Small pin-count device for generating output frequencies when triggered
Results 1 to 10 of 10
    Default Re: Small pin-count device for generating output frequencies when triggered
    If you need to be able to change the tone "continously" then rearanging the code slighty might make it a little bit better, the glitch should be in the us* range:
       GO_DONE = 1		    ' Start the conversion
       IF Trigger THEN
          Sound SPK,[Tone / 4 + 50, 1]
       WHILE GO_DONE : WEND	' If trigger isn't 'on' we need to wait for the ADC.
       Tone = ADRES
    Goto Main
    *Depending on how much time SOUND needs to "set it self up".
    Hey Jim, If all you are looking for is an A/D to Oscillator output have a look at maybe using some Linear Tech. TIMER BLOX. They make 2 different VCO's to cover the range from 29uHZ to 977 HZ and 1 for 488HZ to 2Mhz. They are in 6 pin SOT packages. Just a thought.....
    EN82fn
    Feb 2012
    Hi Dave,
    I just looked at the datasheet for the LTC6990 and it does look like it could work for what I need. I would have to test how the frequency ranges sound first, but it seems to have everything I need (OE to trigger it and Freq can be controlled by a POT manually). I'll have to test it and let you know.
    Jim
  1. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 08:32
  2. Replies: 3
    Last Post: - 24th September 2010, 07:10
  3. How to know what pin triggered an interrupt?
    Last Post: - 13th October 2008, 07:29
  4. Turn on output pin
    Last Post: - 11th March 2007, 11:49
  5. Input / output using same pin
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:19
