Pic to GSM Phone connection (HSerin problems) - Page 3
Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 81 to 120 of 289
  1. #81
    Feb 2004
    Germany
    ... do I need an hex inverter? or a max232?
    You will never get this to work if you don't take the time to read any datasheet.
    regards
    Ralph
  2. #82
    dimitrin's Avatar
    dimitrin Guest
    don't quite understand your comment.
    thanks for your input.
  3. #83
    Feb 2004
    Germany
    Quote Originally Posted by dimitrin
    don't quite understand your comment...
    ...nor RS232
    regards
    Ralph
  4. #84
    dimitrin's Avatar
    dimitrin Guest
    Default so now you confuse me more
    because it does work with rs 232.
    thanks again for you help
  5. #85
    aruran's Avatar
    aruran Guest
    Question Ericsson T18
    I got an Ericsson T18 phone, which works with the data cable for AT commands.. Going through the internet I found that it doesn't support Text mode, Only pdu mode available. So can I make it work by using bitmaniac's PDU decoder. And I am going to use PIC16F877A. If I do the necessary changes it should work right......
    thanks in advance
    aruran
  6. #86
    PIC Coder's Avatar
    PIC Coder Guest
    Default Samsung SCH-N356.
    Hello,
    I am look out for technical details of Samsung SCH-N356. I also want to make SMS controled relay. Please suggest.
    Bye
  7. #87
    aruran's Avatar
    aruran Guest
    Thumbs up SMS using T18
    Hai all,
    First of all thank you all for the help rendered. I have successfully made a Ericsson T18 to send SMS using PIC16F877A. I give the PIC using I2C bus some data from a main PIC for my microcontroller project. I have written a dynamic PDU encode routing to handle the dynamic texts sent by the main pic. This was achieved mainly from the help of bitmaniac's PDU encode...
    Thank you all
    aruran
  8. #88
    Feb 2004
    Germany
    aruran,
    it would be nice if you would share youre code.
    regards
    Ralph
  9. #89
    MICOCALI's Avatar
    MICOCALI Guest
    Default hserin
    What is the metod for write a code in 16f628 for read in rs232?
    when the telephone send (*elip string, my 16f628 to be one pin at gnd
  10. #90
    Apr 2005
    Thumbs up
    I just finished my circuit below a PIC to cellphone interface to send text messages..I can succesfully SEND a pre-programmed text message using this code:
    Device 16F84A
    Declare Xtal = 4
    Start:
    LOW LED
    DelayMS 1000
    SerOut2 PORTB.1, 84,["AT+CMGS=",34,"MyNumber",34,13]
    DelayMS 1000
    SerOut2 PORTB.1, 84,["TEST",13]
    DelayMS 1000
    SerOut2 PORTB.1, 84,[26]
    DelayMS 3000
    GOTO Start
    I can send an endless "TEST" text messages to "MyNumber" but I can't make it work to read received text messages..
    I need a code sample that will READ the received text message and will text back to the sender the word "GOOD"
    I don't have the idea how to strip the sender phone number and the sent text message "GOOD" from the example below using SERIN command..
    +CMGR: "REC READ","+xx1234567890",,"05/05/26,17:19:23+00"
    GOOD
    OK
    I'd look at this code:
    HSerin 5000, Loop, [Wait("UNREAD"), skip 3, STR Caller\12, skip 4, STR GSMTime\17, skip 4, STR GSMbuffer\12]
    But I can't "SAY" it using SERIN command using PIC16F84..
    Thanks for any info..
  11. #91
    Royce's Avatar
    Royce Guest
    Default PIC to GSM modem
    Hi
    I am very new to PIC's so please excuse some of the comments that I have added to the following code.
    I have put this together using data that was available earlier in this post. I have got the SMS sending working great whenever I push a button but I am also wanting an LED to be switched on when the GSM modem receives and SMS containing "SWITCH"
    I think I have got everything that I require within the program but I am wondering what commands I should use in order to read the GSMBuffer then if it is true then switch on the LED.
    I have added the line just to give an idea of what I'm trying to do:
    IF GSMBUFFER = "SWITCH" THEN LED = 1
    Here is the code:
    ' Setup PIC tx and rx serial port
    DEFINE OSC 8
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    'Setup the names that will be used throughout the program for the led and switch
    PushButton var PORTB.0 ' Setup the name PushButton to mean PortB input 0
    LED VAR PORTB.1 ' Setup the name LED to mean PortB output 1
    ' SMS receive buffer setup:
    GSMBUFFER VAR BYTE[16] '16 is used to tell buffer to store max of 16 characters
    Caller VAR BYTE[13] '13 is used to tell buffer to store max of 16 characters
    GSMTime VAR BYTE[17] '17 is used to tell buffer to store max of 16 characters
    ' Set all PortB i/o 1 to be an output and all other i/o as inputs
    TRISB = %11111101
    IF PushButton = 0 THEN SMS 'If button is pressed then run the SMS routine below
    goto main ' however if the button is not pushed then just go back to the Main
    ' routine to wait for the button to be pressed
    SMS: ' this is the SMS commands routine in order to send an SMS
    HSEROUT ["AT" ,13,10] ' send AT to modem followed by a CR and line feed
    HSERIN 5000, SMS, [WAIT("OK")] ' now wait for 5secs until OK is received however
    ' if it is not then goto the SMS routine again
    HSEROUT ["AT+CMGF=1" ,13,10]
    HSEROUT ["AT+CMGS=+447977578999"]
    HSEROUT [13,10]
    HSERIN 5000, SMS, [WAIT(">")]
    HSEROUT ["BUTTON HAS BEEN PRESSED!"]
    HSEROUT [26] ' this is ASCII for Ctrl+Z of which completes SMS sending
    HSERIN 15000, SMS, [WAIT("+CMG")] ' then PIC should receive +CMG from modem
    HSEROUT [10] 'ascii code for a line feed
    READSMS: 'Use this routine to read first 16 characters of new messages and then
    ' store them in the GSMBUFFER variable above then you are able to add a line at
    ' the end in order for an led to be switched on whenever the modem receives the
    ' correct SMS command such as LED ON or SWITCH etc
    HSEROUT ["AT+CMGF=1",13,10] 'Instruct modem to use text mode
    HSerout ["AT+CMGL",13,10] 'List new Messages
    ' Below I Read Caller ID, time and 16 CHARs of Message
    ' The timeout value in the HSERIN statement is important, it takes some time
    ' before the phone replies to the AT+CMGL command
    ' skip works like this: skip 4 (skips 4 characters) - this is a sample of the
    ' message that would be received after the AT+CMGL command is sent:
    ' +CMGL: 2,"REC UNREAD","+447977578999" Test
    ' Please note that I can't seem to receive the time in the reply as in this
    ' example: (of which the line of code is written for below - so maybe I should
    ' edit the line of code below in order to miss it - also remember to update
    ' GSMTime variable above i.e. remove it if your going to adit the line below)
    ' +CMGR: "REC READ","+xx1234567890",,"05/05/26,17:19:23+00" GOOD
    ' Loop could be setup as a routine such as:
    ' Loop:
    ' List new Messages again - as above (think about it)
    ' HSerout ["AT+CMGL",13,10]
    HSerin 5000,loop,[wait("UNREAD"),skip 3,STR Caller\13,skip 4,STR GSMTime\17,skip 6, STR GSMBUFFER\16\13]
    ' Basically in the above line, \13 - stores 13 characters and \17 - stores 17 characters etc into
    ' each of the buffers i.e. Caller & GSMTime etc etc
    HSerout ["AT+CMGD=1;+CMGD=2",13,10] 'Intruct modem to delete SMS's from location
    ' 1 & 2 as this is where any new messages will be stored, so its a good idea to
    ' delete them after we have processed the SMS command above - please note that
    ' it would be a good idea to wait for an OK after this command but we can add
    ' this at a later time
    ' --- Put your code to output the result here i.e. IF gsmbuffer = (your sms command) then goto
    ' subroutine etc
    Thank you for your time.
    Kind Regards,
    Royce
  12. #92
    On the following code the phone responds ..."REC READ",... if the message was read sometime before. If you have a fresh new message then this becomes UNREAD as you state on your code.
    So, why don't you change your code to:
    HSerin 5000,loop,[wait("READ"),... since the word READ is present all the time?
    ' Loop:
  13. #93
    Royce's Avatar
    Royce Guest
    Thank you for the info.
    I was wondering if you could tell me how I should use the data that is captured within the GSMBuffer i.e. the SMS text as I would like use this to switch on an LED. Should it be something like this:
    IF GSMBuffer = Switch on then LED = 1
    Thanks in advance.
    Kind Regards,
    Royce
  14. #94
    PBP does not have such string compring capabilities.
    You have to make your own subroutine to compare byte to byte the two string array. Like that:
    i=0
    while i less_than gsmbuffer_length (I cant sen the less character! Why?)
    if gsmbuffer[i]=compare_array[i] then
    'gsmbuffer[i]=0
    i=i+1
    goto wrong_sms
    wend
    correct_sms:
    'your code here
    wrong_sms:
    'your code here
    You understand that in compare_array you have to put your characters in some other place of the program prior to the above subroutine.
  15. #95
    Royce's Avatar
    Royce Guest
    Thanks again but I'm afraid I dont quite understand. Really sorry but would it be possible to be little clearer.
    Thanks again.
    Kind Regards,
    Royce
  16. #96
    Hmm, what part you are not understanding?
    Royce's Avatar
    Royce Guest
    Sorry.... would it be possible to add comments to each of the following lines:
    i=0
    'gsmbuffer[i]=0
    i=i+1
    goto wrong_sms
    wend
    correct_sms:
    'your code here
    wrong_sms:
    'your code here
    Could you give me an example using the SMS keyword: "switch on" in order to switch on an LED.
    Thanks again.
    Royce
  18. #98
    The commands used in the small piece of code are very elementary. So you have to read the manual because all the answers are in there.
    I cannot explain how an If-Then-EndIf statement is syntaxed or how is working. The code I gave you is very very easy and basic I could say.
    It is comparing one element of the array gsmbuffer at a time with one element of the other array. If it succeeds then it is moving on to the part of the program labeled:
    correct_sms:
    'you add your code here
    If it does not succeed then it is moving on to the part of the program labeled:
    wrong_sms:
    Try to write some code and see what happens. One part at a time...
    Royce's Avatar
    Royce Guest
    Thanks Ioannis. I will do my homework.
    Kind Regards,
    Royce
  20. #100
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Hello all,
    I have been doing something similar with an Ericsson T68I phone.
    I communicated at 1200 buad and use AT command set.
    I am NOT trying to send SMS, but DTMF tones. I am getting the phone to dial by using the access keypad AT command (rather than ATD command, which for some reason wouldn't work) and then activating send DTMF tones. Sorry I can't remember what the AT for these are, but what I dis was successful withoput too much trouble. Simple serout at N1200 (without MAX232 chip) was the most successful from a 4MHz 'F84. The T68I is autobaud so will talk at most baud rates above 1200.
  21. #101
    Aug 2005
    Hello all
    if I want not send sms But I dial to phone.How to make it.
  22. #102
    Feb 2004
    Germany
    tsupuntu,
    See: This
    And read the GSM thread from the beginning.
    regards
    Ralph
  23. #103
    aruran's Avatar
    aruran Guest
    Quote Originally Posted by NavMicroSystems
    aruran,
    Hai NavMicro,
    Sorry for the delayed response. I was involved in the project in another part..So I couldn't concentrate on the SMS sending part as it is almost finished.
    I have finished the PBP coding to send SMS using a Ericsson T10. It uses PDU mode since T10 supports AT command for PDU mode. So help from bitmaniac's PBP file helped me.
    I have attached the file.
    I also want to develop this to be integrated into a Embedded IP module for my project. I want to know how can I make this SMS sender to send sms when a centrallized MCU gives an interrupt and then the datas such as message, recepient number and so on are fed from that centrallized MCU to the MCU that controlling sending sms.
    Some people say that the PBP is not good for interrupt handling, and ASM codes inserted may be of use. Have anybody got any idea....
    thanks
    aruran
  24. #104
    Airrr's Avatar
    Airrr Guest
    Default oh no!
    i've read this thread a few times, but it wont work at all!
    nokia 6210 connected with RX to PIC 16f84a port b.1
    gnd2gnd
    now thats the programm
    SerOut2 PORTB.1, 396,["AT", 13, 10]
    Pause 1000
    SerOut2 PORTB.1, 396,["AT+CMGF=1", 13, 10]
    Pause 500
    SerOut2 PORTB.1, 396,["AT+CMGS=", 34, "+972544567209", 34, 13, 10]
    Pause 500
    SerOut2 PORTB.1, 396,["Test-message", 13, 10]
    Pause 500
    i tryed 8mhz crystal and 12mhz
    pic sends some pulses out, but mobile just do nothing
    is it a wrong programm or what?
    ps, i need simply to send SMS.
    i think i missed something important..
  25. #105
    Jan 2004
    Thessaloniki , GREECE
    Wink
    First of all I would like to say a big HELLO! to all of you.
    I was out of this forum for some months and I really like the fact that this topic is of so great interest , while I am back.
    SO back to PICs again..
    Airrr:
    I would advice you to read all the related topics about sending sms with Gsm ,
    so to take an idea of how this works.
    But to make you start:
    A simple way to test if your phone is working ok (making sure you have checked the connections) you can connect it to your PC serial port and try sending AT commands using a terminal program like HyperTerminal for example
    (set speed 9600,8,n,1)
    OF COURSE YOU HAVE TO USE A RS232 LEVEL CONVERTER as your serial port
    works with rs232 level volt (+-12v) and your Nokia ecpects TTL level volt (+-5v).
    Second, as reading your code I noticed that you are trying to use NOKIA 6210 in 'text mode' and I am not sure that 6210 supports text mode.
    I think it only supports PDU mode but I am not 100% sure.
    You have to encode your text sms in PDU format in order to 'feed' it to your phone trough AT commands which is a complex procedure with pic but IT IS possible -please read through the topic to get an idea.
    I hope I have helped you a little
    AGAIN A BIG HELLO TO ALL OF YOU!
  26. #106
    Airrr's Avatar
    Airrr Guest
    Talking
    i have made this circuit for interfacing rs232 to nokia
    http://pinouts.ru/images/cable_cell2.gif
    now im starting huper terminal, 9600, com1, 8,n,1, connected xx:xx:xx and
    i can't type anything, pressing on keys don't display nothing, but schematic works fine with logo manager as f-bus cable.
    ? how it could be? logo manager works, does it meen cable is OK?
    after few hours i have sucesfully send msg from hyper terminal. now some other questions
    1: is it so necessary to use pic on mbus? if so, my project has to be double pic'ed
    2: finaly project uses a 9210 mobile, but seems like communicator dont recognize pic on mbus (debug led on pic remains off all the time)? 6210 works, but now i need to do the same with 9210.. any suggestions?
  27. #107
    Sep 2005
    Switzerland
    Quote Originally Posted by Airrr
    i have made this circuit for interfacing rs232 to nokia .....
    I have the same problem with hyperTerm, how were you able to send AT cmds ?
    Lotondo
  28. #108
    Quote Originally Posted by Lotondo
    If you follow the thread from the top, you will find out how. Anyways, just type the commnds that are relative to the phone being used: AT+CMSG etc...
    Look the manual of your phone and then type them in your terminal. You can also set your modem to ASCII and not PDU format which is more convinient.
    Airrr's Avatar
    Airrr Guest
    Lotondo: like on the schematic abowe, u have to use pic connected to m-bus and if its working good, phone will connect to terminal...
  30. #110
    Apr 2005
    gnd2gnd
    Pause 1000
    Pause 500
    Pause 500
    Pause 500
    I succesfully done it using this code..
    Device 16F84A
    Declare Xtal = 4
    Symbol BAUD = 84 ' 9600,8,N,1(True,driven)
    SYMBOL LED = PORTB.2 ' Assign PortB.2 for Status LED
    Symbol TX = PORTB.1 ' TX to Phone
    Symbol RX = PORTA.0 ' RX from Phone
    Start:
    SerOut2 TX, BAUD,["AT",13]
    DelayMS 500
    SerOut2 TX, BAUD, ["AT+CMGF=1",13] ' Use TXT Mode
    LOW LED ' Turn OFF Status LED
    DelayMS 1000 ' Pause for 1 second
    HIGH LED ' Turn ON Status LED
    SerOut2 TX, BAUD,["AT+CMGS=",34,"Recipient Phone Number",34,13]' Prepare the recipient Phone Number
    DelayMS 1000 ' Pause for 1 Second
    SerOut2 TX, BAUD,["TEST Message!!",13] ' The message to be sent
    SerOut2 TX, BAUD,[26] ' Terminate message with Control+Z (26)
    DelayMS 1000
    Goto Start ' Repeat
    What i did is some sort of SMS bomber...look for the circuit I posted before to make this code works..
    Notice that all it does is send..TX. I dont process any message I received so RX was not used.
    BR
  31. #111
    Sep 2005
    Switzerland
    Kasamiko,
    thanks for sharing your project.
    I built it according to your above schema but the test I did had no success.
    The pics receive 2.8 V. from the phone, is that enough ?
    IC2 has your software with my data (phone nr. + text)
    IC1 has the the software found at http://www.atrox.at/datacable/dlr3/dlr1.hex
    LED1 is always flashing
    LED2 is just flashing once.
    Could you pls. tell me the pic config (osc, wdt, pwrt) ?
    What's the purpose of diode zener (D5 2.7) ?
    Thanks your or anyone else support.
    Lotondo
  32. #112
    Apr 2005
    That circuit is drawing power from the phone..2.8VDC is enough since this is the maximum the phone can supply. Please remove that zener Diode that was left when I was experimenting powering it with external power supply.
    I think you have the problem with the HEX you used for the DLR-3P part since LED1 will light steadily. You used the wrong HEX! this is the link for the 8 Mhz version..http://www.atrox.at/datacable/dlr3/dlr2.hex
    LED2 will continously blink meaning it is sending SMS.
  33. #113
    Sep 2005
    Switzerland
    Kasamiko,
    thanks for answering.
    I did what you said.
    Now the LED1 is always on and not flashing like before. This should be ok.
    Led 2 is just flashing once cause I turn the loop off.
    Till here should be everything correct but I dont receive any sms on the
    other cellphone.
    Testing my phone (7110) with a DLR3P cable (Nokia cable) and hyperterm I noticed that it worked only at 19200 baud. I knew that it should also work with a lower baud but it did not. Maybe it's the DLR3P cable that 'force' it works at 19200.
    Btw here is "my" code pls have a look.
    Thanks again for any further help.
    Lotondo
    ;Device 16F84A
    BAUD VAR BYTE
    LED VAR PORTB.2 ' Assign PortB.2 for Status LED
    TX VAR PORTB.1 ' TX to Phone
    RX VAR PORTA.0 ' RX from Phone
    Start:
    Pause 500
    Low LED ' Turn OFF Status LED
    Pause 1000 ' Pause for 1 second
    High LED ' Turn ON Status LED
    SerOut2 TX, BAUD,["AT+CMGS=",34,"0761111111",34,13]' Prepare the recipient Phone Number
    Pause 1000 ' Pause for 1 Second
    Pause 1000
    ;GoTo Start ' Repeat
    Hi!
    All phones default on power up to Autobaud mode. The first connection defines the speed from that moment on upt to the next power up.
    This is over ruled only if you define explicitly and store to the phone's memory the speed to use.
    So, in your case may be you did a connection with the mobile at 19200 with the Hyperterminal and then without reseting the mobile, did you connected to the PIC circuit? Are you sure the mobile does autobaud at power up?
    Hi!
    So, in your case may be you did a connection with the mobile at 19200 with the Hyperterminal and then without reseting the mobile, did you connected to the PIC circuit? Are you sure the mobile does autobaud at power up? If it does then you should send an AT command without any parameters to sync the mobile to the speed you set in the beginning of your program.
    Sep 2005
    Switzerland
    Hello,
    as far as I know, I read again the manual, it's not possible to set baud speed to be used through the port. The only set possible for baud speed is if you want to connect to the internet (wap). I tried in any case to set it at 9600 but it did not work.
    I checked the at command manual and i did the following check with the cable and hyperterm (19200,8,N,1):
    AT+CBST?
    > +CBST:0,0,1 the phone is in autobauding
    then i typed:
    AT+CBST 7,0,1
    AT+CBST?
    > +CBST:7,0,1 the phone is at 9600 baud
    Great, I thought, now i change the hyperterm setting from 19200 to 9600 and let's see !!
    Nothing, exactly like before, at + enter, no answer back
    I reset the hyperterm to 19200 and i type
    AT+CBST?
    > +CBST:7,0,1 the phone is still at 9600 baud
    Seen that the phone is in autobauding and it's not possible to set via menu
    I'll try to add to the code this:
    >>CUT
    Start:
    SerOut2 TX, BAUD, ["AT+CBST=7,0,1",13] ' <-------------------------------
    Pause 500
    >>CUT
    I have some doubts but I will try
    What do you think you guys ??
    Bye
  37. #117
    Sep 2005
    Switzerland
    i added this line
    but no success.
    I'm running out of ideas.
    Thanks for yr help
    Lotondo
  38. #118
    Sep 2005
    Switzerland
    Tried with Sony Ericsson T610
    it works just GREAT !!!!
    I dont know what's wrong with damn Nokia 7110 !!
    Any help will be appreciated
    Lotondo
  39. #119
    Why not read any manuals about the specified phone?
    With Wavecom module, 6210 and 6310 I had no problem with any commands. May be your phone is a little different.
    Sep 2005
    Switzerland
    Guys, I finally successed !
    The Nokia 7110 did work too !
    Here what I did:
    The 7110 boots and sets itself in autobaud mode,
    even i forced it to work at 9600 baud with
    AT+CBST= 7,0,1
    it did not send out any sms. (see code previous msgs)
    Now I did not want to waist more time I already did,
    so I reprogrammed the 16f84a and I change the
    line:
    with this one
    BAUD = 32 ' 19200,8,N,1(True,driven)
    and it worked !
    According to what I read here and in some manuals
    the 16f84a with 4Mhz quarz should not work properly
    with that baud speed, but it did.
    Now I'll get more time to study some code
    Thanks again
    Lotondo
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  4. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  5. Pic to GSM Phone connection
    By samertop in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 13:40
