LCD BARgraphs - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 81 to 120 of 233
Thread: LCD BARgraphs
  1. #81
    Talking
    For Portb.1 ...
    you've declared it as an Input ... and drive a led with it ... so, it's an OUTPUT !!!
    I think the Interrupt problem could be here ... I remember a thread explainining a Change in the I/Os disabled the Pullups ...
    YESS it is !!! ... just over Fig 3.3 of the Datasheet ...
    Tadaaaaaaa ..... one RTFM for you !!!
  2. #82
    The LED is on portb.2. Portb is set as all outputs except bit 1. See the trisb=1
    So, where is the ... Tadaaa?? :-)
  3. #83
    No tadaaaaaa ... just read a bit too quickly ( TRISx = %00000001 is so much easier to look at ...)
    Strange ... i tried DT interrupts quite the same way ... no problems.
  4. #84
    I think I am,
    trisb=1 is equal to:
    trisb=%00000001
    Isn't this bit 0 of port b set as input?
    Looks good ...
    I tried THAT in MPSIM ... Works Great ...
    INCLUDE "C:\PBP\MODEDEFS.BAS"
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    LED1 VAR PORTB.2
    trisa=1:trisb=1:trisc=0:trisd=0:trise=0
    PORTA=0:PORTB=0:PORTC=0:PORTD=0:PORTE=0
    OPTION_REG = %00100001 ; Set TMR0 Prescaler to /2, RBPU on
    adcon0=%10000000 'Fosc/32, ADC ON
    adcon1=%10001110 'Right Justify, RA0 Analog, rest Digital I/O
    INT_Handler INT_INT, _ToggleLED1, PBP, yes
    INT_ENABLE INT_INT ; enable external (INT) interrupts
    pause 1
    GOTO Main
    '---[INT - interrupt handler]--------------------------------------------------
    ToggleLED1:
    high LED1: pause 100:low led1
    @ INT_RETURN
    I just modified OPTION_REG value cause little things seemed strange to me ...
    try it ... huuu ... is processor a 16F877 ????
  6. #86
    Yes Alain, MCU is 16F877, but this is minor.
    Do you mean that with OPTION_REG=$81 does not work also at your test?
    I have not the board with me at work now. I will test it late today.
    Wink
    I have an old 877 here...
    I'll breaboard it ...
    We'll see !!!
  8. #88
    Smile Original Code is OK
    Hi, Ioannis
    YOUR code has passed the Breadboard test ...
    Works as expected ... ( little flash when PORTB.0 tied to ground )
  9. #89
    Looking at the PICDEM2+ schematic some more, it seems that there might be a conflict with PORTB.0
    <img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1794&stc=1&d=118289364 1>
    With J6 installed (has to be for the LED on PORTB.2), the LED on PORTB.0 may not allow the voltage to rise far enough to register a HIGH level.
    Jan 2007
    Thumbs up AWESOME!!!!! (again)
    I joined in this quite late, but on the original bargraph code posted by Darrel (and also the interrupt code posted elsewhere) I have one thing to say....WOW Darrel. GENIUS.. BOTH of these snippets have saved me hours of work on a project I'm working on.
    I needed to poll an array of front panel switches every few milliseconds AND service a bargraph update AND change the frequency of a HPWM signal all at set times, I was in the process of writing an RTOS for the PIC to allow me to use queued commands executed on a priority/time basis, then these two pieces of code went live.
    OK, you killed my six months of work on the RTOS, but I'm not complaining. Everytime I see a new posting by you I just KNOW it's gonna be soething that makes my life that little bit easier.
    A huge thanks and keep up the excellent work.
  11. #91
    That's Great Sean!
    Always nice to know it's not going to waste.
    Hope it makes you money, or
    Impresses the boss, or
    Get's you an A+ on the project, or
    simply presserves the hair, so it can fall out naturally later.
    Best regards,
    Ioannis,
    Just in case you're still thinking, It can't be that (Post #89) because this works ...
    while portb.0=1
    wend
    high led1
    If you look at the PORTB.0 diagram. You can see that it uses a TTL input buffer when reading PORTB as digital inputs. So, the High and Low voltage levels are 2.0V and 0.8V.
    With the circuit on the PICDEM2+ you'll get around 2.25V with the switch open (depending on the forward voltage of the LED). So it works fine with the digital Inputs.
    <img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1800&stc=1&d=118290623 7>
    But the signal for the INT interrupt, goes thru a Schmitt Trigger. And it's levels are .8VDD (4V) High, and .2VDD(1V)Low.
    The circuits on PORTB.0 of the PICDEM2+ don't produce enough voltage to trigger the interrupt. (when the LED's are engaged)
    HTH
    Darrel, your suspicion of PICDEM2+ were confirmed! Damn, so many ours wasted over a stupid LED!
    Thanks for the help guys!
    Finally I decided to use the hardware direction about the log conversion to bargraph display. Faster, cleaner, wide dynamic, expensive!
    Thanks again.
    Lightbulb
    Hi, Ioannis
    Have a look here ...
    http://pdf1.alldatasheet.com/datashe.../SSM-2110.html
    nice, but may be difficult to find ... and expensive.
    but worth it.
    I've also found an AOP and linearizing diodes solution, but won't give the dynamics and precision you look for ...
  15. #95
    for non-french user, AOP= Op Amp
  16. #96
    Hi, Ioannis
    Thanks Alain. I 'll stick to NE604, although more expensive than CA3089, because is operating on 5V directly and is great!
    I was wondering what AOP was! Thanks!
    Jun 2006
    You can use the SA605 (is more newer model than NE604) , and this is operating on 5-8V.
  18. #98
    Quote Originally Posted by savnik View Post
    Thanks Nik. And a bit cheaper too!
    Jan 2007
    I've been playing with the NCD/DCD with excel, and there's something I can't seem to work in there.
    Granted, I'm relying on 30 year old memories from when I was working on microwave radios in the air force. But if memory serves me right, then a change of 3 db is double the power, and -3 db is half the power. And since the impedance is constant, it also means the voltage is either doubled or halved.
    So let's assume the signal is scaled so that the (maximum A/D reading +1) corresponds to +7 dbm. Then half of that would be 512 or +4 dbm.
    If you keep dividing that down, since there's only 10 bit's, you end up with a minimum of -23 dbm with an A/D input of 1.
    And it appears that it would take a resolution of 16-bits to be able to get down to -40 dbm.
    I think this applies to however you do it. Lookup, calculate, ...
    ADDED: And any noise or offset voltages will Obliterate the low end.
    But then, maybe I've got it all wrong? ??
    I was always taught (having worked in the audo industry on digital mixin consoles, and having spent years designing synthesisers and samplers as a hobby) that the actual figure is around 6dB per bit, so 10 bits gives you 60dB, but in reality it's more like 4.5dB. I might be wrong but this is what I've always been told. Surely all you have to do is shift the levels?
  20. #100
    Quote Originally Posted by Sean_Goddard View Post
    Look at http://www.picbasic.co.uk/forum/show...1&postcount=68. That one was solved!
    Aug 2007
    Question
    Hello!
    I've try to get some bar from this and I've got problem as usual ;-)
    So this is little code from me:
    INCLUDE "LCDbar_INC.bas" ' Include the BARgraph routines
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    INPUT PORTA.0
    i var word
    LCDOUT $FE, 1 'clean screen
    while PORTA.0 = 0
    i = i+1
    LCDOUT $FE,2,"Value = ",DEC i," "
    ' syntax- BARgraph Value, Row, Col, Width, Range, Style
    @ BARgraph _Value, 2, 0, 16, 255, lines
    Pause 100
    wend
    As You can see in picture I've got problem when compiling with LCDbar_INC.bas...and get'+s lot lines of syntax error in INCLUDE file......off course I didn't make anything to this file...just copy -> paste....
    Do You know what couses this problem?
  22. #102
    Quote Originally Posted by Marin View Post
    _Value should be _i in this case.
    The comments a little confusing at first, but once you figure it out, it just seems natural.
    Hi Marin,
    To use Darrel's tidy little include files, you must place a copy of his file in the same directory as your code's file is in, and you must use MPASM as the assembler, not PM.
    JS
    Oh, and do they ever work sweet too!
  24. #104
    Aug 2007
    OK!
    Joe, is they any way to this be compiled in PM with some changes in .INCLUDE file?
  25. #105
    If Darrel would make major changes it might!
    But then again why would he? MPASM is much better assembler!
    You still have your beloved compiler to write your code. Let Microchip do the job that knows better than anyone third.
    Aug 2007
    GOnna go to MPLAB now.....
    Can somebody explain me using MPSAM with mine MicroCode Stuio PicBasic Pro?
    With that I still gona write code in code studio or?
  27. #107
    No additional code.
    Just set up the Microcode Studio to use MPASM from View/Compile and Program Options/Assembler and check the Use MPASM checkbox.
    On your programmer set the fuses accordingly to your program/xtal
    Aug 2007
    NOW, I download latest version of microcode studio and I'm using MPASM...and still have same problem....
    With other mine code MPASM works great without any mistake.....but when I try to put bar code rutine as INCLUDE it gives me many errors....
    Like YOu can saw on picture!!!!
    Only one strange thing occured:
    Everytime when I start CodeStudio.exe give me this message:
    The procedure entry point ThunkConnect32 could not be located in the dynamic link library KERNEL32.dll
    BUt, like I said...everthink wrks good with mine codes......
  29. #109
    At this point, we can only guess.
    If you want to send the .LST file to me, I can take a closer look.
    Email to darrel at PBPgroup.com.
    It'll probably be too big to post in the forum.
    Aug 2007
    The problem is I don't have LST file......Ionly have LST file for code which is corectly assembled...for this no...when I try to assembled it it give me errors and stops.,
    And this is screenshot i forgot to send:
  31. #111
    It seems like the MPASM is not selected or not found.
    Have you installed MPLAB or at least the assembler?
    Can you send the program?
    Aug 2007
    I did install MPASM and when I buil other code it works perfect and MPASM window pops up while compiling......so I think that's ok....
    Gonna try reinstall PICBASIC OR mpasM AND GONNA SEE.....
  33. #113
    You might try downloading the LCDbar_INC.bas file again.
    I've heard a couple people say they got incomplete files on the first try.
    After downloading again it worked.
    The compiler is flagging errors, that should not be errors.
    A semicolon is the comment character. It should be ignored, not an error.
    What version of PicBasic Pro do you have?
    It is PicBasic Pro, right?
    Not PicBasic.
    Just a detail ...
    When installing MPLAB+ PbP ... some special instructions to care with !!!
    did you declare Paths to PbP AND to MPLAB, as specified ???
  35. #115
    Aug 2007
    I downloaded code many times and always same problem remaining!
    Mecanique Micro Code Studio Plus
    Version 2.2.1.1
    Compiler Version is PicBasic Pro 2.30
    Yes....and MPASM is checked in complier options...and MPASM functioning ok with other codes!
  36. #116
    PicBasic Pro 2.30 ??
    Well there's the problem.
    That's waaaaaayyy too old.
    Must have been at least 8 years ago.
    Time to buy a new version.
    Hi guys,
    does this work with a pic 16F84A ??
    I get many strange errors !
  38. #118
    Does it say something like "... Least significant bits used" ?
    If not, What errors are you getting?
    i've imported the folowing code from this thread:
    INCLUDE "lcdbarIN.bas"
    ' Set LCD Data port
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 2
    ' Set LCD Enable port
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 3
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    ' Set data delay time in us
    DEFINE LCD_DATAUS 100.
    DEFINE ADC_BITS 8 ' Number of bits in ADCIN result
    ADCON1.7 = 1 ' Right Justify AD result
    Value VAR WORD ' Must be a WORD even though AD is 8bit
    LCDOUT $FE, 1, " "
    loop1:
    adcin 2,value
    LCDOUT $FE,2,"Value = ",DEC Value," "
    'syntax- BARgraph Value, Row, Col, Width, Range, Style
    then i get :
    Error line 14: syntax error - this one i believe it's the ADCON1.7 = 1 command
    Warning Line 15: Bad token ";"
    bad expression
    Warning Line 16: Bad token ";"
    bad expression
    Warning Line 17: Bad token ";"
    bad expression
    Warning Line 18: Bad token ";"
    bad expression
    Note:
    The INCLUDE "lcdbarIN.bas" line where the name of the bas file is different because i also had to change to a smaller name due to "cannot include...etc" error
  40. #120
    mmm, as far as i know... grandpa 16F84 have no A/D converter ... so ADCIN will never ever works with... hence why you have some strange error... i missed that forum
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
