Project - GSM Shield SIM900D + PIC16F877A
Results 1 to 2 of 2
    Jan 2018
    Default Project - GSM Shield SIM900D + PIC16F877A
    Hi there!..So this is my partial project for my research proposal on how I integrated my GSM Shield module, specifically the SIM900D, with the PIC16F877A microcontroller unit. In this project, I only constructed a sending process function by using a push-button. Therefore, every time I would press the push-button, a fixed message would be sent to a specific recipient. This is only a basic construction of understanding the GSM Shield function and its AT Commands.
    The image that is shown below is the GSM Shield SIM900D that I used for my project. You can purchase this at http://www.e-gizmo.com/KIT/gsm shield.html for about 1,995.00 pesos.
    Features and Specifications of GSM/GPRS Shield:
    • Industry proven SIMCOM SIM900D Module
    • Buffered UART provides additional layer of protection
    • Fused power input
    • On board LDO voltage regulator
    • UART/SUART switch selectable port (gizDuino)
    • On board manual power switch
    • SIM Card Holder
    Here is the circuit I made by integrating the PIC16F877A (datasheet:http://www.kynix.com/uploadfiles/pdf...F877A-I2fL.pdf)and the GSM Shield:
    Be sure to connect the Tx of the GSM Shield to the Tx of the PIC and the Rx of the GSM Shield to the Rx of the PIC. Take note also that the GSM needs to be powered by a 1.5A and 5VDC supply and its ground must be COMMON to the ground of the circuit.
    For the PIC16F877A programming code, I used a programming language which is the "MikroC Pro for PIC". MikroC has an awesome and numerous features of built-in libraries along with examples of small programs in order for the user to simply understand the functions. Here is my program code: (REMEMBER: This is only a sending process, it does not consist of a receiving capability yet.)
    /*---------------------------FLEET MANAGEMENT SYSTEM-------------------------
          MikroC Programming by Kirk Macaraeg
    void GSM_Init(void);
    void GSM_send(void);
    void GSM_receive(void);
    void main(void) {
    TRISD=0b00000010;     //RD1 is an input
    PORTD=0x00;                //The rest of RD pins are output
    UART1_Init(9600);     //Initialize and establish communication at 9600 bps
    Delay_ms(250);
    UART1_Write_Text("AT+CMGD=1");  //Delete mesage sotred in inbox1
    UART1_Write(0x0D);              //
    while(1)
    if(PORTD.F1==0)           //if pushbutton is pressed
      PORTD.F0=0;               //LED OFF
      GSM_Init();                   //calls GSM_Init function
      GSM_send();                 //calls GSM_send function
      PORTD.F0=1;                //LED1 blinks 3 times
      Delay_ms(250);
      PORTD.F0=0;
      Delay_ms(250);
      PORTD.F0=1;
      Delay_ms(250);
      PORTD.F0=0;
      Delay_ms(250);
      PORTD.F0=1;
      Delay_ms(250);
      PORTD.F0=0;
      Delay_ms(250);
                          GSM INITIALIZING PROCESS
    void GSM_Init(void)
      UART1_Write_Text("AT\r");
      UART1_Write_Text("AT+CMGF=1");      //Text Mode
      Delay_ms(250);
      UART1_Write_Text("AT+CMEE=2");      //Write Mode
      Delay_ms(250);
      UART1_Write_Text("AT+CFUN=1");      //Full Phone Functionality
      Delay_ms(250);
                           GSM SENDING PROCESS
    void GSM_send(void)
      UART1_Write_Text("AT+CMGS=\"09429185691\"");    //send SMS to this number
      Delay_ms(250);
      UART1_Write_Text("F.M.S. GSM with PIC Testing\r");  //message to be sent
      UART1_Write(0x1A);                                  //
      Delay_ms(250);
    Here is an actual video of what I have made:
    Apr 2003
    Cambridge - UK
    Default Re: Project - GSM Shield SIM900D + PIC16F877A
    Thank you for making this contribution. It has been published on the web site
    http://www.picbasic.co.uk/forum/cont...00D-PIC16F877A
    Lester - Forum Administrator
    www.crownhill.co.uk
  1. Pic18F4550 + SIMCOM SIM900D GSM/GPRS
    By tacbanon in forum GSM
    Last Post: - 20th July 2016, 10:28
  2. Replies: 62
    Last Post: - 5th May 2014, 19:22
  3. GPS Shield
    By mackrackit in forum PBP & Amicus18
    Last Post: - 25th September 2011, 07:23
  4. Replies: 8
    Last Post: - 25th May 2011, 00:22
