Victron , VE.Direct
Results 1 to 6 of 6
    Default Victron , VE.Direct
    i have a pic based C code i/f up and running and a wemos d1 /nodemcu/esp8266 udp interface too
    anybody interested ?
    OK
    Default Re: Victron , VE.Direct
    I remember my high school science teacher would ask, "Any questions?" After close to a minute of silence he would add, "Do you understand enough to have any questions??" Not sure what you're even offering.
    if you don't understand then you are unlikely to need to
    https://www.victronenergy.com/live/v...t_protocol:faq
    Although its been a couple of years I would be interested to have a crash on the wemos things...
    Thank you,
    turned out UDP was a poor choice, there is no guarantee UDP packets will be delivered at all or even arrive in order sent.
    i changed over to an espwebserver model and used http GET/POST requests which worked ok but on a busy network or with poor wifi reception and having multiple clients made synchronizing victron device responses with the web requests very clumsy. ESPAsyncWebServer allows for a better solution has worked nicely, so far.
    a WebSocket Server will probably be the ultimate solution when i find time to learn another trick.
    best place to start is the arduino ESPAsyncWebServer demo
    i took some ideas from this, but used littlefs rather than the deprecated spiffs
    to really get anywhere you want an understanding of c++ , html and one of the browser scripting languages like js or php
    this can answer most questions
    https://www.w3schools.com/
    my current educational project is a weather station webserver;
    pic16f18326 - 32k fram - bme280 - esp02s
    would love to find a socket to fit TYWE2S ESP8285 Module
    i was using the m3 but the price/availability ratio has soured
    Thanks Richard.
    Amazing things, too much knowledge...
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 21:32
  2. WIFI Direct Module Recommendation
    By ssnickson in forum Ethernet
    Last Post: - 24th October 2013, 13:50
  3. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 18:27
  4. Direct replacement for 16F688
    Last Post: - 7th September 2006, 01:20
  5. max232 vs direct serial
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th August 2005, 01:07
