips is to be dropped
    This appears to now assemble the tinybootloader file
    still like to know where dave found those files as i cant find them on the source download
    see if the pc software see it after its loaded
    Feb 2012
    PERTH AUSTRALIA
    thanks dave
    i have pc software from the main download site
    Feb 2012
    PERTH AUSTRALIA
    dave , the asm asked for Xtal value , it this the real value of the external xtl of 16000000hz or the PPL4 of 64000000 value ???
    Feb 2012
    PERTH AUSTRALIA
    dave
    my pic config has currently set to protect memory , is this a problem for the bootloader ?
    also what changes need to be done to the pbp code to allow bootloader to work , i have read that addtional defines are required for other bootloaders such as
    DEFINE LOADER_USED 1
    DEFINE RESET_ORG 800h ' For Microchip USB Bootloader
    DEFINE INTERRUPT_ORG 808h ' For Microchip USB Bootloader
    are these required for tiny bootloader ???
    radix DEC
    list  p=18f87k22
    #define _PIR PIR1
    #define _RCIF RC1IF
     #ELSE
    #define _PIR PIR3
    #define _RCIF RC2IF
     #ENDIF
            ;       [email protected]
    #else
    #endif
    	;Setup CONFIG1L
    	;Setup CONFIG1H
    	;Setup CONFIG2L
    	;Setup CONFIG2H
    	;Setup CONFIG3L
    #if (PDIP == 80)
    #endif
    	;Setup CONFIG3H
    #if (PDIP == 80)
    #endif
    	;Setup CONFIG4L
    	;Setup CONFIG5L
    #endif
    	;Setup CONFIG5H
    	;Setup CONFIG6L
    #endif
    	;Setup CONFIG6H
    	;Setup CONFIG7L
    #endif
    	;Setup CONFIG7H
    	cblock 0
    	buffer:14
    	crc
    	i
    	flag
    	cnt1
    	cnt2
    	cnt3
    	endc
    		ORG     0x0000
    	nop
    	nop
    	nop
    	nop
    	org first_address+8
    IntrareBootloader:
    #endif
    	movwf 	_TXSTA,BANKED
    	movlw	spbrg_value
    	movwf	_SPBRG,BANKED
    	movwf	_RCSTA,BANKED
    						;wait for computer
    	rcall 	Receive
    	bnz 	way_to_exit
    	movwf   INDF1
    MainLoop:
    mainl:
    	movwf   INDF1
    	clrf 	crc
    	movwf 	TBLPTRU
    	movwf 	flag
    	rcall 	Receive				;High
    	movwf 	TBLPTRH
    	rcall 	Receive				;Low
    	movwf 	TBLPTRL
    	movwf 	i
    rcvoct:
    	rcall 	Receive
    	tblwt+*
    	decfsz 	i,F
    	bra 	rcvoct
    	rcall 	Receive				;CRC
    	movlw	'N'
    	bnz	mainl
    	rcall 	Erase
    	rcall 	Write
    	bra 	MainLoop
    wr_cfg:
    	movwf	TABLAT
    	rcall 	Write
    	bra	wr_cfg
    	bra 	MainLoop
    Erase:
    Write:
    	movwf	EECON1
    	movlw	0x55
    	movwf 	EECON2
    	movlw 	0xAA
    	movwf 	EECON2
    	bsf 	EECON1,WR
    Receive:
    	movwf 	cnt1
    rpt2:
    	clrf 	cnt2
    rpt3:
    	clrf 	cnt3
    rptc:
    	bra 	notrcv
    notrcv:
    	decfsz 	cnt3,F
    	bra 	rptc
    	decfsz 	cnt2,F
    	bra 	rpt3
    	decfsz 	cnt1,F
    	bra 	rpt2
    						;timeout
    way_to_exit:
    	movlb	.15
    	movlb	.0
    	bra	first_address
    ; After reset
    IntrareBootloader:
    can't see how that will be ok
    1. at por OSCCON IRCF0 and IRCF0 are both set anyway and will not result in a 16mhz clock
    2. you have pll on selected in config so clk will be 64mhz yet no attempt is made to wait for pll ready state to establish
    Feb 2012
    PERTH AUSTRALIA
    richard
    YES , your correct , there is no test to see if the internal clock or in this case external tcxo is ready,
    in my normal pbp i there is wait to check this , but not in the bootloader code
    comment of 16 mhz is generic for the file , i not changed it
    Feb 2012
    PERTH AUSTRALIA
    loaded the file bootloader file , via programmer
    but the com port does not detect the device
    have no rts/dtr avaialble -
    used com7(usb interface) - usart1 19200 ( rx1 - rc7 pin , tx1 - rc6 pin)
    tried manual rest and remote signal - looking for 65,66,67 , which i am assuming the bootloader has setup somewhere , but i cant see it
    usart1 is connected to a usb to serial ttl converter ch340 driver
    removed all memory code protect in cchip config for bootloader , just as test
    any sugestions
    if you can't see it its likely not there.
    looks to me like the bootloader sits mute till the pc speaks
    the code says
    ;Expect C1h
    and responds
    ps, if you have not fixed the fosc problems it wont work anyway, at least post code of what you are trying
    Feb 2012
    PERTH AUSTRALIA
    the bootloader pc app does not see the bootloader code serial port - untill it does the other steps are mute
    i have removed my config and just used the base standard 18f87k22 chip confg - 16mhz internal , no PPL4 , no protection etc
    build asm with MASM 5.86 , with options as build in absolute mode , it has the correct hex format INHX32
    i have serveral other chip set of 18f46k80 , 18f47k40 to make this work on
    I have the referance dave given me for the 18f46k80 series , will need a k40 version
    so have built that with the default chip config setting for the 18f46k80, usart 2 19200 ( for this device)
    THE BOOTLOADER PC SOFTWARE SEE IT "Yay" on manual reset
    and it bootloader pc software finds the base code config
    so ill continue to work on 18f46k80 bootloader and put in my chip config
    I am still unclear what changes i need to make to my orignal pic code for the bootloader to allow it to work
    this is going to be long project stage i think
    cheers
    Sheldon, The only statement required for PBP is the "DEFINE LOADER_USED 1" at the top of the program.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    thanks dave
    prior to bootloader use and relating to the config of the pic protection memory blocks i had protected boot blocks
    and most of memory blocks
    which of these now cant be protected cos of the bootloader use ?
    which setting can be further locked down if using a bootloader ?
    ;----- CONFIG5L Options --------------------------------------------------
        CONFIG CP0       = ON         ;  MEMORY BLOCK 0 CODE PROTECT BIT - 7KW 800h  - 3FFFh ( when 1K BOOT OPTION used )
        CONFIG CP1       = ON         ;  MEMORY BLOCK 1 CODE PROTECT BIT - 8KW 4000h - 7FFFh
        CONFIG CP2       = ON         ;  MEMORY BLOCK 2 CODE PROTECT BIT - 8KW 8000h - BFFFh
        CONFIG CP3       = ON         ;  MEMORY BLOCK 3 CODE PROTECT BIT - 8KW C000h - FFFFh
    ;----- CONFIG5H Options --------------------------------------------------
       CONFIG  CPD       = OFF        ; EEPROM DATA PREOTECT BIT - EXTERNAL R/W
       CONFIG  CPB       = ON         ; BOOT BLOCK CODE PROTECT BIT
    ;----- CONFIG6L Options --------------------------------------------------
        CONFIG WRT0      = OFF        ; MEMORY BLOCK WRITE PROTECT BIT
        CONFIG WRT1      = OFF
        CONFIG WRT2      = OFF
        CONFIG WRT3      = OFF
    ;----- CONFIG6H Options --------------------------------------------------
        CONFIG WRTD      = OFF       ; EEPROM WRITE PROTECT BIT - INTERNAL AND EXTERNAL
        CONFIG WRTB      = ON        ; BOOT BLOCK WRITE PROTECT
        CONFIG WRTC      = ON        ; CONFIGURATION REGISTER WRITE PROTECT BIT
    ;----- CONFIG7L Options --------------------------------------------------
         CONFIG EBTR0     = OFF      ; MEMORY READ TABLE BLOCK PROTECT
         CONFIG EBTR1     = OFF
         CONFIG EBTR2     = OFF
         CONFIG EBTR3     = OFF
    ;----- CONFIG7H Options --------------------------------------------------
        CONFIG EBTRB     = OFF      ; TABLE READ PROTECT BOOT
    prior to bootloader
    Sheldon, This is the sheet for the 18F47K40 that I use here.
    EN82fn
    Feb 2012
    PERTH AUSTRALIA
    dave have you the asm code for MPLABX for the 18f27k40 used for the tiny bootloader
    i think as i am using the 47k40 theword values will be abit differnet
    Sheldon, Here is the .asm file I use here.
    EN82fn
  1. test tiny bootloader via bluetooth
    By hatuan291 in forum mel PIC BASIC Pro
    Last Post: - 13th September 2015, 13:35
  2. Replies: 1
    Last Post: - 2nd September 2014, 20:57
  3. Open source PBP bootloader
    By cncmachineguy in forum PBP Wish List
    Last Post: - 22nd March 2014, 18:34
  4. Tiny Bootloader 18F2420
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 31st March 2010, 17:32
  5. Tiny bootloader and 18F4525
    By Najim in forum Off Topic
    Last Post: - 11th January 2006, 11:43
Members who have read this thread : 4
