LCD BARgraphs
Results 1 to 40 of 233
Thread: LCD BARgraphs
    Default LCD BARgraphs
    LCD BARgraphs
    LCDbar_INC.bas
    is an Include file that makes it easy to create BARgraphs on your LCD display.
    Features:
    • Can be placed anywhere on the screen.
    • Can be any width (whole characters)
    • Can be scaled anywhere between 0 and 32768.
    • Three styles to choose from.  {lines, boxed, blocks}
    • Just 1 Command does it all. (Well, sort of)
    Click here for Larger Video (225kbps)
    @   BARgraph   Value, Row, Col, Width, Range, Style
    Value: The Value of the BARgraph  (0 to Range).If Range = 100 and Value is 50, then
              half of the BARgraph will be filled in.   Value MUST be a WORD sized variable¹
    Row: LCD Row to place the BARgraph (1 to 4)   can be either a constant or a
              variable¹.
    Col: LCD Column to place the BARgraph (0 to LCDsize² - 1)   can be either a constant
              or a variable¹.
    Width: Width of the BARgraph in charaters. (1 to LCDsize²)   can be either a constant
              or a variable¹.
    Range: The "full-scale" range of the BARgraph  (0 to 32768) MUST be a constant.
              Variables will not work here.
    Style: Selects which Style will be used for the BARgraph  (lines, boxed, blocks)   can
              be either a constant or a variable¹.
    Note ¹ - Variables must be preceeded with a
                 underscore.   ie.  _Temperature
    Note ² - LCDsize is the number of Chars in 1 line of
                 the LCD, for "4x16" it's 16
    Added 10/18/05 - If using a 4x20 display, you can use this define to let the program know the addressing is different.   Thanks, CocaColaKid!
    DEFINE  LCD4X20  1
    Default How to use LCDbar_INC.bas
    This is so simple to use.
    Here's an example of a BARgraph that follows an A/D input.
    ; Initialize your hardware and LCD first.
    DEFINE ADC_BITS 8               ' Number of bits in ADCIN result
    ADCON1.7 = 1                    ' Right Justify AD result
    INCLUDE "LCDbar_INC.bas"        ' Include the BARgraph routines
    Value  VAR  WORD                ' Must be a WORD even though AD is 8bit
    LCDOUT $FE, 1  ' Clear Screen
    Loop1:
        ADCIN  0, Value
        LCDOUT $FE,2,"Value=",DEC Value,"   "
        ; syntax- BARgraph   Value, Row, Col, Width, Range, Style
        @         BARgraph  _Value,   2,   0,    16,   255,  lines
    GOTO Loop1
    Default Another example
    This is just like the previous example except that it places both the Value and the BAR on the same line.
    Loop1:
        ADCIN  0, Value
        LCDOUT $FE,2,DEC Value," "
        @         BARgraph  _Value,   1,   4,    12,   255,  lines
    GOTO Loop1
    Very good job, Darrel ! I like very much ! But you forget the "vertical bargraph" !
    Don Mario
    Talking
    Quote Originally Posted by Don Mario
    Don Mario
    Hi, DON
    Just turn your LCD 90° cckw !!!
    hi,hi,hi ...
    Thanks ! It's a very good advice ! But I'm seriuos ! Don't forget the vertical bar !
    Don Mario
    Aug 2003
    Default Re: LCD BARgraphs
    Hi, DON
    Did a vertical graphing tachometer over time with a single custom char (far right in the video).
    Just got to matrix rotate the byte and shift every byte in the custom char every frame to make room for the next vertical byte.
    (this one has odometer effect on the elapsed timer as well
    vbcoder's Avatar
    vbcoder Guest
    Thanks Darrel. It gives me an amazing look for my project. Can you tell me if I use 2x16 Alpha LCD. How many bars that I can get per line?
    Hi vbcoder,
    You're welcome.
    There are 3 bars per character, so you can get 48 per line on a 2x16.
    Question aren't characters in a 5x7 Matrix arranged ???
    Hi vbcoder,
    You're welcome.
    Hi, Darrel
    I know it's YOUR Bargraph example ... but 5 bars can be used with "general programming" ...
    May be a Typo from yours ???
    Translated and modified from a Stamp application :
    ' This program generates a horizontal bargraph
    ' with a 2x16 Intelligent LCD Display HD 44780 / KS 0062.
    DEFINE OSC 20
    DEFINE LCD_EBIT 1
    Led var Portb.5
    Scale var Portb.2
    ' ** Variables **
    BarVal Var Word ' Value to be graphed.
    Bars Var Byte ' Number of full |||/||||| bars to draw.
    Balance Var Byte ' Balance left after all |||/|||||s are drawn.
    Padding Var Byte ' Number of spaces to fill width.
    Balf Var Byte ' Is a 'Balance' character needed? (1=yes, 0=no).
    Temp Var Byte
    Fullbar Var Byte
    Maxbar Var Byte
    ' ** Constants **
    BWdth Con 16
    Basebar Con 0 ' ASCII value of 0 bar (blank).
    IF NOT Scale THEN
    Fullbar = 3
    Fullbar = 5
    Maxbar = BWdth*Fullbar ' Max bar counts.
    ' Transfer the bit patterns that make up the bars into the LCD's CGRAM.
    ' The vertical bars are made up of 8 identical bit patterns
    ' A | bar consists of 0, 5 times $10, 0
    ' A || bar consists of 0, 5 times $14, 0
    ' A ||| bar consists of 0, 5 times $15, 0
    ' We repeat each pattern 8 times.
    IF Fullbar = 3 THEN
    Lcdout $FE,64,0,0,0,0,0,0,0,0 'Motif 0
    Lcdout $0,$10,$10,$10,$10,$10,$10,$0 'Motif 1
    Lcdout $0,$14,$14,$14,$14,$14,$14,$0 'Motif 2
    Lcdout $0,$15,$15,$15,$15,$15,$15,$0 'Motif 3
    Lcdout $0,$18,$18,$18,$18,$18,$18,$0 'Motif 2
    Lcdout $0,$1C,$1C,$1C,$1C,$1C,$1C,$0 'Motif 3
    Lcdout $0,$1E,$1E,$1E,$1E,$1E,$1E,$0 'Motif 4
    Lcdout $0,$1F,$1F,$1F,$1F,$1F,$1F,$0 'Motif 5
    Goto OverBargraph
    ' The value in 'Bar_Val' is displayed as a horizontal bar graph
    ' from the current cursor location with a total width (in characters) set by the WIDTH constant.
    ' Each character position can represent a maximum value of 3/5 using the Fullbar character |||.
    ' The routine calculates how many full bars to use by dividing by 3/5.
    ' If there is a remainder after dividing by 3/5, the routine joins on a partial-bar character
    ' ( | or || or ||| or |||| or ||||| ) to represent the balance.
    ' Then it pads out the remainder of the bar width with spaces to erase any leftover bars
    Bargraph:
    Bars = (BarVal min MaxBar) / Fullbar ' One full bar for each 3/5 graph units.
    Balance = (BarVal min Maxbar) //Fullbar ' Balance is the remainder after a division by 3/5.
    Balf = Balance min 1
    Padding = BWdth - (Bars + Balf) ' Number of spaces to fill bar width.
    LCDOut Rep Fullbar\Bars,Rep (Balance + Basebar)\Balf,Rep " " \Padding
    OverBargraph:
    For BarVal = 0 to Maxbar
    Lcdout $FE,$80
    Gosub Bargraph
    Lcdout $FE, $C0, #BarVal," "
    Pause 300
    Next BarVal
    Jun 2007
    TÜRKİYE
    Smile Thank
    gerçekten güzel uygulama teşekkür ediyorum.
    [email protected]
    TÜRKİYE
    Me neither!
    But I did catch the "Thank" part.
    So in case that's what it was...
    You're welcome zaferakbay.
    Hope you get good use out of it.
    Ok let's try in split words..
    gerçekten = Actually, honestly,indeed, literrally, positively,properly,really,simply, truly
    güzel = attractive beautiful, bonny, bracing, cherub,comely,dreamy,elegant,enjoyable,fair,fine,g allant,glorious,graceful,grand,handsome,lovely,nic e...
    uygulama = application, execution,implementation,practice
    teşekkür = *** can't be found *****
    ediyorum = *** can't be found ****
    hmmm,
    positively glorious application
    properly elegant implementation
    honestly beautiful execution
    really dreamy practice
    Hey, works for me
    As long as those last 2 words aren't
    Stink, Pile or S___
    ciberman37's Avatar
    ciberman37 Guest
    Default error in LCDbar.inc.bas
    The compiler signalise error in line 29, no is alabel?
    Line 29 is GOTO overBAR, and overBAR: is the last line in the include file.
    Check the end of the file and make sure overBAR is there. If not, you may have received a partial download. Try downloading it again.
    Sep 2008
    Stockholm
    What kind of licence did u put on your code Darrel ?
    I currently making a little project for a contest in a swedish electronics forum, and I really would like to use a LCD bargraph, and the rules states that I only can use includes that are "GPL or more free.", can I use this, or do I have to write something much more ugly myself ?
    Quote Originally Posted by Glenn View Post
    As long as you don't say you wrote it ... you can do whatever you want with it.
    For Free!
    Hi darrel.. Really nice work.Congrats.
    I intend to write lcd bar vu-meter and bar voltmeter codes. I did for voltmeter but not for bar vu-meter. And I need help for this. MCU is 16f876 and 2x16 lcd.. I need some help to convert reading from frequency to the bars. Can you help me ?
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
