A/D converter PIC16F1827
Results 1 to 9 of 9
    Sep 2009
    Default A/D converter PIC16F1827
    i use this code but is not working
    DEFINE ADC_BITS 10
    DEFINE ADC_SAMPLEUS 50
    'DEFINE ADC_CLOCK 3
    ADCON0  = %00000001
    ADCON1  = %01100011
    ANSELA = %00000111
    TRISA   = %00000111
    How to enable three channels (AN0,AN1,AN2) A/D converter PIC16F1827
    any help please
    Default Re: A/D converter PIC16F1827
    You've selected the FVR as reference for the ADC but I see no code that configures the FVR (it's disabled on POR).
    That's how far I got with what's shown.
    OK
    ADCON1 = %01100011
    For your ADC Clock to = 3, ADCON1 must be %0011....
    You have the ADC Module looking at the FVR for a VREF+ (bits <2-0> of ADCON1). Nowhere in your listing do you mention setting up the FVRCON register so your ADC has its positive reference turned on. You might want to change ADCON1 to %00110000 and use Vdd for your VREF+.
    You can use the ADCIN command, ADCIN 0, VAR and PBP will automatically adjust ADCON0 to AN0 for you, or you can work it manually:
    ADCON0 = %00000011
    DO
    LOOP WHILE ADCON0.1 = 1. ;The GO bit
    VAR = ADRESH
    This gives you an 8-bit ADC value. For AN1, ADCON0 = %00000111, for AN2, ADCON0 = %00001011, and so forth.
    Sep 2009
    mpgmike Thank you very much
    Can you tell me how I will get a 10-bit price in the baty variable
    my programm
    baty var word
    arxh:
    ADCON0 = %00000011
    DO
    adcin 0,baty
    if baty > 1050 then
    gosub OK
    if baty < 1000 then
    gosub noOK
    goto arxh
    Look from page 142 and after the details of the AD converter. It always makes a 10 bit conversion. It is up to you if you want 8 or 10 bits result.
    Anyway, having ADFM=1, the result is Right justified and stored in the ADRESH, ADRESL.
    So get your result in the baty variable as:
    baty.HIGHBYTE=ADRESH
    baty.LOWBYTE=ADRESL
    or
    baty.BYTE1=ADRESH
    baty.BYTE0=ADRESL
    In any case for the variable handling (e.g. baty.BYTE1, etc) look at the PICBASIC reference manual.
    You don't have to first do a "manual conversion" (via the GO/DONE bit) and then do a ADCIN (which basically does the same thing for you).
    If you're going to use ADCIN then add a DEFINE ADC_BITS 10. If you're going to use the "manual method" just do what Ioannis showed and get rid of the ADCIN command.
    And once you DO have your 10-bit resuly this won't work because baty will never be >1050 since the maximum result returned by the 10 bit ADC is 1023:
    if baty > 1050 then
    gosub OK
    OK
    There are some 12-bit ADC Modules in a few of the PICs if you want better resolution. Referencing the ADMF = 1, that would be ADCON1.7 = 1. Let us know how you make out.
    Sep 2009
    Thank you all for the help. Excuse me .I am a novice to PICBASIC
    That's what we are here for. Don't worry being novice. We all are, one way or another!
    Henrik caught the over 1023 point that I missed. Be careful on this as the 10 bit might be not enough for what your are after.
    But you can always scale the measurements. Tell us more to help.
  1. Replies: 3
    Last Post: - 22nd March 2013, 00:37
  2. A/D converter sample
    By allan josephus in forum mel PIC BASIC
    Last Post: - 23rd February 2008, 19:44
  3. Step up converter
    By Ron Marcus in forum Off Topic
    Last Post: - 27th July 2006, 20:44
  4. A/D converter
    By rocky79 in forum mel PIC BASIC Pro
    Last Post: - 1st October 2005, 06:40
  5. help D/A converter
    By matelda in forum mel PIC BASIC Pro
    Last Post: - 8th September 2004, 17:25
