Pic to GSM Phone connection (HSerin problems) - Page 7
Page 7 of 8 FirstFirst ... 345678 LastLast
Results 241 to 280 of 289
  1. #241
    Since you can send and receive with the current cable I don't see why you should change it.
    Also please note that the phone might send other characters too, like more CR and LF.
    You said you have only one Com on you PC, ok. You can do a "thief" with two 10K (or even 4K7) that take samples of the Tx and Rx signals while PIC and Mobile are connected together and send them to the Rx pin of the PC Com Port, just to monitor what they are doing while you are not looking. This way you will see exactly what the PIC wants the mobile to do, and what exactly is the mobile responding.
    Please try to take a Screenshot of this and post it.
    brighton
    Thanks Ioannis
    I am gonna do that now and would keep you posted
    Isaac
  3. #243
    brighton
    Post
    i am trying to upload the screen shots but keep getting msg that this exceeds 200kb
  4. #244
    brighton
    I dont know what happened to my last post.
    i was trying to attach the screen shots but couldn't.
    i connected breakout as you suggested and think i know what the problem is but not the solution lo
    When i connected the Tx/Rx to the Rx of the Pc when i run my program
    the pic is not sending anything to screen at all so this means the phone is not receiving anything so its not responding.
    But if i then disconnect the phone DLR-3 cable from the serial port of my project board i can see the AT command being sent to the phone on screen so i think the phone cable maybe faulty.
    i am still trying to get the shot to you but keep getting this massage below
    Your file of 1.08 MB bytes exceeds the forum's limit of 200.0 KB for this filetype.
    Isaac
  5. #245
    Make the file smaller jpg, png, bmp. No more than 200kb. This size is more than enough!
    About the problem not monitoring try smaller resistors like 4K7 or smaller. May be your driver from the PIC side is not powerful. What chip do you use?
    brighton
    i use Max232 which comes with the project board
  7. #247
    brighton
    Default here is the results
    here are the results
    What I see is in the first case only AT. Where is the rest of the string?
    Something is not working here. Check your overall setup of the PIC. Are you sure about the loaded program in the PIC memory? Try erasing before programming.
    Should come up with the rest of the commands, like ATZ etc.
    brighton
    Sorry about that.
    you would only see AT because the pic times out when it dont get ok back and goes back in the loop
    snipper of code
    'Send SMS Test-Message
    sms:
    HSerout ["AT",13,10]
    HSERIN 5000, SMS,[WAIT("OK")] ' wait for response ok for 5 seconds
    HSerout ["AT+CMGF=1",13,10] 'Set Text Mode
    HSerout ["AT+CMGS=",34,"+447895711481",34,",129",13,10]
    HSERIN 5000 , SMS, [WAIT(">")]
    HSerout ["Test-Message",10,13]
    HSerout [26]
    Pause 500
    RETURN ' return from subroutine
  10. #250
    brighton
    Just a thought
    Is there a Difference between DLR-3 & DLR-3P
    Isaac
  11. #251
    I don't know the difference between these two.
    But,
    1. Are you sure that Rx and Tx are connected correctly to the mobile? May be they are reversed?
    2. When you tried the mobile with Hyperterminal, did you set the hyperterminal Handshaking to Hardware or to None?
    brighton
    But,
    I set it to none
    i even trid a null modem cable but all in vain
    i dont have a scope here at home but i gonna get one 2morrow so i get have a good look
    Isaac
  13. #253
    After all the suggestions, I think wishing to you Good Luck is the last resource!
    brighton
    Thumbs up
    Just for your info.
    The problem was the cable.
    I borrowed someones DLR-3P cable and it worked great with my project board.
    I noticed that my cable we were having problem with was a DLR-3 cable without the P
    Isaac
  15. #255
    Oh, doh! What stupid case! I am glad you did it!
    Default Phone Connections
    I'm planning to make a security system wherein I can connect any mobile phone. I've seen some connection diagrams of mobile phone, where do we connect the hardware USART of the PIC16F877 to the mobile phone, Mbus or Sbus? I have experience in interfacing the PIC to a GSM module, I was here wondering if anybody knows, is there a similarity in the AT commands of a GSM Module and a mobile phone? Does all phones support text mode? On last thing, I would really appreciate is somebody could provide me websites that give me additional help in this regard. Thanks!!!!!
  17. #257
    Mbus or Sbus?
    Depends on the phone.
    Not all mobiles support text. Old Ericsson used to support PDU format only. Nokia's do support text. All of the GSM modules I checked support text too.
    AT commands are common in these modules to control. I'd prefer a module rather than a phone for control applications. See Telit, Wavecom and others too.
    Nov 2006
    Post Buy
    Can I ask where can I buy the data cable DLR-3P ? In any nokia shop? because nowadays a lot of shop only sold the usb one not the serial port...hard to find ya...THANK YOU..
    dragonball
  19. #259
    Jul 2007
    Default help me plz
    I am trying to send sms with siemens c55 by Pic 16f876.I already know at command.I have sent already sms by hyperterminal.And I tried on pic 16f876 ı failed.I dont know where i mistake.Plz help me.my source codes are below...
    my schematic is:
    http://images.elektroda.net/15_1185282984.jpg
    #include <16f876.h> // Kullanılacak denetleyicinin başlık dosyası
    tanıtılıyor.
    #fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NO DEBUG,NOCPD //
    Denetleyici konfigürasyon ayarları
    #use delay (clock=20000000) // Gecikme fonksiyonu için kullanılacak
    osilatör frekansı belirtiliyor.
    #use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1) //
    RS232 protokolünün 9600 bit/sn baud hızında olacağını ve
    TX,RX uçlarının hangi pinler olacağını tanımlıyor
    parity bitinin olmadığını, stop bitinin 1 bit olacağı belirtiliyor
    unsigned char mesaj_gonder[] = "AT+CMGS=19";
    unsigned char mesaj[] = "0011000C910945447198660000FF05E8329BFD06";
    /********* ANA PROGRAM FONKSİYONU********/
    void main ( )
    setup_spi(FALSE); // SPI birimi devre dışı
    setup_adc_ports(NO_ANALOGS); // ANALOG giriş yok
    setup_adc(ADC_OFF); // ADC birimi devre dışı
    setup_ccp1(ccp_off); // CCP1 devre dışı
    setup_ccp2(ccp_off); // CCP2 devre dışı
    set_tris_c(0x80);
    puts(mesaj_gonder); //AT+CMGS=25
    putchar(0x0D); // Enter tuşuna basılıyo
    delay_ms(3000);
    puts(mesaj); //Message in PDU format
    putchar(0x1A); //Control-z tuşu
    putchar(0x0D); // Enter tuşuna basılıyor
  20. #260
    This is not general purpose forum! We do only Pic Basic and specially MELABS PicBasic language!
    brighton
    Quote Originally Posted by CLLUNLU View Post
    my schematic is:
    tanıtılıyor.
    void main ( )
    set_tris_c(0x80);
    delay_ms(3000);
    From your circuit you have got gnd connected to pin 5
    also if you can communicate to the phone using hyperterminal
    then you need to connect a null modem between your pic and the phone or just swap Tx with Rx
    Isaac
  22. #262
    Apr 2005
    Quote Originally Posted by DragonBall_6 View Post
    dragonball
    Why don't you make it yourself?
  23. #263
    Nov 2006
    Default data cable
    I also think like that but is it very hard?
    maybe I want to take a try.
    Do you have the schematic or website?
    Thank a lot.
    Peter
  24. #264
    Jul 2007
    Default data cable
  25. #265
    Mar 2006
    Cool dlr3p_cable plus hex file for PIC16F84A
    Hi
    Here's my cable i frequently use in my gsm sms-remote control projects hope this helps!!! the dlr3p firmware is a hack version!!!
    original ckt!!!
    http://www.atrox.at/datacable/dlr3/index.html
    Nov 2006
    Post How Can connect my Phone to the circuit?
    Thank for the reply..Really thank.....
    May I know in your circuit which part is to connect my handphone connector such as nokia 6100.
    I'm not able to find the serial data cable in the market(malaysia) nowadays to connect my mobile phone. What i can find is the usb connector one not the serial port one.
    Can I connect like this??: handphone-->handphone connector-->usb male-->usb female to female converter------>usb-serial adapter then i can connect to my PC.Is that possible and do i need any driver?????
    Because as i know, to send data thru usb is very complicated so i need to find a way to send data using serial cable. it is much easy.
    Pls advice...
    Thank you very much>>>>
  27. #267
    Mar 2006
    Talking GSM to PIC
    Firstly you need to find out if u'r fone is AT-capable most of valid fones have modem dlr3p cable will only work in 6110 series and 7110 series or compatible phones i believe 6100 is using POP-PORT and if u'r talking about USB connection either HOST or PERIPEHERAL mode you will be needing USB to TTL logic converter like those chips from maxim or FTDI because USB is LVDS "low voltage differential signaling" try to find out more about your phones POP-PORT if it sends out TTL and if it is AT-commands compatible and by the way you need to figure out if your phone is can handle TEXT or is PDU by defualt the formeris easier!!! if it is in PDU mode you wont be able to get a response from your phone you will need to be doing translation in your software!!!
    PS.
    The 7-pin in the ckt is directly pin to pin to 6110 or 7110 port i used an old headfone very cheap even the fone is cheap roughly 900 pesos or 20US$
    Yours Trully Ryan
  28. #268
    I would strongly recommend to use mobile modules that support native serial communication. Not by USB adaptors.
    Try Wavecom, Telit, Ericsson or other similar. They are made for this purpose.
    Mar 2006
    Talking
    I strongly agree!!! but if u want to do some recycling and by the cheap approach it's worth trying!!!
  30. #270
    Apr 2005
    Quote Originally Posted by leisryan View Post
    Hi
    original ckt!!!
    Bro what do you mean "HACK VERSION" of firmware...
    What part was hack?
    Mabuhay!!
  31. #271
    Mar 2006
    Talking HACK dlr3p
    original dlr3p has a propreitary signal which sets up the 6210 series and alike fone inorder to accept data from their PORT unlike older cables MBUS,FBUS etc!!! you can follow the link i posted recently above!!!
  32. #272
    Apr 2005
    Default Hack DLR3P
    So what can we benefit for using the "hack" version? can you inumerate the the differences here?
    BR
  33. #273
    Mar 2006
    Talking
    I can't bro "tamad ako magsulat" hehehe!!! but the mere fact someone "hacked the cable" instead of buying the expensive one i'm pretty much sure you will find tons of applications!!! RECYCLING is one thing!!!
  34. #274
    Mar 2006
    Lightbulb Megasquirt!!!
    EVERYBODY in this Forum AVR-guys are getting so much popular making add-on applications for MEGASQUIRT!!! they even developed this LCDASH dashboard and it's freaken jam-packed!!! i believe if you want PICMICRO to hold its position lets start projects for megasquirt too!!! as a start i created idle servo controller for an old 1992 lancer watch my video!!!
  35. #275
    Default Cheapest GSM Module
    Can someone help me direct to a website where I can purchase oneline cheap GSM Module? Any help will be greatly appreciated. Thanks in advance.
  36. #276
    Apr 2005
    The DLR3P found on this site http://www.atrox.at/datacable/dlr3/index.html is already "HACKED" of the original..and it is working perfectly..thanks to the author..
  37. #277
    Mar 2006
    Wink gsm_module
    Quote Originally Posted by pagi View Post
    Here you go bro look for BENQ gsm modules GPRS capable also using standard AT modem commands!!!
    http://www.e-gizmo.com/
  38. #278
    agnius's Avatar
    agnius Guest
    i have maked : http://ktl.kauko.lt/~av2/projektai/gsm/1.png
    pic16f84a and phone siemens c55
    test program:
    define OSC 10
    Rx var PORTA.0
    Tx var PORTA.1
    Led VAR PORTA.3
    speed = 84
    start:
    high led
    pause 2000
    serout2 Tx, speed,["ATD+37060000000",13,10] <--- in this step, phone turn off, whay???
    pause 10000
    low led
    for this scheme (http://ktl.kauko.lt/~av2/projektai/gsm/1.png) are hex (http://ktl.kauko.lt/~av2/projektai/gsm/softas/1010.rar) and it work fine
  39. #279
    Mar 2006
    Question Duh????
    Quote Originally Posted by kasamiko View Post
    DUH????? DUH?????
    Hi
    original ckt!!!
  40. #280
    Feb 2008
    Laguna
    Default help po pls....
    gud day po mga ffriiends. gusto ko lng po humingi ng tulong about our project.\
    title po nun sms controller. anu po bng PIC ang gagamitin? at panu po ba gagawin un? wla po kasi kming idead about dun. pls help po.. salamat... e2 po contact numbver ko po.. 09216625350
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  4. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  5. Pic to GSM Phone connection
    By samertop in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 13:40
