LCD_LINES Question Help ?
Results 1 to 4 of 4
    May 2012
    Merseyside, UK
    Exclamation LCD_LINES Question Help ?
    Thank you for reading
    Quick Question to confirm...
    "Set number of lines on LCD
    DEFINE LCD_LINES 2 "
    Does the above mean define 2 line display
    or
    DEFINE LCD_LINES 1 (2 Line Display)
    DEFINE LCD_LINES 2 (4 LINE Display)
    Manual is not clear.... Various info around internet ?
    BR
    Andy
    Oct 2009
    Default Re: LCD_LINES Question Help ?
    Andy, this is the routine I use for a 4 line LCD on my EasyPIC5 board
    DEFINE LCD_DREG  PORTB                  ' LCD Data port
    DEFINE LCD_DBIT  0                      ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB                  ' LCD Enable port
    DEFINE LCD_EBIT  5                      '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB                  ' LCD Register Select port
    DEFINE LCD_RSBIT 4                      '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4                      ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4                      ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000               ' Command delay time in us
    DEFINE LCD_DATAUS 50                    ' Data delay time in us
    If you have a 2 x 16 or 2 x 20 LCD then change the DEFINE LCD_LINES 4 to DEFINE LCD_LINES 2
    May 2012
    Merseyside, UK
    Hi Scampy
    So for 2 lines ........LCD_LINES 2
    Thank you
    Andy
    Oct 2009
    Hi Andy,
    That's correct.
