Comparator not tripping above 0.6V (Vref) on PIC 16F690
Results 1 to 4 of 4
    SWITZERLAND (french speaking)
    Default Comparator not tripping above 0.6V (Vref) on PIC 16F690
    Hi All,
    I'm struggeling to get my 16F690's comparator 2 output to trip when the measured voltage gets above 0.6V (for battery level monitoring).
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    ' Registers   76543210
    OPTION_REG = %10000000 ' PORT A&B Pull-Ups and Prescaler        (def.: %11111111)
    OSCCON     = %01100000 ' Internal Oscillator 4MHz               (def.: %01101000)
    TRISC      = %00001000 ' Set Input/Output (0 to 7)              (def.: %11111111)
    CM2CON0    = %10100011 ' Comparator2 Module                     (def.: %00000000)
    ' Bit1/C2ON = Comp C2 is ON
    ' Bit5/C2OE = Output is PORTC.4
    ' Bits1-0   = Input is PORTC.3
    VRCON      = %00110000
    ' Bit2/C2VREN = Comparator C2 voltage ref is ON
    ' Bit4/VP6EN  = 0.6V ref is ON
    ' ====== PROGRAM START =============================================================================
    MAIN:
        GOTO MAIN:
    These are the registers:
    And this is my PIC:
    My voltage divider (that comes from Vbatt) is connected to PORTC.3 and I'm expecting the PORTC.4 (C2 output pin) to trip when Vbatt exceeds 0.6Volts, but this nevers happens.
    What am I missing please?
    Roger
    Default Re: Comparator not tripping above 0.6V (Vref) on PIC 16F690
    this works if you mean "trip pin" means pin is set when below 0.6v and cleared when over
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    ' ====== REGISTERS ================================================== ===============================
    led var portc.0 ; proof of life
    CM2CON0 = %10100111 ' Comparator2 Module (def.: %00000000)
    ;bit2 connect c2+ to fvr output
    ansel.4=0 "just to prove c2+ is not connected to this
    VRCON = %00110000
    ' ====== DEFINES ================================================== =================================
    ' ====== PROGRAM START ================================================== ===========================
    MAIN:
    toggle led ; proof of life
    GOTO MAIN:
    Thanks Richards,
    Sorry, maybe the word "trip" is not adequate (I'm speaking french)
    BTW, what would be the correct word: "latching"?
    I found this interresting video which made me start to try battery monitoring:
    Unlike the video, I started with a 2 resistors divider. But a potentiometer (maybe easier for a start) and a corrected register CM2CON0 as you suggested made it work.
    So, I missed this one you kindly pointed me to:
    Finally, the "shortest possible" working code for a 0.6Volt threshold detection could be:
    TRISC      = %00001000 ' Comparator's input port
    CM2CON0    = %10100111
    ' Bit7     = comparator 2 is ON
    ' Bit5     = comparator's output pin (i.e. LED) is PORTC.4 (for "proof of life")
    ' Bit2     = connect Vref to C2Vin+
    ' Bits1:0  = comparator's input pin (i.e. Vbatt) is PORTC.3
    Roger
    the only problem with it is that the comparator state can be programmed to be high or low on either side of the transition point
    the word trip conveys no indication of preference
  1. 16F690 VREF PGC question
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2014, 16:14
  2. Replies: 2
    Last Post: - 31st May 2013, 18:19
  3. 18F2525 A/D, Comparator and Vref modules
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 20th May 2005, 23:17
  4. accurate vref < 1vdc 16F876 comparator
    By mslaney in forum Schematics
    Last Post: - 23rd March 2005, 01:44
  5. switching external vref+ and vdd vref
    By alejandro_halon in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 20:13
